Page 56 of 80 FirstFirst ... 64652535455565758596066 ... LastLast
Results 1,376 to 1,400 of 1985
  1. #1376
    Aug 2019
    Stoughton, WI
    Finally broke the Spyder out of hibernation. With temps in the lower 50*s, it took awhile for the Ride-On to start distributing
    2022 RT Sea To Sky
  2. #1377
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Installed a lock I bought from Slingmods for the front compartment of the wife's Ryker.
    2021 RT Base - Petrol Blue
  3. #1378
    Mar 2015
    Fritch, Tx
    Default If one picture is worth . . . . then what are eight worth?
    I'll just let the pictures tell the story. If they don't appear in order or disoriented, well can't change the site's idiosyncrasies.
    I'm posting this in hopes it will help others as the one video I could find had some spots that were so dark you could not tell what was happening and some of the dialog was incomplete.
    Those who say " I can't" will always be right.
  4. #1379
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by cruisinTX View Post
    It would appear like you were installing Magic Mirrors, but........that’s only a guess on my part. An explanation of what we’re seeing would help a lot.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  5. #1380
    Mar 2015
    Fritch, Tx
    Quote Originally Posted by bigbadbrucie View Post
    it would appear like you were installing magic mirrors, but........that’s only a guess on my part. An explanation of what we’re seeing would help a lot.
    bingo!!
  6. #1381
    May 2021
    Upstate NY State
    My Bar Clamp with 1" ball I bought from lamonstergarage should be in today so I can move my phone from the top cuff to between the bars.
  7. #1382
    Vermont
    AT the dealership for a new belt (due to bad cogs, and not being safe to drive) the belt will be in next week at the dealership. So I am Spyderless until next Friday.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  8. #1383
    Deanna
    Which " cogs " are damaged .... and what caused them to be damaged ???? .... Mike
    Last edited by Peter Aawen; 05-05-2023 at 12:51 AM. Reason: Fixed quote display ;-)
  9. #1384
    Vermont
    I don't know which "Cogs:" were damaged, and I don't know how they got damaged. I have a stone on the belt guard.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  10. #1385
    Deanna
    Well it's your money ( about $500.00 or more ) ..... I have seen pics of some belts with very noticeable damage .... that were not re-placed and continued to be used for many. many more miles .... Has your " significant other " looked into this ???? .... good luck ... Mike
  11. #1386
    Jan 2023
    RI
    Installed Helibars on my 2022 RT Limited. Should make a difference in comfort.
  12. #1387
    Active Member mark4Jesus's Avatar
    Sale Creek, Tennessee
    Installed them on mine earlier in the week. The best!
    2013 RT Limited.
    BajaRon Sway Bar.
    Refined Cycle's BPE2 brake pedal extension.
    Pedal Box
    2013 RT Limited , Refined Cycle BPE2 White
  13. #1388
    Oct 2015
    Lynden, WA
    Installed: Ultimate Floorboards,
    Throttle lock bar end weights,
    Drilled my top cuffs for future install of mirrors.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  14. #1389
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    did my 1st oil change, don't think the oil has been change, bike had 537 miles on it when i bought it, it now has 1822 miles now, i got it in dec 22 and its a 2020. the oil smelled really funky, couple of slivers on magnet and what looked like a little dirt on the oil filter cover stick on the bottom. New Amsoil and it sounds so much better
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
  15. #1390
    Mar 2015
    forrest above Reno, Nv
    Default Ryde prep.
    Did prep for rydes on Friday and Sunday. Yesterday was cleaning, Today is tire pressure, air bag pressure, fluids,ect.
    Lew L
    2014 RTS , Circuit Yellow
  16. #1391
    Mar 2021
    Maryland
    I took a ride to Brooks Powersports in Grantsville Pa. yesterday to get my alignment done.
    They were nice enough to lend me a demo RT and gave me a recommendation to a local diner to go to for breakfast, the Skyline diner.
    Breakfast was great and when I got back they had found an issue with the tie rods. One was all the way in and the other was all the way out.
    I was surprised as I had not noticed this so I suspect this was another issue leftover from the reframe done by another dealer so I had some extra time to spend there and talk with a nice gentleman that was buying an rt and a couple of other people that were picking up their rykers all with big smiles on their faces.
