Results 1 to 20 of 20
    Active Member MarkN's Avatar
    Mar 2022
    Mio, Michigan
    Default Just a silly question - do all F3's have Cruise &/or BRP Go?
    Do all F3’s have cruise control and/or BRP Go?
    Last edited by Peter Aawen; 02-28-2023 at 06:17 PM. Reason: Expanded title to briefly ask the question... ;-)
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    2021 600 , Black/Yellow
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Quote Originally Posted by MarkN View Post
    No - depends on year and model. My 2016 F3L has cruise but not BRP Go.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Bossier LoUiSiAna
    New dash & Go ‘18 - current
    Mar 2022
    Mio, Michigan
    Thanks Guys. Really appreciate it.
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    I don't think any of the lower spec F3's come standard with Cruise - it's a feature of the F3-T's & Ltd's - but if you want to buy the appropriate handgrip/control module & plug it in, it's all there!
    and let me add that quite a few members here discovered that the wiring harness is there .....just add the control module ..... Mike .......right now I'm investigating if I can do this to my 14 Nissan Versa, the previous owner didn't buy that option ..... but I have found the steering wheel modules from salvage sellers for about $50.00 .... I need to find out if my basic model has the CLOCK SPRING that matches .... it's under the Air Bag ...... Mike
    Aug 2020
    Il
    Base F3's don't come std with cruise but its nice to know I can add it later.
    21 Spyder base F3
    Aug 2019
    Stoughton, WI
    F3-S models come standard with cruise control. I know my > 2019 do.
    2022 RT Sea To Sky
    Florida Swamp
    My 2019 F3-S came with cruise control. Not a standard model...... it is Special Series.
    2019 F3-S , Black & Silver
    Mar 2015
    Indianapolis, IN
    The only F3 Model that didn't come standard with Cruise was the was the Base Model.
    F3 - No cruise standard.
    F3S - Cruise
    F3T - Cruise
    F3L - Cruise
    All years apply above.
    In 2016 the F3L didn't come with a trunk. Starting in 2017 - all F3L came with a trunk.
    Oddly enough - in 2016 the F3T had the radio optional (only year the F3T didn't come standard with a radio).
    New Dash came out in 2018. F3T and F3L that are 2018 and newer have the new dash with BRP Go.
    F3S 2018 had the old dash - not sure on 2019 - but 2020 and newer have the new dash as well - but no speakers/etc - so it does have Bluetooth and BRP Go capable - but you have to connect your helmet to the bike to hear the info from the bike. To be honest - this seems a bit odd to me - I'm not sure why they bother - I would just bluetooth my phone directly to my helmet - but that's me.
    F3 base models even 2018 and newer I believe still don't have BRP Go.
    Hope that's helpful!
    Last edited by Jdr00ejr; 03-02-2023 at 11:17 AM. Reason: Updated F3S info on dash.
    Joshua
    2016 Spyder F3S
    2019 Spyder RT Limited
    2022 Ryker Rally
    2016 F3S , Triple Black
    Aug 2013
    SF Bay Area
    The Base and S 2018 and newer models do not have BRP Go nor do they have CC. The earlier models same but LCD dash. Base and S models are pretty much basic models.
    Specials, limited and touring models come with CC and 2018 & newer have the smartphone integrated dash.
    2021 F3 Ltd , Magna Red
    Mar 2015
    Indianapolis, IN
    Not sure what you are basing your info on - but the F3S (Sport Model) does come with Cruise Control (all years). I was incorrect in my post above (editing next) though - in that there was at last 1 year maybe 2 - (2018 for sure) when the new dash was in the F3T and F3L but not the F3S but by 2020 the F3S also got the new dash with BRP Go though it doesn't have speakers - you can connect your helmet bluetooth to the bike.
    Joshua
    2016 Spyder F3S
    2022 Ryker Rally
    Aug 2020
    Il
    Quote Originally Posted by Jdr00ejr View Post
    Correct. My 21 base F3 has the Ryker style screen, no CC nor BRP go and has the smaller sprocket.
    21 Spyder base F3
    Mar 2021
    Maryland
    Nothing has to be done with buds to activate it?
    2020 F3 SE6
    2020 F3 , Black
    Quote Originally Posted by CloverHillCrawler View Post
    Those I've seen/done here in Oz have been a fairly simple 'replace the original handgrip with an upgrade handgrip that has the Cruise Control button on it, plugging all the wiring in when you do so' type job, (you might need to clip a zip tie or two to get sufficient wiring loom length to do the 'remove/replace' bit ) and then since the upgrade handgrip has the Cruise Control button on it, it'll operate as tho it was there from the beginning! I can't remember doing anything else, certainly not anything involving BUDS.
    Nov 2016
    saint cloud,florida
    My 2015 F3S came standard with Cruise Control.
    2015 F3S
    2022 Suzuki Hayabusa
    2022 Kawaski KLX300
    Apr 2023
    Seattle Washington
    My 2020 Spyder F3S comes with Cruise Control but not BRP Go. I wish that the RPM and Temp could be seen on the dash together rather than just pick one...
    2020 BLACK SPYDER F3S
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    TUFSKINZ TANK PROTECTOR CARBON FIBER
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    SENA 10C PRO BLUETOOTH
    ALPINESTARS JACKET
    SCORPION EXO ST 1400 CARBON HELMET
    Apr 2023
    Seattle Washington
    My 2020 F3S came with Cruise Control but no BRP Go...
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    ALPINESTARS JACKET
    Quote Originally Posted by alexf415 View Post
    That's an awful stutter you've got there alex, pretty much a whole week between the repeats!!
    I guess it's another reason that it always pays to check the first post in a thread, AND the last few posts before replying too - and clearly, not just for the dates!!
    Houston
    All F3S models have cruise control. ONLY the base model does not.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
