Results 1 to 25 of 25
    Very Active Member Dochands's Avatar
    Aug 2009
    Oklahoma
    Default Your thoughts on using a Tackform Center mount?
    After playing with BRP Go in the garage I can see it is a bit quirky for my taste. I decided to mount my iPhone and go back to that navigation and music and the best I have found seems to be the Tackform Center Mount. I think the Short Reach but that is not clear since the bike is so new to me. The other reason is with a Ruroc helmet Siri works so that makes it handsfree.
    Thoughts appreciated.
    Last edited by Peter Aawen; 01-27-2023 at 05:47 PM. Reason: Expanded title to briefly ask the question... ;-)
    2022 RT Limited , Carbon black
    indpls in
    wife and i have them very secure love them
    Northern Kalifornia
    I have the same setup. Excellent choice.
    Dec 2020
    Hartwell, Ga
    I also have one with the short arm. It works great.
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    Here is my setup. I'm very pleased with the TackForm mount. Actually purchased one for my 2 wheeler as well.
    2020 RT Limited - Chalk Metallic Dark
    Jun 2015
    Ritzville, Wa
    I have my TracForm mounted on my Spyder Cuff from Lamonster Garage. Works great for me.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Aug 2009
    Oklahoma
    What’s a Spyder Cuff?
    Dec 2020
    Hartwell, Ga
    Not knowing what Spyder you have I just picked one, if you go this route get one for your spyder.
    https://www.lamonstergarage.com/can-...uff-cuff-only/
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Dochands View Post
    The Tackform was my first choice also, BUT my S20FE with defender case was too THICK to fit! So I found this BRCOVAN Aluminum Alloy for motorcycles on Amazon. It has an anti vibration feature. $79.99 Bill
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
    Aug 2020
    Il
    Love my Tackform short reach center mount for my F3. I have an Android A32 in a Otterbox Defender case and fits just fine. Its rock solid.
    21 Spyder base F3
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Knizar View Post
    My S20+ with the Otterbox Defender fits great in my Tackform
    Linden, CA
    The Tackform mount is by far the best strongest safest one on the market hands down.
    I stock the full line even the magnetic one for your car. EVERY THING I sell is at DISCOUNT PRICE
    Feb 2020
    Minnesota,USA
    When reading specs on the Tackform it stated only good for .5" thickness & my otterbox defender is 5/8"+.
    I'm in need of a second phone holder so I will likely order the Tackform. Can always return if it doesn't fit.
    Thanks K80 for that info! Bill
    Oct 2021
    Wichita, KS
    Quote Originally Posted by gkamer View Post
    Same here except I use the Phone Phang from LaMonster. Functionally equivalent to the Tackform. The Spyder Cuff is the way to go with a drink holder on back.
    Peter Pan has struck again!
    Nov 2022
    North Carolina
    I put the short reach on my 2018 F3L. Used the lower right side bolt and turned the i phone horizontally. Doesn't block my view of signal or gear indicators. Two thumbs up!!
    2018 F3 Limited
    Aug 2009
    Oklahoma
    Quote Originally Posted by cjr00 View Post
    I’m glad you mentioned the lower holes. I wasn’t sure. However Murphy’s Law is at work. Buy a new bike invoke a week long ice storm.
    Dec 2020
    Hartwell, Ga
    I mounted mine in the top right hole so I guess it's just whatever you prefer. I can still see everything that I need to.
    Aug 2009
    Oklahoma
    Now that the ice is almost melted I will install it today. And perhaps clear enough space to get this big bike in the garage. Lol
    Aug 2009
    Oklahoma
    Frustrated to find the hex bolt on the RT is a different size than that for the Tackform. Apparently, I don’t have that size and will have to order it. Could someone be so kind as to tell me the bolt size is on the RT?
    Clinton, MS
    First we would have to guess at what RT you have.
    2019 RTL Phoenix Orange
    Dec 2020
    Hartwell, Ga
    Frustrated to find the hex bolt on the Rt is a different size then For the Tackform. Apparently I don’t have that size and will have to order it. Could someone be so kind as to tell me the bolt size on the RT?
    I just realized that all the info that I posted was not what you were looking for, so I replaced it with this. I thought you were wanting a bolt, but you were looking for wrench size.
    Carry on.
    Aug 2009
    Oklahoma
    My bad. I thought I had added my bike in my profile. Nvm though I find the right hex to remove the OEM bolt. Thanks.
    Faribault, MN
    Dochands, It REALLY helps if you add your Spyder details in your Signature block, then when you post a question, everyone can see which Spyder you're referring to.
    I have the TacForm mount mounted over my dash from a Spyderbar on my '13 and now my '18 RTL. I like the landscape view for mapping and don't have to look down at my handlebars.
    Last edited by Peter Aawen; 02-05-2023 at 08:11 PM. Reason: Fixed attach display ;-)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2009
    Oklahoma
    Read my post above. I thought I had. Not sure why it’s not showing.
    I just checked your profile, and you didn't have anything in the Signature Box itself, just in the 'Current Transportation' box - so I've added that info to your Signature Line, but it seems you don't have the 'Display Signature with Every Post' box checked somewhere, cos it still isn't showing....
    Try clicking on 'Settings' up in the top right corner of the page & check/edit your Signature as necessary, then make sure you've checked any/all of the 'Show Signature' boxes on your profile; then back right out of the Forum before logging back in - that should reset everything & with any luck it'll show then. If not, you could try clearing your cookies & history, but it'd probably help more if you drop me a PM so I can have a bit more of a look.... I will shortly be off the Forum for the next four hours or so, but will be back on after that... Good Luck!
