Results 1 to 6 of 6
    Mar 2023
    Mississippi
    Default Will a 2021 Sea to Sky fit in a 6x10 utility trailer?
    Will a 2021 sea to sky fit on a 6x 10 utility trailer?
    Last edited by Peter Aawen; 03-20-2023 at 10:35 PM. Reason: Expanded title to briefly ask the question... ;-)
    Feb 2012
    Spring City,Utah
    Barely but yes.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by Bamaboy View Post
    6 ft X 10 ft. is fine ....... The important measurement is the Width of the trailer opening .... good luck .... Mike
    Member narygancy's Avatar
    Jul 2022
    Pennsylvania
    And don't forget, the stated width of the trailer often doesn't factor in the wheel wells creating a bottleneck in the middle of the trailer. You may be able to back onto the trailer but then most of your weight will be on the back of the trailer and not on the tongue.
    2016 S6E , Red
    Mar 2008
    Hesston, PA
    Also make sure the trailer loading ramps are long enough so the front end of the Spyder doesn't catch when loading...larryd
    Quote Originally Posted by larryd View Post
    And don't forget that you'll need the belly of the Spyder to clear the angle of the ramp to trailer bed!
    Hit that & drag over it & you'll stand a good chance of bending/breaking the bracket holding the Reverse Gear Actuator, and once that's out of alignment it'll really ruin your day - well, mess it up at least until you either bend it back into alignment &/or replace it anyway!
