Whining at 45 MPH - Anyone recall what causes this?
I'm sure I saw a thread on this once, but can't find it. The sprocket recall was done recently and since then there has been a whining sound around 45 MPH. Nothing before that and it goes away once I'm going faster than that. Anyone recall what causes this? Thanks
2018 F3 Limited
I get some of the same thing on mine. In fact, I've had it before on the original sprocket after a belt adjustment had been made. At one time it squealed like a banshee until it was readjusted. I think its the belt rubbing the front sprocket that causes it; seems to me adjustment is a sensitive thing. Some folks have the knack and do it themselves; I tried but never got it right.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Having that issue with my 2020RT, I can give one case opinion and results: I took my RT to a dealer complaining of a "really loud whine between 47-52mph". The service manager rode it and said "that really IS a loud whine!", and they replaced the front sprocket and bolt under warranty (my Spyder was over the 2 years, and about 9000 miles at that time). Result: I still have the whine, but not so loud, and it's tolerable.......
John B.
Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
I would have to ask, which recall sprocket did they put on, the latest and greatest, the white one, and how is your belt alignment look?
Ozzie Ozzie Ozzie
I got the latest and greatest and the belt looks the same as before the sprocket replacement. Puzzling...
2018 F3 Limited
They did NOT install the white pulley, and the belt alignment is within specs (a playing card thickness from inside flange). My RT is a 2020.... Isn't the white pulley for the "red rust of death" issue?
John B.
Ozzie Ozzie Ozzie
I had a 2020 RTL and it had a noticeable whine at those speeds but with the engine panels, was tolerable. Now, have a 2022 F3L Special and the whine noise is really loud with the exposed engine area. The bike did come with the white front sprocket in front. I just stay outside those speeds that bring out the annoying whine.
I used to get this annoying whining sound coming from the rear, then I left the wife at home. All good now. Until I get home then it starts again...
Andrew
Melbourne Australia
2016 F3L Spyder
Now, wash your hands
My guess is the belt tension has changed a bit (less) and it why it has lessened some... Might wanna try an even lower tension setting as a lot of folks have reported that it has stopped their "noise" and "vibrations"... I have lowered it on my '15 F3S due to vibs and it also now no longer makes a minor squeaking/rubbing noise when I wheel it in and out of the garage pre-post ryde....
Chuck
I have a 2016 F3L, had the sprocket recall done about month ago and started noticing the rub/whine noise at low speeds. Just got back from having it adjusted, the belt was barely rubbing on the new pulley. However, when I rode it back down the mountain, I live on 181 in Morganton,NC…great motorcycle road…I noticed the high pitch whining again, even with my full face helmet on. The rub is gone but the whining is worst! I have the new silver pulley “fix”. I didn’t have any whine or rub with the old sprocket.
