Headlights Stopped working!! Any fix ideas/suggestions?
I don’t ride a lot at night so I do not know when this actually started. Both front headlights and mirror running lights are not working. There is also no actuator noise when toggling the HI/LO switch. I have checked the fuses and relays in the frunk and under the seat. Voltage shows 14v at idle. Not sure where to dig in next. Only electrical mod I have done is adding the LED strips to the fenders and replacing the fender running light bulbs with the appropriate LED bulbs.
Thanks in advance!!
2011 Spyder RTS
****UPDATE*** Making progress! Swapped relays around and got the headlights to work.
I think there is a relay for the headlights. I don't know that model though.
2014 RTL Platinum
I am curious, Did you get the mirror running lights back?
SpyderLovers Ambassador
Bad Relay ? ?
Thanks in advance!!
2011 Spyder RTS
What was your final fix?
A bad relay(s)?
Corrosion on the contacts?
Or something else?
Thanks for the Heads Up. ......
ENJOY YOUR LIFE WITH A SPYDER
I have a 2012 rts same problem no headlights tried relay swap check fuses no fix. What’s next
Do hear the shutters clunk when you switch between hi and lo?
Tags for this Thread
