I reckon what type of coolant would be a much better question.
Originally Posted by UtahPete
So, now where are we on this topic of what anti-freeze to use that meets BRP's specs?
Maybe I'll do a search on this forum and see what I find because this thread has been very confusing I think.
Per this thread, the orange XPS is the correct stuff to use. I have no idea if there is a non-OEM equivalent and don't intend to find out the hard way.
https://www.spyderlovers.com/forums/...ht=anti-freeze
Thanks for that, I was getting a bit confused myself. When in doubt I get the OEM stuff.
Reason: Needless puncuation
2022 RT S2S
It's easier to get forgiveness than permission
Thanks ...... I did a search and found a few here who have mixed the GM Dexcool with the BRP stuff with good results ..... That's what I added to my 14 RT ..... so far I've run three heat / fan cycles and it's seems to be working ..... I'll let everyone know if it FAILS ..... thanks ....Mike
My dealer kinda sorta (in a low voice) said he thinks Can Am stuff is GM Dexcool, knowing Can Am doesn't make the stuff. So I have topped up my antifreeze with the Dexcool without incident.
Bill
Bill
how long , or how many miles since you put that in yours ??
My dealer kinda sorta (in a low voice) said he thinks Can Am stuff is GM Dexcool, knowing Can Am doesn't make the stuff. So I have topped up my antifreeze with the Dexcool without incident.Bill
That's a scary dealer. It's XPS; he should know that.
2014 RTL Platinum
There's a lot more technical info on this thead https://www.spyderlovers.com/forums/...ze-in-the-1330
BTW, I think it's a bit of a misleading misnomer to call it 'antifreeze' anymore. Modern coolant does so much more than protect the cooling system from freezing.
2014 RTL Platinum
Im sure its been mentioned before. I picked up that the tap for draining the system is better left alone. Possibly better to loosen and pull off a lower hose was recommended.
We dont get many brands discussed here in NZ. Is the Orange stuff Pete?
Well, I used to have ginger hair; does that count?
2014 RTL Platinum
hahaha.
I thought the color of the stuff was consistent throughout the world.
Very good.
What say you on the colors?
Crickets I guess..........
Items per Page
Showing 1 - 15 of 15 Results
Nulon Anti-Freeze / Anti-Boil Red Premix Coolant - 6 Litre, , scanz_hi-res
Nulon
$45.69 ^ $60.99
★★★★★ ★★★★★ (71)
Fits Your Vehicle
Engine Coolant / Antifreeze Fluid
Notes: 10L Capacity
Grade: 6 Litre Pre-mix
Qty per vehicle: 1
Nulon Long Life Anti-Freeze / Anti-Boil Concentrate Coolant - 6 Litre, , scanz_hi-res
Nulon
$55.99 ^ $69.99
★★★★★ ★★★★★ (131)
Doesn’t Fit Your Vehicle
Nulon Anti-Freeze / Anti-Boil Green Premix Coolant - 6 Litre, , scanz_hi-res
Nulon
$42.69 ^ $56.99
★★★★★ ★★★★★ (142)
Nulon Red Long Life Anti-Freeze/Anti-Boil Ready to Use - 1 Litre, , scanz_hi-res
Nulon
$19.99
★★★★★ ★★★★★ (44)
Fits Your Vehicle
Notes: 10L Capacity
Grade: 1 Litre Pre-mix
Qty per vehicle: 1
Nulon Red Anti-Freeze / Anti-Boil Concentrate Coolant - 6 Litre, , scanz_hi-res
Nulon
$62.39 ^ $77.99
★★★★★ ★★★★★ (37)
Fits Your Vehicle
Notes: 10L Capacity
Grade: 6 Litre Concentrate
Qty per vehicle: 1
Nulon Anti-Freeze / Anti-Boil Blue Premix Coolant 1 Litre, , scanz_hi-res Nulon Anti-Freeze / Anti-Boil Blue Premix Coolant 1 Litre, , scanz_hi-res
Nulon
$20.99
★★★★★ ★★★★★ (3)
Clearance
Nulon Long Life Anti-Freeze / Anti-Boil Concentrate Coolant - 2.5 Litre, , scanz_hi-res
Nulon
$40.00
★★★★★ ★★★★★ (50)
Nulon Heavy Duty Diesel Coolant Premix 5 Litre, , scanz_hi-res Nulon Heavy Duty Diesel Coolant Premix 5 Litre, , scanz_hi-res
Nulon
$60.99
★★★★★ ★★★★★ (7)
Nulon Anti-Freeze / Anti-Boil Blue Premix Coolant 6 Litre, , scanz_hi-res Nulon Anti-Freeze / Anti-Boil Blue Premix Coolant 6 Litre, , scanz_hi-res
Nulon
$59.99
★★★★★ ★★★★★ (1)
Nulon Long Life Anti-Freeze / Anti-Boil Concentrate Coolant - 1 Litre, , scanz_hi-res
Nulon
$23.99
★★★★★ ★★★★★ (27)
Nulon Heavy Duty Diesel Coolant Concentrate 5 Litre, , scanz_hi-res Nulon Heavy Duty Diesel Coolant Concentrate 5 Litre, , scanz_hi-res
Nulon
$75.99
★★★★★ ★★★★★ (15)
Nulon Anti / Freeze-Anti / Boil One Premix Coolant - 1 Litre, , scanz_hi-res Nulon Anti / Freeze-Anti / Boil One Premix Coolant - 1 Litre, , scanz_hi-res
Nulon
$19.99
★★★★★ ★★★★★ (6)
Fits Your Vehicle
Notes: 10L Capacity, Ultra Long Life Coolant
Grade: 1 Litre Pre-mix ...
