03-24-2023, 06:23 AM
#351
Originally Posted by Cobwebs
Washer, loctite/pulley, bolt, 24hour wait, ride.
Just so as everyone knows the loctite is to glue the pulley to the shaft it's not to glue the bolt in place.
Let the dealer do it to retain your legal status. If they allow you to ride off immediately and it fails any time in the future and kills you, they will be liable because they haven't followed loctite's cure time advice. None of them seem to be following this from what I'm reading here.
It's a long shot you say, the odds of the replacement sprocket failing would be huge. No one has been able to confirm if the metallurgy has changed or not so, if not, the repair is based solely on the loctite preventing the sprocket from fretting and doing the same thing again. In other words, a complete waste of time and effort by all involved if it doesn't get the required cure time.
Dealers get paid I think from memory something like 40 minutes labour from BRP to complete the task, they just want it in and out as quickly as possible, BRP just want to meet their legal obligations, you want to do your own research and stop relying on third parties to run your life and start considering bikerchris's approach to things.
I would hate to be the poor sucker to have to pull that sprocket off after all that has set up! Torches, seals and bearings don't play well together!
03-24-2023, 06:50 AM
#352
Mikey,
I believe the point of adding the washer behind the new sprocket is to minimize the heat transfer to the shaft seal and bearing should the new sprocket need to be heated to remove it at a later date! JMHO... Bill
10W40 Amsoil Synthetic Motorcycle oil
If in Doubt, Don't Do It!
03-24-2023, 07:11 AM
#353
Originally Posted by JKMSPYDER
In 2019 I had my pulley replaced by a dealer in NV with Loctite. No cure time was mentioned and I rode the Spyder to St George, UT immediately afterward. When I had the pulley replaced a month ago for the recall the pulley was still in good shape with no wear and no dust. After the replacement of the latest pulley and washer with Loctite by my dealer in NC I rode 2 1/2 hours back to my home. Neither dealer mentioned a period of cure time. I am certainly not disputing that cure time is necessary, but I think some dealers are not mentioning it or the Loctite being used requires no cure time. Thoughts?
Take the time to read the spec sheet that's put out by Loctite on the product.
Reason: ' ;-)
03-24-2023, 10:24 AM
#354
I wish that BRP would publish which type of loctite is being used, also other details such if an activator is being used (and which type).
I looked at the specs for both LOCTITE 603 and LOCTITE 609. Both show a cure time of at least 6 hours to achieve a 100% full strength on steel.
The gap between the two surfaces also make a difference for curing time.
Also the air temperature (in the shop and parts involved) can effect the cure time. Ideal temperature is above 40 degrees above 40 C.
The cure time can be shortened by using Activator SF 7649 or Activator SF 7471.
So if a dealer is allowing the Spyder to be used in less than 6 hours they might be using an activator.
Reason: spelling
Dean Secord AKA seaweed
Veteran: U.S. Air Force
2015 RT-S SE6
My Mods:
03-24-2023, 05:18 PM
#355
03-24-2023, 05:27 PM
#356
Originally Posted by T.P.
THE NEW REPLACEMENT SPROCKET IS SILVER
I have a copy of the Warranty Bulletin #2019-10 rev 1 September29,2022
Required parts, front sprocket kit, (includes washer)219800553 needed 1
listed as screw 250001017 needed 1
use loctite 609 or 603 torque to 111 lbf-ft +-4
No cure time listed.
CHECK THE NUMBERS ON YOUR DEALER PAPERWORK!
Way too much misinformation on this issue since the start of the problem,
We need everyone on the same page in the same book.
T.P.
Nothing in the warranty bulletin about any activator so they wouldn't be following BRP's script if they did use it .
https://www.bing.com/ck/a?!&&p=34089...MjBwc2ku&ntb=1
https://www.bing.com/ck/a?!&&p=c855b...zNTUxMS4&ntb=1
Cure times highlighted as 24 and 72 hours.
03-24-2023, 06:46 PM
#357
Cure time is also based on the cleanliness of the metal components. The loctite reacts with the metal causing it to set. Also note that it reacts differently with various metals. The three examples shown steel, galvanize and aluminum all have different cure rates.
Hopefully the tech is willing to spend a bit of time cleaning out the grooves in the shaft, I know mine is full of moly paste.
03-24-2023, 07:43 PM
#358
Originally Posted by Knizar
Mikey,
The washer is to act as a solid base on the output shaft to be able to seat the milled sprocket hub, to get rid of the sprocket wobble.
T.P.
03-24-2023, 08:25 PM
#359
T.P.
