Results 1 to 13 of 13
    Jun 2021
    Washington
    Default Installing 2020/2021 Spyder RTL backrest from Can-Am?
    Have any 20/21 Spyder RT Limited owners self-installed the adjustable driver backrest from Can-Am? I'm not too mechanical but it looks like it should be fairly easy. However the online instructions are vague and unintelligible - so I'm wondering whether you have any tips for the install?
    Jul 2015
    Dorr, michigan
    VERY easy to install, I love it.
    2020 RT Limited , Petrol Blue
    Jan 2021
    Oklahoma City
    I agree the instructions are not very good for my non-spatial brain, I need words to go along with pictures.
    However, the install is easy, the one thing I had to fiddle with to get it right was which side of the retaining wire thing-a-majig faced up but I figured it out so no doubt you will too. It's easy, go for it!
    Aug 2016
    South Wales UK
    Something I did to mine may help. I placed a loop of strong material, 1in webbing in my case, around the wire retainer. It makes it so much easier to remove at any time.
    Alan
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    If this is the one you got, here's the install.
    https://youtu.be/02xASx27tq4
    Member MS JETSON's Avatar
    Jun 2014
    LENNOX, SD
    It's very easy; takes about 10 minutes!
    Ms Jetson
    2021 Spyder RT Limited Chaulk/Dark
    Farkles:
    Drivers Backrest, K.O.T.T. Grills, Lamonster Handlebar riser
    Past rides; 2007 Lehman Jackal, 2014 Spyder RTS
    Flatlands of South Dakota
    Lennox,SD
    2014 RT , Congac
    Jan 2021
    Oklahoma City
    Quote Originally Posted by Flier Tuck View Post
    Alan
    Good idea
    Jan 2021
    Oklahoma City
    Quote Originally Posted by Quickdraw View Post
    The OP ask about the CanAm backrest from BRP. Your link is for a Show Chrome backrest which does not have the wire retainer like the BRP backrest.
    Member Navigator's Avatar
    Dec 2020
    Maryland
    Default Bracket and Panel Nut not Aligned
    I found this thread and feel like an idiot. I have a 2021 RTL and the OEM back rest. The bracket that holds the back rest in places, does not line up with the panel nut so that the bolt will fit in place. It seems the bolts only wants to go straight down, but the panel nut is at an angle.
    It seems easy enough and I agree it should take about 10 minutes and yet ... here I am. Can anyone provide some advice or direction to assist in getting this installed?
    2021 Spyder RT Limited Deep Marsala Metallic
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Navigator View Post
    Do you have the bracket upside down? Mine installed no problem.
    2021 RT Limited Asphalt Gray
    Halo Skid
    Driver's backrest
    2" riser w/ F3 standard handlebars
    F4 vented 25" windshield
    Member AZ4U2C's Avatar
    Nov 2021
    Arizona
    Push the bracket down firmly into the slot until it SNAPS into place. Then the bolt should easily fit into the nut.
    I just did this install for my 2022 RT yesterday. (Thank you, Brentc!)
    d.i.
    2022 Spyder RTL – MCRN TACHI
    Active Member USAF's Avatar
    Aug 2022
    NY
    Quote Originally Posted by AZ4U2C View Post
    d.i.
    Can the BRP backrest easily be removed on the fly ?
    2022 Spyder RTL
    Nov 2021
    Arizona
    Quote Originally Posted by Rick28 View Post
    Yes, it can easily be removed.
    Just lift the driver seat, pull the locking pin forward to release the backrest and then lift the backrest out of the slot.
