Re TYRE PRESSURE MONITORING SYSTEMS. Which one?
So this self-confessed Kiwi Luddite is considering dragging himself into the 18th century or so re these TPMS systems.
Yep it’s true, only considering mind you.
Naturally I’m not really a fan of phone apps but will concede now and again. It’s a good option.
But I’m swinging towards the display type right now as a real time preference.
When I ride my phone is in my pocket and have no burning desire to change that.
Thought I would start a new thread rather than add to I hate this as it keeps it all in one thread but that what prompted it.
So…let us begin with a couple, well 5 actually starter questions.
I see there are a few to choose from and some are powered to the bike and others have Solar.
I’m guessing you just unscrew the valve fitting like the OEM valve cap to add air?
How long will those button batteries last?
Waterproof/resistant?
And lastly which one do you use and would you buy that one again or swap for something else?
Cheers and looking forward to being Egdemicated somewhat.
The only one I've ever looked into is the FOBO2. But that is a phone app thing.
Greg Kamer
USAF, 20 years, retired
![](signaturepics/sigpic18882_5.gif)
2018 Can Am Spyder RT-Limited
Iso, I have only used FOBO as it works a treat for me, as a phone app. As such, it is not “powered” to anything. Sorry, but I have never looked at alternatives as FOBO fits my needs.
Yep, unscrew the sensor just like a valve cap to add air.
The button batteries last around 6 months for me, and then it’s as simple as unscrewing the sensor, unscrewing it’s two halves, sliding the battery out, sliding the new one in, and reversing the removal procedure.
Yes, they are waterproof.
Also, they come with locking nuts. I have never used them as they are a pain, and have had no issues.
Regarding your phone, you can set your high/low tyre pressure, then you simply check your pressures on your phone as you approach your Spyder, put your phone in your pocket, and it will vibrate and sound a loud warning of your choice if those parameters are exceeded.
I’m still running the original FOBO 1, and have been for 7 years. If they cark it, I would swap to the more modern FOBO 2.
I have never had to call FOBO support, but I believe a couple of users have said that they are a bit hit and miss.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I'm considering getting this: https://www.amazon.com/dp/B07ZL2ZB92...lig_dp_it&th=1 I had a similar system on my GL1800 that worked well as long as it was on "T" stems.
1976 RD400c
I also have the FOBO2, and as previously mentioned have never tried or investigated anything else. Peteoz says that he replaces the button battery every 6 months, but from what I've seen with mine, the battery lasts well over a year, possibly 2 years. Like Pete0z suggests, check your tyre pressure prior to getting on the byke and then put your phone in your pocket. You will be notified by either a vibration (if your phone has that option), or by a LOUD ring or buzz if you have a catastrophic loss of air. I also do not use the locking rings....don't seem to need them. Good Luck.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
2021 Spyder RT Limited
![](signaturepics/sigpic43415_1.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by rjinaz86323
Probably not a popular opinion, but I had a Fobo2 and sold it. I found it very distracting. I was always obsessing over a pound or two difference. Now I just check before each ride and don't worry about it. If a tire has a slow leak I will notice it before it goes completely flat (if underway you will feel the handling change. If it blows out the Fobo won't tell you in time to do anything about it anyway). JMHO
It doesn’t matter if your opinion is popular or not, rjinaz. Everyone has their own reasons for using/not using something, but “distracting” seems a rather odd reason for giving FOBO a “fail” ?
I find exactly the opposite. Checking my tyres in 10 seconds before a ride, and then putting my phone in my pocket and forgetting about the tyres because you’ll get a warning if they are not functioning as planned, provides me with added confidence, not a distraction .
HeliBars Handlebars
Kenda Kanine rear.
FOBO 2 for all the reasons listed. I don't check my tire pressures all that often but they are there if I need them.
Peter Pan has struck again!
![Quote](images/misc/quote_icon.png) Originally Posted by Peteoz
I don't give the Fobo a fail. It does what is is designed to do. It just doesn't mesh with my semi-OCD mentality.
![](https://www.spyderlovers.com/forums/maps/map.png?states=HI.CA.NV.OR.WA.ID.MT.WY.SD.IA.NE.KS.MO.AR.OK.TX.NM.AZ.UT.CO) ![](https://i.imgur.com/k9M9Kkkm.jpg)
I use the FOBO 2. The readings are the same as I get on tire pump.
2022 Spyder RT Petrol Metallic Blue.
![](signaturepics/sigpic36536_1.gif)
Yep…….understand completely, rjinaz ![2thumbs](images/smilies/a18.gif)
HeliBars Handlebars
Kenda Kanine rear.
