Results 1 to 3 of 3
    Active Member rays hell's Avatar
    Hiram Ga.
    Default Fog light switch fm '16 on '21 not triggering relay? Any thoughts/ideas?
    I recently purchased a 2021 F3T and moved my fog lights from my 2016 F3T (will be selling soon)
    After plugging in the lights, I found the plugs and wires were different. After rewiring and starting the bike, the lights came on, but the switch did not turn them off. I unplugged the switch and the lights stayed on. My guess is that the switch is not triggering the relay the same as it did on the 16.
    I am also curious if it's possible to buy just the switch and not the entire fog light kit at $200 plus.
    Any thoughts, comments, much appreciated.
    Last edited by Peter Aawen; 07-10-2022 at 08:56 AM. Reason: Expanded Title to briefly ask question ;-)
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    Jan 2021
    Descanso, CA
    "Any thoughts, comments, much appreciated."
    Either: Buy a new set of fog lights specific to your 2021 (too bad you modified the 2016 fog lights, now they won't sell)
    Or: buy a 2021 service manual and a digital multimeter
    Because you modified the 2016 fog lights, you're in unknown territory and we probably can't help.
    Hiram Ga.
    I'm selling the 2016 f3t as stock {no fog lights} not the fog lights.
    They work just fine on the 2021, I just can't turn them off with the switch.
    They turn off same as the head lights and may just leave them like that.
    Monique,
    factory floorboards
    added topcase
