I have just bought my first 2022 Can Am Spyder RTL.
I am looking to install some USB ports and power for heated for the driver and passenger.
I have searched through the forums, but didn’t find much for the newer models.
Any suggestions?
on your new Spyder RTL and Welcome to the
Spyder forum. You should check with Lamonster Garage or Value accessories
both sponsor here. They should have what you are looking for
in a USB port and power for accessories.
Ryde safe and enjoy the Ryde
Come directly off your battery with a fused (15amp) lead with an SAE connector on the end you're going to use for heat clothing and USB connectors. Your SAE connector can be attached to a number of splitters and safely run many 12v items.
I didn't think USB would put out enough power for heated clothing.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
That's true. However, the SAE connector will. I run two heated jackets on mine and charge our two Sena headsets via USB all at the same time off the SAE connector, which comes directly off the battery.
We both have PowerLet outlets installed for heated gear use as well as for emergency air compressor if needed. I've been able to rescue other motorcyclists with flat tires using my oulet and the air compressor I carry.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
I ride solo and I installed a power port for my heated gear right up front. I also use it for my battery tender.
Most heated gear uses 12v and USB uses 5v. An SAE connector fused directly to the battery is the best way to get the 12v for heat. USB ports should be fused and connected to the battery through a relay controlled via the 'key on' power (assy port or license plate light).
You could use Y-cables with SAE but that can get a bit messy and can overload the cable with too much current draw for 2-up heating. Also, if you blow the SAE fuse, you lose the USB power too.
Any suggestions?
I just bought heated jackets from Cycle Gear. Each came with a 3ft pigtail. On one end, the pigtail has ring connectors and a fuse to connect directly to the battery. On the other end is a barrel connector that plugs into the jacket, similar to Gerbing.
3 ft was long enough to reach the driver's seat. I bought a 2 ft extension for the passenger seat. When not in use, the barrel connectors are capped under the driver's seat for easy access when needed.
IBA #47122
2020 RT Limited Asphalt Grey
That sounds like an excellent setup!
Peter Pan has struck again!
Any suggestions?
Sorry I can't help you with what you are asking for. Other members on this site can chime in to help.
Good luck!
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I use that same set up on my sled.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Going to use a 5' Ring terminal cable to Mono plug to go from the battery to under the riders seat. Then a 2' cable extension for the passenger heated gear or a SAE connector for the battery tender.
