Are Belt Tensioners installed on new bikes same as they used to be?
Just wondering if BRP had updated them when they began installing as a factory build, as opposed to those they used to sell as an accessory? Can't seem to find them on the fiche to compare part numbers. Just a matter of curiosity on my part.
FWIW, I've read all the pros/cons about use of the belt tenioners. I recently added an OEM that I bought a couple years ago but never got around to installing, on my '16 F3T and it works for me. Plan to update to a Lamonster version sometime soon.
Reason: Lamonster ;-)
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
All I know is from personal experience. I took delivery on a new 2022 Sea to Sky and I checked it and found a factory installed tension-er already in place. Prior to this bike I had a 2019 RTL and installed a Lamonster version which worked for me. I will replace the roller on the new bike with Lamonster replacement after a while.
Bartender
2022 Spyder Sea to Sky
So the new Spyder RT's come with them from factory ?
My 2021 F3-S SS came with a belt tensioner from the factory.
2021 Spyder F3-S Special Series
Monster Fuel Injection Stage II
K&N Air Filter
Lamonster Cat Delete Pipe with Baffle
Akrapovic Sinister Exhaust
Ultimate Floorboards
Baja Ron’s Anti-Sway Bar Kit
Elka Shocks Stage 3 Front, Stage 4 Rear
F4 Customs 32” Windshield
Pedal Commander
Lamonster F3 Brake Rod
Shad SH36 Side Cases
Crampbuster
Mine came from the factory with one, Rick. I believe that practice started with the ‘21 RT.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
From what I have read on this forum the '21's had them about mid year. I think the early year builds did not have them. I'm not for sure on that. My '22 does for sure.
Peter Pan has struck again!
Yes, that sounds familiar, Dave. Mine was a later built 2021.
HeliBars Handlebars
Kenda Kanine rear.
Let's get back to the original question. Are the belt tensioners now installed by the factory different from the ones BRP was selling to us as an add on?
Happy owner of 2014 White RTS - SE6
