Results 1 to 18 of 18
    Apr 2015
    Tucson, AZ USA
    Default 2020 RTL Removing Brake Fluid Reservoir
    How do you remove the brake fluid reservoir on a 2020 RTL to move it out of the way to do your oil change?
    Regards,
    Rob Owen
    Mar 2013
    On mine there is a small tube spacer on the back of the bracket. Pulling that out from the side allowed the brake res to pull free.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    I used a hemostat to grasp the tube end and pull it free. Tried with bent needle nose pliers and it was difficult.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by robhowen View Post
    Regards,
    Rob Owen
    Just lift up (less than 1/2 inch) and pull out. Disconnect the wires on the sides first. Once you pull it out, you'll see how easy it fits in.
    2020 RT Limited , Chalk
    Sep 2020
    Central Oregon
    Quote Originally Posted by Copperman View Post
    Mine won't pull out without removing the black locking tube. It's about an inch long by 1/8.
    Spyder Tryke Pylot
    Jul 2010
    Las Vegas, NV
    Remove black tube, lift.
    To get the tube out, small needlenose pliers. Hard to see, easy to drop!
    Joe Meyer
    Sep 2020
    Central Oregon
    Quote Originally Posted by cptjam View Post
    That's why I used a hemostat. They lock closed on the tube so there is little chance of dropping it behind the panels.
    Spyder Tryke Pylot
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by ButterSmooth View Post
    You must have been a head in your younger years.
    Sep 2020
    Central Oregon
    Fixed your typo:
    You must have been ahead in your younger years. 8^)8^)8^)
    And, thank you!
    Spyder Tryke Pylot
    Apr 2015
    Tucson, AZ USA
    Default Got it!
    Got it, Joe. Do you put it back in when reinstalling? I ask because I wonder if the reservoir will stay just fine without it.
    For others: For me it was easiest to see looking from the top and rear of the reservoir. I also found it easiest to pull out from the rear side (versus the front) using small needle nose pliers. Bent needle nose pliers did not work well for me.
    Rob
    Sep 2020
    Middletown, NJ
    No need to reinstall the tube IMO. The reservoir will not fall off when the panels are in place.
    2020 RT base , Chalk White
    Aug 2012
    Central Coast, CA
    When I did my first oil change, after letting the dealer do the break-in service, which was part of the purchase deal. I found the tab that holds the rubber sleeve was broken and it fell apart when I took it off.
    It wasn't important enough to me to get into an argument with the dealer's service department about who was responsible, so I just used a semi-loose zip-tie to hold it fast. Although, not really needed I felt better about it.
    2020 RTL SE6
    Aug 2017
    Wisconsin
    Regards,
    Rob Owen
    I used a hemostat the first time to remove the short black piece of tubing that locks the reservoir in place. Then I dropped the little piece into the guts of the machine where it’ll never be seen again. No loss. I cut a 6” piece of 1/4” plastic tubing and pinched the end with a pliers to make it easier to insert. The longer piece can be installed and removed with no tools. Any hardware store will have the tubing.
    May 2016
    Mansfield, Ohio
    Same thing here! Just cut a 6" piece of nylon air line and the end slides right in and leaves a nice long section to grab when removing the next time. If you leave it out, I suppose there could be a remote chance of hitting a bump and having the reservoir dislodge. But the 6" hose will eliminate any doubt.
    2021 RT Limited , Deep Marsala Metallic (red)
    Feb 2019
    LA
    Mine must have fell out when I pulled the reservoir because I don't find it. I just set it back in the bracket it seemed to be doing fine. I would like to put some sort of tube back on it but do not know how it goes on. In
    May 2016
    Mansfield, Ohio
    Quote Originally Posted by drkennedy61 View Post
    There is a quarter inch void above the hanger clip that allows the reservoir to be raised up in order to release it from the clip. You should be able to see this void as you move the reservoir up and down on the clip bracket. If anything is inserted into this void when the reservoir is in place, it will simply prevent the reservoir from lifting up. They could have easily put in a longer piece of cheap hose instead of that tiny 1.5 inch long piece!
    Nov 2022
    Florida
    Default Brake fluid reservoir
    All I did on mine was to pry it up and pull it out. 2020/2021 rtl
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Dennis4728 View Post
    Maybe so but, at one time there should have been a small black tube at the top to hold it in. Beside with this thread being a couple of years old, I'm sure he has it by now.
Tags for this Thread