See More
Nulon Long Life Anti-Freeze/Anti-Boil Ready to Use - 1 Litre, , scanz_hi-res
Nulon
$18.99
★★★★★ ★★★★★ (25)
Nulon Red Anti-Freeze / Anti-Boil Concentrate Coolant 1 Litre, , scanz_hi-res Nulon Red Anti-Freeze / Anti-Boil Concentrate Coolant 1 Litre, , scanz_hi-res
Nulon
$23.99
★★★★★ ★★★★★ (2)
RED LONG LIFE COOLANT 20L, , scanz_hi-res
Special Order
Nulon
Nulon Red Premium Long Life Coolant Concentrate 20 Litre
$236.00
★★★★★ ★★★★★ (0)
Fits Your Vehicle
Notes: 10L Capacity
Grade: 20 Litre Concentrate
Qty per vehicle: 1
Very good. What say you on the colors?
See the link in post #31 for more info than you thought possible. Start at the end of the thread and work backwards from there.
Reason: thelink - the link ;-)
2014 RTL Platinum
Well as I stated earlier ..... I decided to use the GM DEXCOOL .... I've run my 14 RT through 6 heat / cool cycles and all is well ..... So from my tests, I feel it's OK to mix this with the current Can-Am - OEM coolant..... Mike
Mike, you may have posted and I missed it, but are you still running the Dexcool and is all ok? I had intended to do a flush but couldn't get my old bones to function so had the dealer do it. Tech did say Dexcool was fine for topping off but did not question his source of info.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I actually bought the " Prestone " brand of Dex-Cool it was much cheaper ..... PS to all, Dex-Cool is an Anti-freeze / Coolant FORMULATION which is different from the Green stuff. So anything labeled " DexCool " is OK to use ...... Mike
Thanks Mike. Have a buddy whose coolant is down and water was added. Am gonna check it and if antifreeze is too little, maybe siphoning the overflow container (whatever its called) and adding pure Dex, might well be enough. We don't ride if its below 40F anyway.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Good luck on SIPHONING from the reservoir ..... maybe you will have better luck at getting the internal Strainer out .... I tried to get the siphon tube on my anti-freeze tester into the reservoir and couldn't ..... PS ... DO NOT USE THE DRAIN on the radiator ..... lots of them have broken off. .... If necessary remove the bottom hose .... good luck ... Mike
Mike, if you can get your finger in far enough to guide the anti-freeze tester tube down the very front of the reservoir it will go all the way down. Did this today with my buddy's RT to get an idea of how much was in the reservoir. Very little it turned out, so we added a couple of quarts, mixed with DexCool, and got minus 10 below freezing. We both cannot fig how the coolant got so low as it sits in his garage and never a drop on the floor.
Note to all: if your temp gauge fluctuates at all, check the fluid level.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I just checked can-am parts fiche' and it doesn't even list the internal strainer ..... I know there is one I saw it !!!! ... It could be it's permanently connected inside the reservoir ????? .... good luck .... Mike
Those stupid Okiteker clamps are hit or miss. Our 2014 RTS had a similar unexplained and random coolant smell, coolant loss was minimal if any. Not until I recently did a full system flush, AND replaced all the oem Okiteker clamps did I finally locate the leaking clamp / hose. That bugger was fully buried and not visible until the assembly was removed from the Spyder. But there it was remnants of the random leak.
Had I not been accomplishing modifications to the airboxes and temp probe, that leaker would never have been removed or found. Now all the clamps are smooth band worm clamps.
Apparently "over-filling" the Radiator doesn't have the same impact as "over-filling" with OIL has ..... The Spyder set-up will EXPEL any excess fluid WITHOUT causing an issue ....unlike over-filling with OIL ..... good luck ... Mike
Reason: same impact.... ;-)