    Even though it is really out of the way for me they have really won me over as my go to dealer.
    So this finally completes my yearly maintenance and all I need now is gas and time to enjoy the season. Next year plans is to upgrade from Rons standard to his ultra bar and maybe install a s model right hand control for cruise control.
    2020 F3 SE6
    2020 F3 , Black
  17. #1392
    May 2021
    Upstate NY State
    I did nothing today but I did order the new Pedal Box Pro from lamonster over the weekend. It's bluetooth so not need to install the module on the handlebars.
  18. #1393
    May 2021
    Upstate NY State
    Here's a couple of pics of the wife's bike. I added more color to the top case, removed the can-am stickers from the air filter cover and changed it to the name of her bike, and I added a couple of 3D printed covers with the name of her bike as well.
  19. #1394
    Apr 2023
    Seattle Washington
    I towed My 2020 F3S spyder today.... Check Key came out again... Another $275....
    2020 BLACK SPYDER F3S
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    TUFSKINZ TANK PROTECTOR CARBON FIBER
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    SENA 10C PRO BLUETOOTH
    ALPINESTARS JACKET
    SCORPION EXO ST 1400 CARBON HELMET
  20. #1395
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Quickdraw View Post
    Nice touches for the wife! Maybe it earned you a couple of brownie points.
  21. #1396
    May 2021
    Upstate NY State
    Thanks. I got double extra points because I installed the steering damper as well and she has already noticed the difference.
  22. #1397
    Sep 2021
    NY or FL
    Just finished installing seat heaters from Motorcycle Dave. Must say the seat removal and install on my 2015 RT is a real PIA.
  23. #1398
    Nov 2019
    Central Oregon
    Added 1.5 cm of preload to front shocks.
    Went for a ride. MUCH better ride and a smidgen sharper handling on curves. I still plan to install higher weight coil springs on the original Fox shocks. Either 300 or 350 pounds.
    While riding I went through two torrential downpours. Standing water in the road. The new Vredesteins cut through the water as if it were dry pavement. The rear, stock Kenda tire, original (made in 2014) with plenty of tread, fish-tailed repeatedly. Interesting and almost fun, but now I'm thinking I'll need to add a real tire to the back of the bike soon.
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (Front).
  24. #1399
    Nov 2018
    Northern NV
    Took it back to the dealer to have them replace a newly-installed front tire that was out of round and causing vibration in the front end (thanks, Kenda!). This is the first set of replacement tires I've put on the F3 and it'll be the last Kendas it'll wear as long as I own it. Would have gone aftermarket but wasn't sure if I could get them mounted. Of course, that info became available just after I'd gotten the tires changed!
    2017 F3T , Black, black and more black
  25. #1400
    Mar 2021
    Maryland
    Quote Originally Posted by Columbia View Post
    I have had my rear Vredestein fishtail in the rain but that was during those torrential downpours that went through Tenn. and Ky. last July and flooded places out. I was in the heavy part of one storm going through Blue Ridge City Tenn. on my way to the Cherohala Skyway in Tellico plains.
    I was able to do about 25 mph safely in a heavy enough down pour that it was running down the hills on the road in sheets. Once I pushed it past 25 and got around 30 it would start to fishtail, but I wanted to go slow anyway as the last thing I wanted to do is get past my clearance with the water in a place where it was ponded and swamp the frunk area in a huge puddle. It was great when I looked down at the front fenders, they were like two pumps throwing water out to the sides. Plus, I had some jerk in an F350 coming the opposite direction go out of his way to hit a puddle which caused a wave of water to hit me. Luckily, I had on my raingear real tight and only had the water that infiltrated my vents on my helmet run down my neck. Once I got to Tellico Plains, I took my suit off and was completely dry to enjoy my evening ride on the Skyway.
    But in normal rain when I left Roanaoke Va. on that same trip I was able to do highway speeds on I-81 and didn't have any issues at all. Blue Ridge City was an awful extreme for a half hour on the approach from Ga. the sky was just an awful evil black, at least I heeded the warning and geared up before I started through it.
    2020 F3 SE6
    2020 F3 , Black
