What was BRP Thinking on the 2022 models and placement of the brake pedal?
I had my 2015 RT Limited in the shop today to get my replacement sprocket put on and a oil change. I sat on a 2022 RT-S in the showroom. My height is only 5'2" and my inseam is 24". Good grief....I can't be the only short operator out there, but my foot could NOT reach the brake pedal at all. The parts guy looked for a "Riser" and couldn't find one, but if BRP wants people to continue to purchase their SPYDERS they are going to have to make them conducive for ALL consumers, short and tall.
My 2015 I added a hand-brake lever, but hardly use it and I have NO issues with the brake pedal on the 2015.
So BRP designers or engineers really blew it on this new RT!
Anyone else out there experience this issue and if so, what work arounds did you find?
Brakes are the most important thing on any vehicle.
Thanks!
Reason: read - reach ;-)
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned! ![](signaturepics/sigpic10868_1.gif)
Well, in my view, the engineers didn't blow it. They went to the middle range in height, whatever that is, maybe 5'8"?. If they made the seat/handlebars/brake pedal/SM shifter to fit the low end of the height scale, then midrange 5'8" riders would feel slightly cramped, and the really tall riders would REALLY be cramped. This goes for ALL kinds of motorcycles, they go to the midrange of ergos. I feel for the shorter riders, but I'm 6'1" so I don't have a problem. Some of the lady riders will have that fit problem.
Reason: Caps & ' 's ;-)
![](https://www.spyderlovers.com/forums/maps/map.png?states=NC.CO.ID.MT.WY.SD.KS.UT.MO.NE.IA.IL.TN.SC.KY.VA.WV.PA.NY.ME.NH.VT.MA.CT.NJ.MD.DE)
![Quote](images/misc/quote_icon.png) Originally Posted by Elembytes
I had my 2015 RT Limited in the shop today to get my replacement sprocket put on and a oil change. I sat on a 2022 RT-S in the showroom. My height is only 5'2" and my inseam is 24". Good grief....I can't be the only short operator out there, but my foot could NOT read the brake pedal at all. The parts guy looked for a "Riser" and couldn't find one, but if BRP wants people to continue to purchase their SPYDERS they are going to have to make them conducive for ALL consumers, short and tall.
My 2015 I added a hand-brake lever on but hardly use it and I have NO issues with the brake pedal on the 2015.
So BRP designers or engineers, really blew it on this new RT!
Anyone else out there experience this issue and if so, what work around did you do?
Thanks! ![wink](images/smilies/icon_wink.gif)
Lamonster has floorboard risers that you can install and a brake pedal riser you can also install that will help with that issue. https://www.lamonstergarage.com/brake-riser/ and https://www.lamonstergarage.com/can-...20-to-current/
My Spyder ![](signaturepics/sigpic32694_1.gif)
I use a brake pedal riser and a handle bar riser. Works good I am short too I ride a 2021 RTL
It’s one of the reason I went with an F3 Ltd. I’m 5’1” with boots on and a 26” inseam and I had the same problem. After trying out a 2018 RT I found the ride height made it difficult for me to corner without slowing down. Even knowing the bike won’t roll, I just couldn’t feel comfortable cornering. The F3 is so much nicer due to the lower center of gravity.
![Quote](images/misc/quote_icon.png) Originally Posted by Woodaddict
... ALL mass produced veh's are designed to fit the MAJORITY of possible users - ie. MOST short, medium, and tall/large people. ... What if BRP or any other company ONLY produced veh's to fit "little people" instead (ie. midgets & dwarves) instead of all those others? .... How many veh's would get sold ??????? ... I have complained about many things that BRP engineers do and have done for over a decade. .... But I don't see this one as a reasonable complaint ..... JMHO ..... Mike
Reason: ' 's + ... ;-)
I was in our local dealership Saturday and had pretty much the same experience. Don't you know engineers walk on water and you should not question their designs--that's according to them anyway.
![](signaturepics/sigpic17779_1.gif)
Those who say " I can't" will always be right.
Short legs.
I replaced my 2016 RT for a new 2021 S2S, the deal was done over email as the dealer is over 180 miles away. When I went to collect the bike I was not able to get on due to short legs and bad hips even though I had no trouble in the 5 years I had the RT. The solution was to make up 5in risers for the floorboards but only raise the brake pedal by 2in. This has proved perfect with no problems.
………. but if BRP wants people to continue to purchase their SPYDERS they are going to have to make them conducive for ALL consumers, short and tall.
Elembytes, I don’t believe that BRP “blew it”, by not making the new RT to fit really short people. That’s a bit self centred.
