Got an Ez-pass? Where did you mount it on your Spyder RT ?????
For those of you that have one or more ..... where did you mount it on your Spyder RT ..... Thanks ... Mike
I put mine under the lid for the frunk. I've done the same kind of thing on a number of bikes. I had it under the trunk lid on my Goldwings. Never had a problem.
If I need it, I pull it out of the truck and put it in the glove box on the bike or one of the aftermarket bags that are velcro'd to the dash.
2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
Mine is in the trunk on the top in the black area were the hinges are located.
Reason: truck - trunk
Well that's interesting ..... The NY EZ-PASS says ONLY a device designated for a " motorcycle " will be accepted ..... I have three, one is for the Spyder .... Mike
Reason: accep[ted - accepted ;-)
Originally Posted by trikermutha
Mine is in the truck on the top in the black area were the hinges are located.
" truck " .... did you mean ...TRUNK in the rear ???? .... if so that's interesting the ezpass people say use in the FRONT of the Mtc. ..... thanks .... Mike
IBA #47122
2020 RT Limited Asphalt Grey
That's I switched to the frunk. I think the newer ones are as powerful and wondered about the timing of it being read and the camera taking pictures.
Mines on the underside of the frunk lid, works fine. Chris
Well that's interesting ..... The NY EZ-PASS says ONLY a device designated for a " motorcycle " will be accep[ted ..... I have three, one is for the Spyder .... Mike
Well, I've never seen anything on the VA ezpass site that says what type of vehicle, only the number of axles. Motorcycles are 2 axles just like cars. And you can register the pass to multiple vehicles as well. You have to have the plate number for each vehicle so I assume the system that photo id's you reads the number and matches it with the transponders ID and figures out what to charge you. When we take the motorhome, I pull the pass out of the truck and put it on the campers dash. Never any issues so far and we've been doing it this way for quite a few years now. I guess each state is different. YMMV.
F3S below gauge cluster
Reason: Caps
Yes. Trunk in the rear. In fact I even have my Satellite radio antenna next to the EZ toll on mine.. I am guessing the EZ Pass is the same size as EZ Toll. Maybe 3-4 inches long and about 1-1/2 to 2 inches tall?
It does not know where its mounted. As long as it can received the signal.
Originally Posted by ThreeWheels
I have mine here:
Originally, my CDO (that's OCD with the letters in the correct order) placed the pass in the very center of the screen
At speed, the wind funneling through the vent was enough to knock the pass off the mounting tape.
Fortunately, I was able to catch it. I moved it off center and haven't had any issues with it since.
I have it covered with a silicone skin. Basically, just for appearance.
Although it is the standard size, like you, this is motorcycle specific.
The only difference between the car and motorcycle pass is, sometimes, the tolls for motorcycles are less.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And that is where mine fell off on the Hwy doing 75 one morning. Well that was the end of that unit. I must not have put it on the velcro correctly in the morning..
I put mine under the lid of the frunk too. If the EZ PASS can be read through a laminated glass windshield than it can easily be read through the plastic cover lid. I have had zero problems or any issues at all with this installation. I use four small pieces of the Velcro brand Alfa-Lok adhesive fasteners that come with the EZ PASS to mount it.
2021 Spyder RT Limited Asphalt Gray Chrome Edition
2022 Spyder RT Limited Hyper Silver Chrome Edition
Shoei Neotec 3
Cardo Packtalk Edge Duo
Spyderco Paramilitary 2
Vanquest Gen 2 7x10 First Aid Trauma Pack
Garage Door Opener
iPass
DJI Action 2
Tackform Anti-Vibe Phone Cradle
UltraGard Full Covers
Show Chrome rear trunk lid lift strut
Noco Genius 1
Noco GBX Booster X
Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
Baseus Cordless Inflator
To be sure, I check it every once in a while.
I used to keep it on the underside of the frunk lid, but I found that several of the local bridges were unable to read the transponder, mostly the Newburg Beacon Bridge and the Bear Mountain Bridge. Both of these bridges have had the toll booths completely revamped with new readers. I may consider moving it back down to the Frunk lid for safety.
I'm pretty sure the reading failure had to do with the angle the transponder was installed. The frunk lid is transparent to radio waves.
The current location echos a car's windshield in height and angle.
IBA #47122
How I solved my EZ-Pass issue
A few weeks ago, I asked how others have attached their EZ-PASS (you don't pay tolls on the highway) on their Spyders..... Lots of good advice, but in the end, I just put it in my shirt pocket ..... I only need it occasionally and the thought of permanently mounting it didn't appeal to me. ... It recorded all my tolls, and they deducted it from my checking account (my preferred method) ..... Mike
Reason: Moved Post title into text after merge - many only see Thread titles, and post titles mess with Searching! ;-)
SpyderLovers Ambassador
So, You are saying that the 'Toll system/reader' was able to communicate while the pass was in your shirt pocket?
I tried that with a 'RiverLink' pass, but it did not work. I was in my truck and did not want the sticker on my windshield. They said it was designed to be installed on the windshield. .......
So next time I installed it on the windshield with clear tape. This worked and everyone was Happy. ......
Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
ENJOY YOUR LIFE WITH A SPYDER
Originally Posted by Little Blue
So You are saying that the 'Toll system/reader' was able to communicate while the pass was in your shirt pocket?
I tried that with a 'RiverLink' pass but it did not work. I was in my truck and did not want the sticker on my windshield. They said it was designed to be installed on the windshield. .......
So next time I install it on the windshield with clear tape. This worked and everyone was Happy. ......
Yep in my shirt pocket , but I was on my Spyder not in a veh.,... it might not have worked in a veh. ..... Mike
I found the jacket pocket method to be spotty with no obvious reasons for missing the reader. I ended up putting the EZ Pass on the underside of the frunk lid. Works every time and is removable (3M Lock). On my bike, it's on the windscreen w/3M lock.
Does anyone know if an EZ Pass will work if it is mounted to the underside of the front trunk hood?
YES it does. My EZPass is stuck to the underside of the frunk with the 3M strips. Never had an, "EZPass not read".
Thanks!
When I lived in CT, that's where I put it. Only a couple places where it didn't work, The Bear Mountain Bridge, and the Newburg Bridge. Was fine anywhere else.
