Results 1 to 6 of 6
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Cutting sheetmetal trailer skin - any ideas/suggestions?
    So as a follow up to my original post on this subject
    https://www.spyderlovers.com/forums/...tach-the-metal
    I am wondering if anyone has heard of a flush trim bit for a router or laminate trimmer that will do sheetmetal?
    Has anyone tried this, or have a better suggestion than cutting it by hand? Does anyone think a carbide bit for woodworking would work?
    Thank you all
    Mike
    Last edited by Peter Aawen; 03-04-2023 at 10:08 AM. Reason: Exposed hidden URL's iaw Forum policy to avoid trolls/spam/scams... & expanded title to briefly ask the question! ;-)
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Florida Swamp
    .046 X 4.5 cutting disk in 4.5 inch side grinder. Very thin and cuts a straight line. Any place that sells hardware has them.
    For sure wear a face shield. The really thin disks are easy to break.
    2019 F3-S , Black & Silver
    Quote Originally Posted by Gwolf View Post
    I also recommend an Angle Grider for doing this ..... I buy 1mm ( .040 ) disc's made by Diablo in bulk, H.D. also sells them .... I think this is the Thinnest disc made
    If you're going to be cutting lots of sheet metal, & you need to be able to cut around odd shapes as well as straight lines, you don't hafta rely on just disc cutters &/or angle grinders loaded with cutting discs, you can also get 'sheet metal nibblers' & 'sheet metal shears' - the nibblers do what they say, & chew/nibble a small section of metal out with each stroke, doing some hundreds or more strokes per minute; while the shears are heavier powered versions of what used to be called 'tin snips'.
    Here's a nibbler that I chose at random from the first search I did on them: https://www.bing.com/shop/productpag...ue&FORM=SHOPIC
    And a shear that I found easily the same way on amazon: https://www.amazon.com/DEWALT-DW890-..._t2_B011HX36GS
    They're not the nibblers or shears I own/use, but they're similar & I find them a lot quicker & more versatile than disc-based cutting, easier for cutting complex shapes, & safer all round too - but depending on the model/type of either that you get, you might lose a thin strip of metal with every cut.
    Personally, I wouldn't recommend cutting too much metal with a carbide bit (or any bit for that matter) that was designed for woodworking either - I reckon there's a whole bunch of reasons that they've been 'designed for woodworking' rather than 'designed for cutting sheet metal'
    Northern Kalifornia
    Peter! That's the only way to go for ease, accuracy, and safety.
    May 2020
    Rhode Island
    Ok ... thanks all!
