Page 54 of 79 FirstFirst ... 44450515253545556575864 ... LastLast
Results 1,326 to 1,350 of 1973
  1. #1326
    Feb 2012
    Spring City,Utah
    waited for the snow to melt so I can get it out of the trailer I use for storage.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  2. #1327
    Aug 2019
    Stoughton, WI
    Checked/adjusted tire pressures and took the FOBO II caps out of basement hibernation/installed. Ready to roll
    2022 RT Sea To Sky
  3. #1328
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Put the Home Depot Spring on my top case to get me through riding season. It actually works quite well .
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
  4. #1329
    Sep 2015
    Mocksville,NC
    Getting my new trailer equipped with e track to haul the Spyder when the whole family is going with us on vacation and I want to take the Spyder. 20230406_110739.jpg
    The trailer is a 7x12 tandem axle Rock Solid brand.
    Lamonster Riser
  5. #1330
    Vermont
    I took a ride on my spyder.
    It felt good to be back in the saddle again.
    Took the spyder out of hibernation
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  6. #1331
    Jan 2019
    Hunter Valley NSW Australia
    After having a number of issues with my driving lights/wiring/relay i ripped it all out. I had thought I had killed my Baja Designs S2 Pro Combo lights and in a last ditch effort connected them to an alternate power source - they were fine - phew - that was $600 i wasn't going to have to throw away and another $600 to replace them.
    Changed to a different type of fuse block - it was more compact but not water proof. Taped up all the external contacts and clear cover and sprayed with LeakSeal. I also changed the mounting of the relay and gave it a spray after masking the contacts to make it hopefully waterproof.
    Today I learned !!!!
    • If my earth is in any way imperfect, its going to create problems
    • Working with LeakSeal is messy, but worth the effort (see below)
    • My expensive Crimping tool is only good for crimping one type - the other sets of "jaws" are useless.
    • When testing expensive LED's make sure the power source is healthy.
    The whole setup got a test a few weeks ago in atrocious conditions and lights/trailer/crashcams all stayed alive during some very heavy downpours - water got in and upset the dash on my '17 RTL a few times though. As others have seen my 622 Trailer leaked so - some you win some you lose.
    Next project is a 12v outlet in the trailer for the 12v mini fridge for summer rides.
    2017 RTL
    2017 RTL , White
  7. #1332
    Jan 2019
    Deanna
    That would be hard - not being able to ride. So lucky here in Australia.
    2017 RTL
    2017 RTL , White
  8. #1333
    Vermont
    Quote Originally Posted by askitee View Post
    My Spyder goes into hibernation from Oct. to April, that is why I don't ride. ( Off topic: instead I take rides on my snowmobile).
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  9. #1334
    Jan 2019
    Deanna
    Now that would make up for it. Never seen a snowmobile in real life, is it as much fun to operate?
    2017 RTL
    2017 RTL , White
  10. #1335
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Just got my 7 x 12 tandem axle USA Cargo trailer and starting to install stuff. Made at the same plant as Rock Solid Cargo.
    Same construction, different name...
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
  11. #1336
    Vermont
    Between the Spyder riding season and the snowmobile season here in VT, I don't get much down time. Yes, the sled is fun to operate, the best way to describe the sled it's like a Spyder but on skis. I have the heated seat, handgrips/throttle, adjustable suspension (which I can adjust on the fly).
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #1337
    Sep 2015
    Mocksville,NC
    Quote Originally Posted by ES44AC View Post
    One more picture
    Lamonster Riser
  13. #1338
    Mar 2015
    forrest above Reno, Nv
    Woke the from its winter slumber. Placed a small heater on low for about 45 minutes to warm the oil. It started right up. Took a 45 min. ryde. Felt real good.
    2014 RTS , Circuit Yellow
  14. #1339
    Vermont
    Also woke up my from its long winter nap and got a VT. state inspected sticker on it.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  15. #1340
    Nov 2018
    Northern NV
    Installed the Adjustable Brake Rod that I got from Slingmods and the Mirror Lock kit from Lamonster Garage. Took the F3 on a short ride - both upgrades are outstanding!
    2017 F3T , Black, black and more black
  16. #1341
    Oct 2015
    Lynden, WA
    Received my "new to me" F3T. Slightly used at 5K miles.
    Rode 187 miles home. All is good.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  17. #1342
    Mar 2021
    Arizona high country
    Congrats. I have a 2018 F3L and love it, and I'm sure you will too.
  18. #1343
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Yesterday I installed the newly redesigned blinker button and paddle extender, with compliments to the forum user I purchased them from. I didn't get a chance to ride yesterday but I can already tell I'm going to like these newly added motifications.
    2021 RT Base - Petrol Blue
  19. #1344
    Mar 2015
    Quote Originally Posted by Haze View Post
    Well great Dave. Really glad to hear that you got what you wanted and it's hardly used. BattleBorn Spyders rydes again!!!!
    Lew L
  20. #1345
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Lew L View Post
    Lew L
    Peter Pan has struck again!
  21. #1346
    Durham,Maine
    Changed my oil, checked the fluids, tire pressure, aired up the air bag to my happy number, coolant check, cleaned the battery terminals, oiled all latches and locks, and cables, check brake pads. Now a good wash and shine and wait for the weather to break!
    2012 RTL , Pearl
  22. #1347
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    Not today, but Friday, I, with the help of my beautiful bride, installed Lamonster's 2" handlebar riser. Then, of course, took it for about 15 mile shakedown. Definately changes your riding posture, I think for the better. Positive so far (for that short ride). After this round of cold breaks, I'll have to put more miles on and make sure my initial thoughts hold.
    2022 Sea to Sky
  23. #1348
    Oct 2020
    TN
    Looks good buddy.
    An Old Ryder on a Spyder.
    2021 RT Limited Sea-to-Sky , Highland Green
  24. #1349
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Jesster72 View Post
    I installed the Lamonster riser on mine also. For me it works great.
  25. #1350
    Vermont
    Nothing, it is on a battery maintainer.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