At 6’7”, I am at the opposite end of the spectrum to you, and the design on the new RT is not conducive to very tall people either, not without modifications. So, I did some research and bought a custom seat to lift me a couple of inches, lowered the brake pedal, bought some new bars, and a new screen. I know that there are brake, bars, and floorboard risers made for shorter people. The options are out there for both ends of the spectrum.
As Mike said earlier, manufacturers HAVE to cater to the high percentage of their potential buyers, and that is neither you nor me. It would be financial suicide to do otherwise. There’s a video around of some builders modifying a Spyder for someone who is only 4’ tall. Unfortunately, added expense for tall/short people just goes with the territory.
Reason: ,'s ;-)
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
everything is based off the average adult male 5-9/ 190'ish pounds 40 inch waist
the brake pedal angle is absolutely horrific.
I'm 5' 7" with a 30" inseam. I noticed the same thing when I sat on a 2021 RT. I had to scoot forward in the seat a bit to comfortably touch the pedal.
![Quote](images/misc/quote_icon.png) Originally Posted by Flier Tuck
Thanks, I am wondering if that riser is good enough to help me out. I was very surprised how far away that pedal was. Not like my 2015 at all.
Reason: Fixed quote display... ;-)
![Quote](images/misc/quote_icon.png) Originally Posted by Peteoz
Thank you for your reply. 6'7" wow must be nice! My wife is 5'10"- go figure that one out! LOL! I looked at the risers from Lamonster and they seem to help. It was nice to hear from Lamont himself say that they really didn't make it for short riders. So I am glad he's got some work arounds!
![Quote](images/misc/quote_icon.png) Originally Posted by Fat Baxter
I was scooted as far forward as possible and still couldn't even reach the pedal without really over extending my right leg. As I mentioned before, my 2011 and my 2015 RT's never were an issue with the brake pedals at all.
Well, I'm 6'3" and I find the brake pedal too close. I have a hard time braking when the bars are turned left because they hit my knee. I've seen brake pedal risers on one or two aftermarket sites for the vertically-challenged riders, but there's nothing I can do to move it further away for me.
Scott (slhanks004)
Gilbert, AZ USA
2022 Spyder RT Limited - Carbon Black
- Pedal commander
- Baja Ron sway bar
- TricLED tail lights
- TricLED driving lights
- Corbin seat
- BRP rider backrest
- Lamonster topcuff (2) w/ RAM mounts
- 12v/USB docking station
- Garmin Zumo XT
- RLS cat delete pipe
- IPS highway pegs
- IPS belt tensioner
![Quote](images/misc/quote_icon.png) Originally Posted by slhanks004
See post #9 above for some ideas.
Drop “SLICE’ a pm, Scott. He found a lowered rod on one of the 3rd party sites that he has installed for exactly that issue. The only reason I haven’t bought one is that my current solution of removing the stock thick brake rubber pad and replacing it with a 1mm thick rubber pad has effected the same resolution……but I also have a custom Daylong seat that has lifted me 2”….![wink](images/smilies/icon_wink.gif)
HeliBars Handlebars
Kenda Kanine rear.
I am just 6 foot but have a 34 inch inseam and find the RT a bit cramped. I suspect there are just as many tall folks with issues as the OP and others who are vertically challenged.
If BRP made the bike for 26 inch inseam riders it would eliminate many of us as potential customers.
2021 Spyder RT Limited (Palm Desert)
Grey - dark edition
2015 Spyder F3 S (Vancouver)
2017 Yamaha V Star 1300 Tourer
![Quote](images/misc/quote_icon.png) Originally Posted by PeterKelly
And if they made them for those 6' and more, they would eliminate just as many. I'm 5'4" with a 27" inseam an sat on a '22 model about a week ago. I had to move all the way forward until the boys were uncomfortable in order to just barely use the brake pedal. I would definitely have to make all of the above-mentioned mods for the vertically challenged before I could ride one safely seeing as how your brakes are one of the primary safety features of any vehicle. Personal opinion is they should have made a horizontal adjustment in the brake pedal position. If engineers are as smart as they think they are, that should have been a simple no-brainer for them.
Our 2022 RTL fits me perfect, But I do agree there should have been some adjustability built into these and it could have been done very easily.
you need this, it has saved me from selling the spyder........SERIOUSLY!!!
https://www.youtube.com/watch?v=fSF_...SLICEofAmerica
![Quote](images/misc/quote_icon.png) Originally Posted by Rick28
There was obviously some thought put in to brake pedal positioning by BRP engineers, Rick, as they deliberately removed some teeth from the sprocket so the brake position could not be clocked forward. I guess they were worried that customers would clock the pedal so far down that it would render the brake ineffective.![don't know](images/smilies/shrug.gif)
HeliBars Handlebars
Kenda Kanine rear.
