Results 1 to 23 of 23
    Active Member kjweed's Avatar
    Jul 2017
    Syracuse NY
    Default Anyone recommend a good Corded tire inflator?
    Can anyone recommend a decent tire inflator that is corded ?
    2013 RT Limited
    2013 RT Limited , Black
    Northern Kalifornia
    Jul 2017
    Syracuse NY
    Thanks but I was looking to see if anyone had one to recommend.
    2013 RT Limited
    Clinton, MS
    Do you want corded 120 volt or 12 volt?
    Jul 2017
    Syracuse NY
    It would be for my Spyder so a 12 volt.
    2013 RT Limited
    Northern Kalifornia
    Quote Originally Posted by kjweed View Post
    I know. I've had several over the years. It's a crap shoot at best. They work until they quit and they all have features trying to outsell the competition. In my experience find one that doesn't come with the kitchen sink, if you get my drift. Keep it simple. I carry a small one in a flat repair kit that's inexpensive and compact. Never used and hope I never will. There are hundreds out there to choose from and hundreds of opinions. Keep it simple if you can. Good luck.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    This one has saved me lots of trouble. It's compact and fits nicely in the rear trunk:
    https://www.harley-davidson.com/us/e...ght/p/12700020
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Feb 2022
    very southern tip of Texas
    Have been carrying a SuperFlow HV40A2 for several years now. Rigged a 12v weatherproof outlet on the CTX, but on the Spyder it’s easy enough to remove the frunk liner to access the battery. Carry compressor, tools, and rain gear in the frunk. All my family members have one in their autos, as well. Zero problems, so far. Bought from O’Reilly’s.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    Mar 2021
    Maryland
    I got this for my trip in case of a flat. No cords or batteries. Just pop a cartridge and the tire is inflated (after plugging said hole with the plug kit).
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2020 F3 SE6
    2020 F3 , Black
    Quote Originally Posted by redrazor View Post
    What he said!
    Dec 2015
    Oakley Utah
    Yeah, my thoughts exactly.
    2014 RTL Platinum
    Northern Kalifornia
    #5 Either a 12 or a very very long corded 120.
    Clinton, MS
    My favorite of the bunch is the Dynaplug Micro Pro along with the Dynaplug repair kit.
    dynaplug_micro_pro_inflator_750x750.jpg dynaplug_dynaplug_ultralite_tubeless_tire_repair_kit_750x750.jpg
    Dec 2015
    Oakley Utah
    Maybe he wants one to use in his garage? Can't tell from his post.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    They do make 115vac air compressors for auto tires, which work much better than 12vdc, so we have no idea what your application might be.
    The 12vdc units are slow and can't fully inflate a deflated car tire without burning up, so in my book would not qualify as 'good' or 'decent' unless you buy the ARB units for around $100.
    But maybe you just want to occasionally top off your otherwise inflated tires while touring, in which case the dinky ones mentioned here could qualify as 'good' or 'decent'.
    For emergency repair of a punctured tire, get the CO2 cartridge repair kit suggested.
    2014 RTL Platinum
    Bossier LoUiSiAna
    664EED9F-AB73-4FFD-B508-2A7A79FD32F9.jpg as seen tv air hawk pro: 12VDC(cigarette plug) & rechargeable battery & lil carry pouch +-$60 most places , has been handy Do not let run more than 10-12min without time to cool & don’t charge battery over 4h at a time.
    Northern Kalifornia
    I liked that thing. Kinda neat but a bit pricy. Does a 13 limited have an onboard compressor for the rear shock? If so there's the solution.
    Bossier LoUiSiAna
    I liked that thing. Kinda neat but a bit pricy. Does a 13 limited have an onboard compressor for the rear shock? I so there's the solution.
    ST did not get that feature. **Pricy?¿- has more than paid for itself with emergency uses, & otherwise just handy around house, super ez for bailing out family members without much hassle. Just don’t let run or charge too long. Has programmable pressure shut off, not other stops. 81AED3DF-5E68-4361-9CA6-63A1A36A6F2A.jpg added to kit just in case.
    Clinton, MS
    If you have any Ryobi 18 volt tools they make a great hand held compressor that is similar, can be caught on sale at home Depot for about $19 without the battery and charger.
    Aug 2012
    Central Coast, CA
    This is what I carry. I've only used it once and it worked well. Nice and compact.
    https://www.amazon.com/Slime-40061-P...%2C134&sr=8-77
    2020 RTL SE6
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I have one of these and it works great. We used it to jump a fellow rider last year on our Smokey Mountains trip and then plugged it into the USB outlet to let it charge while we were riding. Never had to use the compressor on the road but I tested it out at home before we left by deflating my tires when the bike was on the lift and it re-inflated them all back to the required pressures and it didn't take long to do it.
    https://www.amazon.com/Starter-Compr...s%2C100&sr=8-6
    2022 RT Limited , Silver w/ Black and Purple accents
    Sep 2012
    Stetson, Maine
    At one time Lamonsters garage was selling a rechargeable one. Do not know if he still offers one.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Dec 2015
    Oakley Utah
    The O.P. specified corded, not cordless.
    2014 RTL Platinum
