09-17-2022, 11:26 PM
#976
Originally Posted by Tmac4Life
I am starting to receive the "Dess" key error. Sometimes the bike will start immediately and other times I may have to wait 10 minutes. Any suggestions on how to I fix this? I don't want this to happen and I'm on a road trip and can't get back home.
I sent you a PM ..... hope you get it ..... Mike
09-18-2022, 11:00 AM
#977
Tmac4Life,
The info I posted early on this thread might help you, especially if you read the first few pages here...
What year is your spyder?
What spyder model do you have?
Would you post what DESS model you are using so other spyder owners and I know.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
09-18-2022, 08:55 PM
#978
Well now our 20 RTL is having intermittent Check Key issues. Saw it once last week when I turned the ignition on at Spyderquest to show a customer lights. Now tonight it came on when we were out and stopped. Messed around with it for a few minutes and it reset. Came back on when we put it back in the shop and would not reset for a couple of hours. We are supposed to have the bike down in Maggie Valley for our 20+ demo bike in 2 weeks.
Looks like I just need it turned off.
09-19-2022, 03:15 PM
#979
Hi rick_w,
What did you do to reset it ?
Are you going to have some turn off the DESS?
Keep us posted!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
09-20-2022, 02:28 PM
#980
Originally Posted by Deanna777
Hi rick_w,
Keep us posted!
Deanna
It would not reset by turning ignition off and on 4 or 5 times. After a few hours it did reset on its own. The Check Key does not come on now, bike has just been sitting though. I am pretty sure if you rode it the Check Key would come back. I would not trust it at all like this.
We are busy through Sunday, so taking it down to Lamont on Monday to have it turned off and go over a couple other items before Maggie Valley.
09-20-2022, 03:44 PM
#981
rick_w,
Question,
Was there any electronic equipment( keys, cellphones) or any other devices next to the spyder keys?
That is a good thing that the Check Key doesn't come on now. I would not trust it either.
Have you tried the other spyder key?
Interesting info.
OK.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
09-21-2022, 11:33 AM
#982
rick_w,
Question,
Interesting info.
OK.
Deanna
For reference information. There are no type of cell phones or anything close to it and when it was locked out with the check key the other key we have for it would not work either.
09-21-2022, 03:24 PM
#983
OK. Thanks for the info.
Here are my thoughts: Sounds like a chip problem in both keys.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
09-22-2022, 07:23 AM
#984
Deanna
While not impossible, the likelihood of two failed keys vs a failing DESS system seems very, very unlikely.
Suspect Lamonster will get Ricks Spyder sorted out with minimal fuss by disabling the DESS.
09-22-2022, 08:50 AM
#985
You are right, not the keys. The spare key has never been used and will work right now. We are just getting it turned off.
I think we will see more of these failures on the newer bikes sooner or later.
We have talked to a few customers over the years that have had absolute nightmares because of this issue and being stuck places.
09-22-2022, 09:42 AM
#986
Agreed.
I disabled DESS on our 2014 awhile ago.
Since I have BUDS and BUDS2, I offered locally to disable DESS for a reasonable cost. Simply wanting to break even on license costs. Much to my surprise, no one took me up on it. If DESS fails or acts up locally, or while traveling, it will be far more costly, but whatever.
Yes, disable DESS and don’t look back.
09-22-2022, 12:31 PM
#987
In 2015 when I had my 2nd DESS module and 2nd antenna replaced since then I have not had the DESS error show up.
I have a 2014 RTS-SE6.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
10-08-2022, 01:50 PM
#988
The only reliable fix for this DESS Check Key Error is to disable the DESS in BUDS by dealer. We had this problem with our 2020 F3 SE6 Limited. Dealer replaced the DESS and the antenna, but the problem returned. After the third time trailering the bike to the dealer, we requested that they disable the DESS, which is a redundant security system anyway. This solved the problem. It is unconscionable that a company with the resources and expertise of BRP cannot get this right.
10-08-2022, 02:26 PM
#989
daveschulz,
What is the part number of the DESS?
Also, what is the antenna part number?
The above info is for other spyder owners.
BRP needs to get a grip on this, and get it fixed ASAP!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
10-08-2022, 02:39 PM
#990
710004916 DESS Module - $229.49
219800373 DESS Antenna - $72.41
I agree, it is unbelievable that BRP has been unable to deal with this properly. Given the DESS is a redundant anti-theft system we decided to disable it. This should not be the only reliable solution.
10-08-2022, 02:49 PM
#991
daveschulz,
Before you had the DESS disabled did you have the dealership open a case with BRP?
The DESS module and the Antenna is under MFG and the B.E.S.T warranty.
There has to be a better reliable solution to this DESS Problem.
Thanks for the part numbers.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
10-08-2022, 03:04 PM
#992
Yes they opened a case with BRP and the module and antenna were replaced under warranty. The problem still happened again. I just want to be able to ride without worrying about getting stuck somewhere. This system is clearly designed and/or manufactured poorly and I have completely lost confidence in BRPs ability to address it with a reliable solution. The sheer volume of reported cases similar to mine on various forums proves that. There should be a complete redesign of the unit and a factory recall to get them all replaced, in my opinion. At this point to have the same faulty design replaced with the same flawed unit again makes no sense.
10-17-2022, 05:59 PM
#993
Hello all, I just installed a new DESS module in my wife's 14 ST Limited. I was under the impression that there was a procedure to make the new module recognize the 2 keys? I installed the module and was ready to go through the process and it seems to have just automatically recognize both keys. Is that normal now? Thanks.
10-17-2022, 07:04 PM
#994
The key recognition is performed in the ECU, the engine control module. The DESS simply communicates with the key to verify a valid key ID format, and sends the key ID to the ECU which then compares it to the list of authorized IDs that is programmed into the ECU. Since you did not change key IDs or reprogram the key list in the ECU, you were good to go!
10-17-2022, 07:38 PM
#995
daveschulz,
Yes, BRP should do a complete redesign and a recall.
I have a 2014 RTS-SE6 and I had the DESS problem happen to me twice (as I posted in this thread). Since I have had my 2nd DESS module and antenna/switch replaced (both times were under warranty) I have not had the DESS problem (and my bike is now out of warranty).
I am glad that your dealership opened up a case with BRP.
What year is your Spyder?
What Spyder model do you have?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
10-17-2022, 07:44 PM
#996
GearHd,
I haven't heard about the new module and recognizing the 2 new keys.
I don't know if that is normal.
Will someone chime in that has had the new module and 2 new keys installed on there spyder.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
10-17-2022, 08:25 PM
#997
10-17-2022, 09:10 PM
#998
From the 2014 service manual.
10-18-2022, 05:29 AM
#999
GearHd,
Deanna
This is what I get in my service manual. Sorry for the sideways picture.
10-18-2022, 05:39 AM
#1000
Also, one odd thing I noticed on the old original module was it had something that looked like a cylindrical magnet zip tied to it that a couple of the wires looped through it. That just looked like a major afterthought to me.
