Results 1 to 15 of 15
    Feb 2021
    Mundelein, IL
    Post Any suggestions on USB ports for driver and pass heating?
    Hello everyone, I am new here.
    I have just bought my first 2022 Can Am Spyder RTL.
    I am looking to install some USB ports and power for heated for the driver and passenger.
    I have searched through the forums, but didn’t find much for the newer models.
    Any suggestions?
    Dec 2015
    Oakley Utah
    Most of the power and port adapters I've seen aren't vehicle-specific.
    2014 RTL Platinum
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Quote Originally Posted by timgmccabe View Post
    Any suggestions?
    on your new Spyder RTL and Welcome to the
    Spyder forum. You should check with Lamonster Garage or Value accessories
    both sponsor here. They should have what you are looking for
    in a USB port and power for accessories.
    Ryde safe and enjoy the Ryde
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Northern Kalifornia
    Come directly off your battery with a fused (15amp) lead with an SAE connector on the end you're going to use for heat clothing and USB connectors. Your SAE connector can be attached to a number of splitters and safely run many 12v items.
    Oct 2021
    Wichita, KS
    Peter Pan has struck again!
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I didn't think USB would put out enough power for heated clothing.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Northern Kalifornia
    Quote Originally Posted by Wahrsuul View Post
    That's true. However, the SAE connector will. I run two heated jackets on mine and charge our two Sena headsets via USB all at the same time off the SAE connector, which comes directly off the battery.
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    We both have PowerLet outlets installed for heated gear use as well as for emergency air compressor if needed. I've been able to rescue other motorcyclists with flat tires using my oulet and the air compressor I carry.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Mar 2013
    Maumelle, AR
    I ride solo and I installed a power port for my heated gear right up front. I also use it for my battery tender.
    2020 RT Limited , Chalk
    Sep 2020
    Middletown, NJ
    Most heated gear uses 12v and USB uses 5v. An SAE connector fused directly to the battery is the best way to get the 12v for heat. USB ports should be fused and connected to the battery through a relay controlled via the 'key on' power (assy port or license plate light).
    You could use Y-cables with SAE but that can get a bit messy and can overload the cable with too much current draw for 2-up heating. Also, if you blow the SAE fuse, you lose the USB power too.
    2020 RT base , Chalk White
    Danbury Connecticut
    Any suggestions?
    I just bought heated jackets from Cycle Gear. Each came with a 3ft pigtail. On one end, the pigtail has ring connectors and a fuse to connect directly to the battery. On the other end is a barrel connector that plugs into the jacket, similar to Gerbing.
    3 ft was long enough to reach the driver's seat. I bought a 2 ft extension for the passenger seat. When not in use, the barrel connectors are capped under the driver's seat for easy access when needed.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Oct 2021
    Wichita, KS
    That sounds like an excellent setup!
    Vermont
    Any suggestions?
    Sorry I can't help you with what you are asking for. Other members on this site can chime in to help.
    Good luck!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    I use that same set up on my sled.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member ferrasr's Avatar
    Nov 2021
    Alberta
    Going to use a 5' Ring terminal cable to Mono plug to go from the battery to under the riders seat. Then a 2' cable extension for the passenger heated gear or a SAE connector for the battery tender.
Tags for this Thread