FOBO 2 , as everyone else has stated.
I also use the FOBO2 and found the batteries that came with the unit lasted two years before it showed on the phone app that they were in need of replacement. I really like having this system in place because it saves me the considerable effort of checking the rear tire pressure. I find that the only way to get a tire pressure gauge on the rear tire stem is to be laying flat on the ground, which for an old guy like me is a real pain. With the FOBO2 I just pull out my phone when getting ready to ride and I am good to go.
2021 Spyder RT
2023 Royal Enfield Hunter 350
Retired U.S. Army
Life Member, NRA
![Quote](images/misc/quote_icon.png) Originally Posted by pidjones
I have a similar two wheel version.
1.) The sensors unscrew and you add air, I have the lock washers installed and yes it is a pain to add air. Though I usually only need to add air at the start of the riding season and maybe again late in the season.
2.) The sensor batteries have lasted about two riding seasons, maybe longer but I change them anyway. The monitor, once charged, lasts for days when traveling. I usually charge at night every second or third day when traveling.
3.) Waterproof, not sure. But I have ridden with the monitor exposed to rain numerous times, full fledged frog chokers, and never an issue. Mine mounts on the handle bar and easily unscrews, so removal is easy. Or just slip a zip lock bag over it if concerned.
4.) Mine (2 wheel version) is a Mecru - Newell TPMS System.
I've been real happy with it and would purchase again. And will look at pidjones's referenced one when my Ryker arrives.
YMMV
2023 Ryker Rally - Heritage White III
Sport Windshield
GPS Holder
![Quote](images/misc/quote_icon.png) Originally Posted by vito1943
This, and an earlier comment really got me thinking, Vito. I just realised that -
1. I am running old FOBO 1 sensors.
2. I have an old iPhone that I leave in the garage as I try BRP GO from time to time to see if it has improved to the point where it is of use to me. (Hasn’t happened yet ). That phone also has the FOBO app running, meaning it is communicating via BT on an ongoing basis. This may indeed be the reason I am only getting around 6 months battery life.
HeliBars Handlebars
Kenda Kanine rear.
![Quote](images/misc/quote_icon.png) Originally Posted by shardt
Is there a way to stop it from alarming on the missing 4th sensor? Seems this would be great for us, as we sometimes pull a Uni-go (single wheel) trailer.
1976 RD400c
Ozzie Ozzie Ozzie
2 for the Front Wheels; 1 for the Rear Wheel; put the 4th sensor on the ACS Air Bag. Problem solvered!
![Quote](images/misc/quote_icon.png) Originally Posted by Peter Aawen
2 for the Front Wheels; 1 for the Rear Wheel; put the 4th sensor on the ACS Air Bag. Problem solvered! ![thumbup](images/smilies/thumbup.gif)
Or, set up 2 profiles, 1 with trailer, one without. Click on the one you need to see.
Himm I think I need the 3 set as my F3 Ltd dosnt seem to have the valve or that ACS Air Bag. Unless you can turn off the 4th one. Donno.
![Quote](images/misc/quote_icon.png) Originally Posted by Isopedella
Iso, my ‘16 F3-L had a shraeder valve under the rear seat, on the left (closest to the kerb) side. I’d be surprised if you don’t have one, unless they made a big change between ‘16 and ‘17. I had a FOBO connected to it.
…..and even if you don’t have one, there is no need to set up the 4th unit.
HeliBars Handlebars
Kenda Kanine rear.
Fobo2 will also alarm into a headset if low or high pressures are found. To me, that was most important to be able to react quickly in real time.
John B.
Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
![](https://www.spyderlovers.com/forums/maps/map.png?states=FL.GA.AL.MS.LA.TX.OK.AR.TN.SC.NC.KY.IL.MO.WV.VA.NM.AZ.CO.UT.MT.WY.ND.SD.MN.IA.WI.KS.NE.CA) ![](https://www.spyderlovers.com/forums/maps/map.prov.png?states=BC.AB.SK)
I've used one of the car based systems for years now. I think FOBO is overpriced for what it is. I don't need it to alarm through my phone or anything else as I can just glance over and see what the pressures are. The sensors look identical to what the car based displays use. If you don't activate one of the sensors, it will never be monitored or displayed. Batteries last about a year, maybe longer. Velcro it down to the top of the dash and it stays there.
2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
\ ![](https://www.spyderlovers.com/forums/maps/map.png?states=NC.VA.WV.OH.PA)
This is exactly how I have mine.
