For What YEAR Spyder RT, Oh and for the Australian version not the US/North American version?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Ozzie Ozzie Ozzie
I thought he was on about a fog light. Guess my Strine could do with some work.
Yeah I know its hard to know what the fog lights look like???????
Next time Ill post a photo
Oh???? and I think their all Canadian Vesions But probably wrong
And figured out how to do it
Just what are you trying to do? Change bulbs, or remove them all together?
Ozzie Ozzie Ozzie
They might all be made in Canada Kooler, but there are different Standard fit-outs depending on where they're going.
The 2010-2019 Australian/European Spec RT's didn't get Fog Lights at all, we got Lo Beam lights only in the Lower light Assy up front, with Hi Beam only in the Upper Light Assy; while US/Canadian Spec RT's have blank inserts down there in the Base model versions, with both Hi & Lo Beams provided via a single filament globe with Hi/Lo selected via a shutter arrangement in the Upper Light Assy, and with those Fog Lights available only as an option; but then the Fog Lights did come as standard fittings on the US/Can Spec higher level S, T, & Ltd models as Fog lights with a Fog Light selector switch included in the dash panel below the steering shaft.
And the Fog Light configuration & model applications all changed again with the release of the 2020 RT's!!
But clearly, they aren't really all Canadian versions at all, just some of them, and if yours was initially purchased in Australia, it didn't come from the factory with Fog lights at all.
So Peter, what your saying iis down under they have the housing, but no bulbs in there?? Because in that picture the clear housing is there!
Ozzie Ozzie Ozzie
Can I please have some information on how to remove the fog Light with heaps of really good Pictures, and all the info on how to:
Remove Bolts?
Remove fasteners?
Remove panels?
Thank you
This is the type of project where you would be well served, and find the answers you need, by shelling out about $30 for a service manual and referring to it. www.canammanuals.com. Be mindful of the fact that the effort required by a member here to compile an answer for you has already been accomplished by the manual writers.
I reckon the smart money would be on ignoring this bloke and his whizzbang questions. He has gone dark and so cant be helped.
