Results 1 to 11 of 11
    Oct 2011
    PEI Canada
    Default Anyone have a toy hauler for a Spyder RT?
    Anyone have a toy hauler for a Spyder RT? I've looked and all seem too small in length...
    Last edited by Peter Aawen; 08-30-2022 at 01:26 AM. Reason: Expanded Title to briefly ask the question ;-)
    Nov 2018
    Waynesboro, PA
    Try doing a search using the words toy hauler see what you get. Top right side Search
    My Spyder
    2012 RTL , Brown
    Nov 2015
    Chardon, OH
    Quote Originally Posted by ivan View Post
    anyone have a toy hauler for spyder rt I've looked and all seem to small in length
    Motor home or tow behind?
    Doug
    ”Freedom is not a loophole”
    INDIANA, USA
    Default Toy Hauler
    It would help if you tell us what you want to do.
    I have a trailer that I use for my Spyder.
    A little more information will be a great help.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    PA
    Like snow belt asked, Are you looking for a motor home toyhauler with a separate garage or integrated garage? Or a simple enclosed box/ cargo trailer? I can provide all kinds of info on all three if you are a bit more specific. I’ve got a 38’ fifthwheel fuzion with separate garage toyhauler. I have a work and play integrated garage bumper pull toyhauler. I also have a snowmobile trailer with drop down bunks, insulated, electric, cabinets, stove etc cargo trailer. A toyhauler is a pretty generic term. What type or describe what your looking for please. What are you planning on pulling with? What’s your intention for this trailer. Weekend, monthly, snowbird, once or twice a year?
    Louisiana
    I have a 30ft 2018 Trail Runner by Heartland the toy hauler portion is 11.5 ft long just enough to make it has 6 tie downs on floor wife and I love it. Nothing fancy, I did have to extend the ramp cause it would bottom out when it would crest the top of ramp. You will definitely need a 3/4 ton pickup to tow it. See photos attached
    Owatonna, MN
    We have a Grand Design Momentum 394 5th wheel toy hauler with a 12 1/2 ft garage. We are able to haul 2020 RT and a 2012 RT at the same time. It takes some planning to load but we figured out how to do it effectively. My son has a Forest River Grey Wolf 30ft bumper pull that he hauls his F3 in and tows with a 1/2 ton pick up just fine. It only weighs about 5700 lbs empty. He needs to back in because it is narrower the further you go inside. We have driven all over the upper midwest with these toyhaulers without any issues. There are many options depending on the size of your tow vehicle and what size trailer you want.
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Gray Wolf 26RR with our F3t behind a Ram 1500 makes for a great combination!
    2016 F3-T , Intense Red Pearl
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    We have a Winnebago 28KS. It is a towable, about 35", the rear of the living area is the garage when hauling. When camped we have a canopy with sides as a garage for the trike or I use the cover we got from Lamonster Garage. The only problem is that the trailer is tall, and I had to set up a ramp system to keep the RT from hitting the nose when getting on the ramp door, and raise the ramp so the Spyder wouldn't high center. Either that or find a hill to back up to to load into the rig.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Sep 2008
    TX
    Grand Design Momentum 381M fifth-wheel. 15' garage. Haul 2 F3 models: an S, a T and an L, in various combinations. The S has a set of Givi 37 liter paniers which adds substantially to its width across the back. The first is ridden in front-first; the second is backed in. Added wheel chock subfloor to expedite tie-down. Extended loading ramp for nose clearance and the bike that gets backed in would break traction while loading. Takes about 20 minutes to load, stow gear and tie the two Spyders down. Just completed a month stay in east TN.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Mar 2015
    Fritch, Tx
    We have been researching RVs and toy haulers since making an RV trip with the in-laws in Sept. of 2019. After spending a LOT of time on Facebook RV pages, I have found what I think is nearly the perfect floor plan in a TH. It's the Heartland Torque T333 that is a little shy on closet space, but has a 13' separate garage and no second bath which seems to be wasted space to me. I have drawn some mods into that original floor plan to add closet space and turn the dining booth to face a TV on the back side of one of the closets I added. Living space and garage space are pretty much personal preferences and this is what I think fits our needs exactly with a strong possibility of hauling our RT-L and one of the motorcycles at the same time. There is still some measuring to do but this thing looks pretty good.
    Those who say " I can't" will always be right.
