Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
  1. #26
    Danbury Connecticut
    I'm coming into this thread late.
    Here's what I have on my 2020 RT Limited.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    IBA #47122
    2020 RT Limited Asphalt Grey
  2. #27
    Apr 2012
    Florida
    Quote Originally Posted by Excoastie View Post
    I have been on the search for mirrors that are less than two inches. Not much of a choice out there.
    I found these on Amazon, but not sure of the quality.
    --Exco
    WallyWorld mirrors are good quality ones. Tom
    2020 Petrol Blue Metallic RTL
  3. #28
    Harrington, Australia
    Gotta say - . I put mine in the inside lower corner of each mirror, so that if needs must, I can quickly spin them so that I can see exactly where my rear tire is going; but for general use, they are aimed out so that with both I can effectively see the 180 degress behind me - well, except for the bit that either my pillion passenger or I block, but a bit of head movement can usually fix that! .
    Interesting, Peter. I actually put mine on the inside upper corner. That top part of the stock mirror is obscured by my arm/elbow anyway. That lets me use my stock mirror to see below my elbow for traffic directly behind me, leaves the rest of the stock mirror free and the convex mirror gives me wide angle beside me. Horses for courses
    HeliBars Handlebars
    Kenda Kanine rear.
  4. #29
    Sep 2014
    USA
    I like these alot and found the glass version is way better than the cheap versions.
    https://electricalconnection.com/ind...r-micro-glass/
  5. #30
    Aug 2020
    Il
    Can you post a pic of your setup with these?
  6. #31
    Yeah, I have the stock mirrors aimed out & back so that I don't see any of me & just the barest smidge of the top/rear of the panniers (on the RT ) - and that barest smidge is the bit I generally cover with the rotating wide vue mirrors.... but I suspect your size may have somewhat more 'blocking effect' than mine?!
    Besides, I only ever qualified as 6ft tall and 'built' in my 'young, fit, & bullet-proof' days, and a whole lot of damage, compression type injuries, & shoulder surgeries since then means that I'm a tad shorter'n less imposing these days. . Shorter, heavier round the waist, slower, not as fit.... geez, they weren't kidding when they said 'the older you get the better you waz'!!
  7. #32
    Danbury Connecticut
    IBA #47122
  8. #33
    Sep 2020
    Ohio
    ...... I actually put mine on the inside upper corner. ........
    I'm glad you said that, because I was going to ask if anyone had ever placed on in the inside upper corner.
    I have the swivel, rectangular stick-ons on my car mirrors. Has anyone ever stuck these https://smile.amazon.com/gp/product/...JPDABE8KA&th=1 on the edge of their windscreen? I'd like something that's more eye level so I don't have to look down and away from the road.
  9. #34
    Northern Kalifornia
    https://www.napaonline.com/en/p/BK_7...pressionRank=9
    Lower inside corner on my RT. Only see my bags there anyway.
  10. #35
    Quote Originally Posted by carolanivey View Post
    Interestingly, I have had to remove those mirrors on the upper inside since I installed my Daylong seat, Carolanivey. It lifted me 2” and they got in the way. On the plus side, I now only see a tiny piece of my elbow in the stock mirrors, so they are working a treat.
    I did use a curved mirror that sits in the middle of the dash in front of you on one of my previous bikes. Yes, your body is in the middle of it, but the curve on each side gave me great peripheral vision. I’ll see if they still make them, as I might give one a go.
    They look something like this, although mine was mounted to the dash, not the screen.
    https://www.pazomaracing.com/product...BoCbMsQAvD_BwE
    HeliBars Handlebars
    Kenda Kanine rear.
  11. #36
    Dec 2015
    Oakley Utah
    I've tried those small convex mirrors on my vehicles and Spyder, but found the object is too small to be recognizeable. Also, with the Spyder I have to take my eyes off the road too long to make out what the spot mirror is showing me.
    The full size custom fit stick on mirrors work well for their purpose. Pricey, yes, but they are optical quality and well worth it for the safety factor, I think.
    Not satisfied with that, I've mounted some inexpensive glass motorcycle mirrors to the outside edges of the instrument panel cowl, up high where i can easily glance at them. I don't know why Can-Am doesn't provide that option.
    2014 RTL Platinum
  12. #37
    Jun 2021
    Dunsford Ontario
    Bought mine at the dollar store work just fine.
    2019 F3 Limited Pearl White
  13. #38
    Apr 2020
    tucson az
    thatshttps://www.amazon.com/Motorcycle-Rearview-Mirrors-Mounted-Windscreen/dp/B08P2MVBMT/ref=asc_df_B08P2MVBMT/?tag=hyprod-20&linkCode=df0&hvadid=616267171621&hvpos=&hvnetw= g&hvrand=10989100113964679607&hvpone=&hvptwo=&hvqm t=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030236&hv targid=pla-1730824790096&psc=1 what I was going to suggest. Amazon has one cheaper
    2011 rt , pearl white
  14. #39
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I put on the ones from slingmods. They work for me.
    2021 RT Base - Petrol Blue
  15. #40
    Active Member arkyleo's Avatar
    Jun 2021
    N. Central Arkansas
    Quote Originally Posted by PhillyPod View Post
    I use these from TricLED. They are designed specifically for the RT and fit perfectly over the OEM mirrors. They may be a lot more than the stick on 2" round mirrors but I really think they are quality and work well.
    https://tricledusa.com/collections/s...clusive-mirror
    Warren
    I put those tricled mirrors on my 2021 RT and they helped a lot increasing the view and eliminating the blind spots. I was fortunate to catch them on sale (can't remember where). Only problem is when passing another vehicle, you have to make sure you wait a little longer to pull in. Objects in mirrors are REALLY closer than they appear. One idea I may try is to remove one side for a better perspective of distance--might work --hope they peel off easy with a little heat.
    2021 Spyder RTL Red, 2024 Triumph Speed 400, blue
  16. #41
    Mar 2015
    Fritch, Tx
    Looking to get the stick on mirrors so I can get better rear view visual. I can live with part of the handle bar in the OEM mirrors, but I want a tad more view from the rear. Been to the after market sites for the complete stick on, but not wanting to pay those exorbitant $, I'm thinking one of those simple stick on round mirrors. Suggestions appreciated.
    I use the round stick-on mirrors on our Spyder as well as bikes that have a fixed mirror large enough to do so. When properly adjusted, the combination of the stick-ons, your regular mirror, your peripheral vision and regular vision, give you 360° of vision without ever turning your head. I do still take a look over my shoulder though as 54 years of driving and over 500K on bikes forms habits that are hard to break.
    Those who say " I can't" will always be right.
  17. #42
    Apr 2020
    tucson az
    Quote Originally Posted by cruisinTX View Post
    Thats a good habit Why try to break it?
  18. #43
    Linden, CA
    Mar 2015
    Fritch, Tx
    Quote Originally Posted by remus View Post
    not trying to; just making a general statement.
