Results 1 to 22 of 22
    Jun 2022
    New Zealand
    Default Where do I get the front suspension ring tools for 2018 F3S?
    Hi all, I have finally had some time to go over the spyder and took it for a good ride yesterday, I got all the tyre pressures correct and it made a big difference in the ride (as it should)
    one thing though is that the manual say (See a Can-Am dealer for front suspension adjustment.)
    I have owner motorcycles for 40 years before arthritis forced me to 3 wheels and the first thing I did was adjust the suspension on the bikes to suit me.
    I am not taking this spyder to a dealer and spend a couple of hours paying him to help me do something I know how to do (even though it will be slightly different for a 3 wheel vehicle) I believe I can do this.
    Now, where do I get the ring tools (none of my motorcycle suspension tools fit) to be able to change the pre-load of the front suspension?
    thanks all.
    Sep 2018
    Australia
    Try ebay they have zillions of them to choose from. Mine were done up by a 400lb gorilla so something with the max amount of leverage might be best.
    PA
    Ron at bajaron might have one that fits. You’d have to ask. Not sure if his shock adjusters match the hole pattern of the F3. That I don’t know. His hole patterns matches my snowmobile ones perfect. I keep the one he supplied me in my spyder and use my snowmobile one for at home in the garage.
    Feb 2022
    New Zealand
    Gidday. Well its a c spanner. Have a measure and look on T Me.
    Jun 2022
    New Zealand
    Quote Originally Posted by Isopedella View Post
    awesome, thank you all!
    Jun 2022
    New Zealand
    Quote Originally Posted by Cobwebs View Post
    lol my CB1300 is the same, I had to use the extension bar from my car jack to get them to turn
    Sep 2014
    USA
    Yep take the load off them they turn much easier
    Feb 2022
    New Zealand
    Yup for sure - take the weight off the spring and apply a bit of lube helps me.
    Mitre 10 - Repco - SCA anywhere like that.
    Aug 2021
    South Carolina
    A word of caution, the preload adjuster, from bottom to top is about 1". If you move it to the max, it will change the ride height which will change the camber and make it more positive and that will cause the toe to be off. At minimum, get the toe reset, and hope the positive camber don't wear the outsides of your tires.
    Jun 2022
    New Zealand
    thank you, Triniman. I finally got around to changing it this past weekend. I marked one of the "teeth" on the top ring and turned it one revolution around tighter on each side. It made a HUGE difference in the ride and cornering, it was really quite astonishing. I will leave it for now and see now it goes and then adjust as needed.
    Feb 2022
    New Zealand
    Be interesting if you were to throw a tape on it and give it a measure. The bible says :With the weight of both driver and passenger on the bike, adjust the front shocks to be 420mm (16-17/32") between the upper and lower shock mounting bolts.
    Jun 2022
    New Zealand
    I can do that
    Oct 2015
    Lynden, WA
    I have a 2017 F3T. I bought a pair of these spanners from Amazon.
    $7.49 ea.
    C Hook Spanner Wrench Collet Chuck for 68-72mm Round Nut,
    Black Adjustable Hook Wrench Tool Steel Key Hand Tools for Nuts Bolts
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2022
    New Zealand
    When I first looked at the suspension I thought it would take 2 c spanners but it just takes 1.
    You just put on the top Ring and turn. Then snug up the bottom ring and done
    Feb 2022
    New Zealand
    I have not yet not seen the top. Its up under there somewhere. I assumed it was just a ring up top and the adjuster was on the lower section. Live and learn I guess.
    Jun 2022
    New Zealand
    Quote Originally Posted by microwavable View Post
    OMG I love my cb1300s. But I know what you mean. Having said that I just got a set of yss for it and it like a brand new bike
    Jun 2022
    New Zealand
    I don't think I can even part with it.
    Jun 2022
    New Zealand
    thats the one, it was cheap is chips to get a good iron one and dead easy to change it
    Mar 2015
    Tacoma WA.
    Uh..you did lift the wheel off the ground first, didn't you? I've never had trouble setting preload.
    2017 F3-S Daytona , Yellow and black
    Jun 2022
    New Zealand
    Quote Originally Posted by TerryTheSpyderRyder View Post
    nope, no wheel lifting necessary
    Dec 2015
    Oakley Utah
    How do you and wife sit on the bike and adjust the shocks at the same time? A friend wants to know...
    2014 RTL Platinum
    The idea of spring pre-load is to recover lost ride height. However you had your Spyder loaded when the alignment was done. You want to bring it back to that same height when loaded for a ride. You can easily lose well over 1" of ride height when just 1 person sits on the Spyder. More if you load the front trunk, etc. So, measure the nose of your Spyder empty, assuming that's how it was when you aligned it. Then measure again with it loaded. That will tell you how much you are losing and give you an idea of how much lift you need to get back to the original ride height.
    It's not rocket science. Nor is it critical to be right on. Your suspension will settle out randomly at + or - 1/4" or so every time you stop.