What ever the reason for adding the washer, hopefully the center hub of the sprocket will hold-up better with the new formulated loctite! I am wishful as everyone else that this is the "Final Fix", but we all know that only time and abuse will make this a fact. btw, Who came up with calling this the final fix? I don't believe it was BRP! .Bill
04-05-2023, 02:43 PM
#360
for those who have done the "Final fix" recall on the sprocket, have you had to pay anything? Even those "shop supplies" line items? Just planning ahead if dealership tries to make me pay even for the line item " shop supplies" I'll know how to react. With this Ridenow dealership my itemized list shows $156.99 and $14.99. Just would think those costs go to BRP along with any "shop supplies" charges
04-05-2023, 03:13 PM
#361
RideNow Austin did not charge me anything for the recall. You should not be paying for anything.
04-05-2023, 05:27 PM
#362
For a mandatory recall on any vehicle, you never have to pay anything. It is the law.
Peter Pan has struck again!
04-07-2023, 04:41 PM
#363
2015 RTL sprocket recall complete loctite 609 shop said no need to cure but took short ride home and will let it sit, took 2 hrs including tech aligning belt which was out of spec no charges
04-08-2023, 04:03 AM
#364
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
05-11-2023, 04:27 AM
#365
05-11-2023, 11:07 PM
#366
I had my "final solution" - and yes, it actually says that on the shop ticket - done two weeks ago. Fred Cummings Motorsports here in Bakersfield didn't ask me for any money. Took about 2 hours from arrival to departure.
“There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
2019 Spyder RT Limited - Asphalt Gray/Chrome
1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
Gone but not forgotten:
2014 Spyder ST SE5
Steel Black Metallic
05-12-2023, 08:55 AM
#367
"(the Spyder,not you) is quite acceptable". You can sit too, depending on if there's a game on and the state of your "honey do" list
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
05-14-2023, 05:57 AM
#368
Had mine done May the 10th. It was ready in about 1 hr, and I rode it home, which is about 1 hr. Then I went for a ride of about 500 km. Hope the glue worked.
Reason: Removed ' 's after words before punctuation... ;-)
05-14-2023, 08:03 AM
#369
I had the Sprocket Recall done this past Tuesday. An hour and 50 miles later, back at home I inspected the dealer's work. The belt tension was waaay tight and there was no gap between the belt and the driven sprocket's flange. See photos. I called the dealer's service manager and told him of my findings. He offered to make things right no charge. Being a DIYer (who I trust) I readjusted the tension and spacing, and all is well.
My suggestion is to check over what your dealer has done, or not done.
Reason: the the ;-)
05-23-2023, 08:51 PM
#370
Well, it took almost 1 year to have the recall done on my Spyder!
Original recall letter is dated 26 May 2022. The new sprocket was done today 23 May 2023. WOW lightning fast "Sarcasm".
I asked if they changed the setting on the belt (yep, they said, according to specs). I will have to readjust it now down to a lower setting.
When I got the paperwork for the completed job (the rep said that according to BRP the Loctite had to set for 2 hours). I said ok, and walked a short way to a hamburger place and killed some time (1 hour and 50 minutes close enough to 2 hours).
This cycle shop does not have much in the way of Spyders or Rykers. Only 6 new ones on the floor. I hope the tech is trained on Spyders.
I asked for pictures of the sprocket. They are shown below:
20230523_101306.jpg A little chewed up on the lower right side of pic
20230523_101315.jpg Again showing it a little chewed up on the lower right side of pic
20230523_101343.jpg This is interesting, a chunk of the outside of the sprocket is gone. I do not know what happened.
Reason: sort way... ;-)
2015 RT-S SE6
My Mods:
06-02-2023, 05:40 PM
#371
Called a couple dealers neither had a sprocket in stock had to order said it may be a month. Need more dealers, closest one is a 3-hr ride.
Reason: ' 's ;-)
06-15-2023, 10:03 PM
#372
I gave up last year on taking the Spyder in for sprocket recall because it sounded like they had no idea what they are doing! My appointment this year was today, for the heck of it I thought I would call first to make sure the new sprocket was in, because I have a long drive. Well, they checked and it wasn't there yet (imagine that!) The dealer said that normally they get a date but since the BRP hack they just have to wait for parts, my question: is this more BRP problems, usual dealer B.S. or both?
06-23-2023, 11:02 AM
#373
I checked the previously listed part numbers and verified they're accurate, but the problem is that I can't find anywhere you can purchase them. Plus, the Can Am parts website doesn't list it as available for purchase. So, I'm wondering if it's a dealer only part available as a recall item only.
(My bike is not part of the recall, but I would like to self-install it to ensure the latest and presumably best parts are installed.)
2020 RTL SE6
06-23-2023, 11:12 AM
#374
T.P.
#375
i have 39000 on my 21 with no problems wife has 22000 on hers i wouldnt worry so much
Tags for this Thread
