Results 1 to 7 of 7
    Active Member Beanz1's Avatar
    Aug 2021
    Louisville,KY.
    Default Asking Questions Because I don't Know? Is oil change a warranty item?
    I am putting my Ryker Rally in the shop tomorrow. My warranty expires next month and I've never had the Ryker service during the year. When I take it in tomorrow can I have them to do it while it there? I am taking it there for the fuel pump to be checked out or fixed if that's the problem. The oil has not been changed, so just wondering if I can have that done under the warranty?
    Last edited by Peter Aawen; 07-06-2022 at 11:13 PM. Reason: Expanded Title to briefly ask question ;-)
    U.S.Marine Corps
    Vietnam-Veteran 68/69
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Maintenance, such as fluids, spark plugs, CVT belt, brake pads, tires, etc. is owner's responsibility.
    Warranty covers components that fail
    I first changed engine and trans after one month/1,000 miles.
    Fluids came out dark, trans drain plug was almost filled with sediment.
    Drain plugs almost clean, ~5,000 miles later.
    INDIANA, USA
    Default Oil Change
    ....Sorry about that, but Oil changes are not a Warranty issue.
    Check out your, 'Owner Manual' for more information about your Spyder. That being said I would have your Spyder Dealer Technician Check out the necessary items for you and your unit.
    Good Luck on Your Mission. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2021
    Louisville,KY.
    Quote Originally Posted by Little Blue View Post
    Thanks I did that today.
    U.S.Marine Corps
    Northern Kalifornia
    Don't know about the Ryker but with my RT the owner's manual had a sign off page for the first 3K oil change. The dealers' service department along with that oil change performed a safety check of the entire spyder to make sure everything was as it should be. Warranty reasons I suspect.
    INDIANA, USA
    Default What did you find out?
    Quote Originally Posted by Beanz1 View Post
    Just wanted to know what you found out.
    Hopefully all is well......
    Aug 2021
    Louisville,KY.
    They said they'd give me a call in a couple of days to let me know, I'm waiting on the call...
    U.S.Marine Corps
