Results 1 to 14 of 14
    Jul 2019
    Georgia
    Unhappy Control panel all lit up! Help?
    2014 ST limited She stopped shifting and her dash lit up like a Christmas tree. Short story to a six month problem. I was told she needed a new clutch. Got it done. Dash is still lit up and now they say its the centrifugal clutch ass'y, module electronic box, and engine wiring harness plus 17 hours of labor....HELP. I have kept her maintained though she has almost 50,000 miles on her. Most of which were put on within the last three and a half years. Thanks for any input....Desperate to ryde.
    Spydermom19@gmail.com
    Last edited by Peter Aawen; 02-25-2023 at 05:23 PM. Reason: Expanded title to briefly ask the question... ;-)
    How old is the battery?
    Bossier LoUiSiAna
    Agree possibly battery. Fully disconnect; load test batt; Deep cycle charge; clean connections & reattach.
    Jul 2019
    Georgia
    Battery is less than three years old. She never sat idle in my care, however, she sat idle at the shop for at least 2 months. I will suggest a new battery. Thank you.
    Quote Originally Posted by Spydermom View Post
    Before you do that put a charger on it for a little while, or try jump starting it. The battery may be recoverable.
    Durham,Maine
    I would load test it first, will not cost you a thing!!!
    2012 RTL , Pearl
    with the other posters... check the connections of your battery ( and ADD STAR washers ), and have it tested..... from what you said I have serious concerns that Dealer Tech is GUESSING as to what your problem and maybe clueless ..... good luck .... Mike
    Jul 2019
    Georgia
    Thanks for your help all. Unfortunately, she is at the garage. I'll be calling them tomorrow. I connected my trickle charger when I first got her back. She came home for about a week. Rode her, same dash lights. Then it rained for three days. I charged her before I took her back to the garage. Does anyone know a good Spyder mechanic near southeast GA?
    Another card on the pile for a battery check. That is what it sounds like to me.
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    How they were able to determine all of this now after missing it entirely earlier is a mystery. It’s very hard to justify or explain why each of these items need replacing now all at the same time. I wonder what their answer was as to why and how this happened and how it was originally missed but now so apparent? What is their evidence of diagnosis?
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Shoei Neotec 3
    Cardo Packtalk Edge Duo
    Spyderco Paramilitary 2
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
    For it to be meaningful a load test needs to be done with the battery fully charged.
    Two months without a maintainer connected is long enough for the phantom loads to drain the battery, especially if it is starting to get weak. That could easily be the case for a 3 year old battery.
    Jul 2019
    Georgia
    Thanks all. She had a new battery and that's when all the other codes came up. The tech thinks that something has chewed my internal wiring and that's what's causing the added codes. The only thing to do is take her apart, supposedly.
    That will definitely do it. Lift the seat and take the inspection cover off. Get a flashlight and look around in there where you can see. It may be where you can see it. Also look for chewed into insulation, etc., if you cannot see a nest. If not, and this is suspected. Parts will have to start coming off. This is an issue more common that people realize.
Tags for this Thread
