Results 26 to 50 of 53
  1. #26
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    I've put 3 of these on my Spyder. The 1st one was a vacuum unit. The next 2 were the electronic version. The vacuum unit was OK. But the electronic units were much improved. They lasted between 2 and 3 years each. Water got to every one of them. I am now looking at doing this a 4th time. they used to be about $100.00. They've gone up just a bit over the years.
    Let us know which unit keeps puking on ya so we know which one not to buy ... ;-}
    Quote Originally Posted by DickB View Post
    Rykerrally, thanks for trailblazing this. I followed your lead, but did not use a supplied control. I used pushbutton switches on the switch pod for convenience and a factory look. The wires were snaked through the existing conduit, and a connector added to make assembly and any necessary disassembly easier.
    Excellent job! Parts numbers and sources please! And make this a sticky !!
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
  2. #27
    Active Member DickB's Avatar
    Jun 2021
    Lake Placid, FL
    Connectors
    https://www.amazon.com/dp/B08CVDFV2J?psc=1...
    https://www.amazon.com/dp/B08CVFRT5G?psc=1...
    Set/Decel and Resume/accel switches
    https://www.amazon.com/dp/B08R9P3RKM?psc=1...
    On/Off switch
    https://www.amazon.com/dp/B08Z743TQC?psc=1...
    I used this illuminated on-off switch, but it is not bright enough to be seen in daylight. A non-illuminated one would be fine.
  3. #28
    Jun 2021
    Lake Placid, FL
    Cruise is invaluable on long trips.
    The case on this drive-by-wire unit is not waterproof; it is intended to be mounted under a car dashboard. I did seal the connectors on the case with silicone sealer and sealed the openings at the back of the case, and wrapped it in plastic. I have been looking for a waterproof case, but finding one small enough to fit the space is proving difficult. One could use the glovebox I suppose.
  4. #29
    Sep 2020
    CA
    Dickb, nice clean job. Good to see you completed it. I am guessing it is working well? So happy to see other people are profiting from my install.
  5. #30
    Sep 2020
    CA
    Bajaron, I can understand the control gets wet. I really like what dickb did for his switches. Nice and clean and water proof.
  6. #31
    Jun 2021
    Lake Placid, FL
    Thanks. It is working well. We don't have huge hills here in central Florida, but it holds speed very well, maybe varying 1 mph for a few seconds up or down hill. The RPMs drop for a moment when activating cruise and relaxing the handgrip, but not enough to affect speed. I still have not used it a great deal, but it is definitely much better than a throttle lock.
  7. #32
    Mar 2021
    Michigan
    The case on this drive-by-wire unit is not waterproof.
    Couple coats of this will seal anything.
    It's an insulator, and peelable if necessary. Also holds up to heat. A bit of black tape first to seal any holes that might be hard to peel is probably a good idea.
  8. #33
    Jan 2019
    France
    hi, very good job. A full instruction sheet should be a dream to install this kit....
  9. #34
    Oct 2020
    las vegas
    Quote Originally Posted by Rykerrally View Post
    Hi everyone, I have finished installing and test driving my Ryker Rally with the Rostra Electronic (drive by wire) cruise control. It is absolutely flawless. One push of the button increase or decrease it does it 1 mile an hour. Brake cancels it out just like in an automobile. I used the Rostra 250-1882, with the magnetic sensor and the control # 250-3472. This unit is used on specially built hot rods that have an open or visible drive shaft. No fooling with the vss wire on the bike. I bought my unit from The control store on line. they are awesome, and has a technician that really knows the unit, just don't say it is going on a bike, act like it is a hot rod. His name is Michael. So I have posted some photos of the install thanks to my man doing all the electrical. If you have any questions please don't hesitate to contact me. Good luck. So much better than the throttle lock.
    Which pedal interface did you choose during checkout of the universal kit?
  10. #35
    Jun 2021
    Lake Placid, FL
    There is no pedal interface for a motorcycle, as of course there is no accelerator pedal. You cut the two throttle sensor wires and wire directly per the Rostra instructions.
  11. #36
    Oct 2020
    las vegas
    Thanks for the info.
  12. #37
    Active Member 66Roseracing66's Avatar
    Dec 2021
    Florida
    Thanks to all for all their hard work to get the cruise control sorted out. Not an easy task and much appreciated work. THANKS !!!!
    2021 F3S , Grey/orange
  13. #38
    Jun 2021
    Lake Placid, FL
    Can-Am should have put the cruise control switch where I did. My location is better ergonomically, as you do not need to reposition your hand to reach the switches, and there's one less thing to clutter up the handlebars. (With hand guards, is the switch even farther away?) Ironic that Can-Am issues this warning in cruise control instructions: "Always keep both hands on the handlebar while riding. Otherwise, this could cause a vehicle loss of control."
    Also, the factory cruise control is a single button. You use it to turn cruise on and off, and to set the speed. There is no accel/decel capability, like every car that I have ever driven has. To increase speed with factory cruise, you use the throttle to set your new speed, then press the cruise button for at least 1 second. To decrease speed, you must first press the cruise button to deactivate cruise (or tap the brake), set your new lower speed, then reactivate with another 1-second button press. (This from the 2022 Ryker Operator's Guide.) Perhaps not a big deal, but I do use accel/decel switches often myself. Press and hold to accel/decel to the desired speed, or press x times to change x mph.
    An advantage is the factory cruise will disable if VSS is activated.
  14. #39
    Mar 2022
    WI
    I followed your lead and installed the 250-1882 Universal Cruise for Drive by Wire kit on my 2019 Ryker. I wired the kit up and it works perfectly. I used a couple of variations. I didn’t install an on/off switch. I wired it to be always on and installed two momentary switches for the set and resume. I didn’t have enough room for the nut on the resume switch so I epoxy glued the switch.
  15. #40
    Mar 2022
    WI
    Screenshot 2022-04-02 111948.jpgScreenshot 2022-04-02 112058.jpg20220402_124923.jpg
    this is how i wired the throttle sensors. The blue wire is for the hot side of the brake switch. It is soldered to the red wire in the 4 wire connector. The red wire goes to the start button which is on the same circuit as the hot side of the brake switch.
  16. #41
    Apr 2022
    GA
    Hey @Rykerrally, thanks for posting this. If I end up getting a Ryker, I want to do this.
    A search for 250-3472 on the site produced no results. Could the number of that part have changed?
  17. #42
    Apr 2022
    GA
    Also, I do 3D printing. I could easily print up a waterproof case to any specific size needed.
  18. #43
    Active Member RickD's Avatar
    Apr 2021
    Due South of Houston TX
    It's 250-3742 according to the image.
  19. #44
    May 2022
    CA
    Thank you guys for sharing this. How is this holding on so far?
  20. #45
    Jun 2021
    Lake Placid, FL
    Quote Originally Posted by Ed64 View Post
    Perfect after 1 year. Been through several rainstorms, no issues.
    I put this writeup with more detail together a while back:
    https://drive.google.com/file/d/10Mz...ew?usp=sharing
  21. #46
    May 2022
    CA
    Thank you so much Dick. This is definitely my next project. Just got my 2020 Ryker last month. Having a cruise control will help me with the long coastal trips.
  22. #47
    Aug 2021
    Quebec
    Thanks alot for your help... This will be my winter project
  23. #48
    Oct 2022
    France
    Default Switch harness
    Some additional information on my installation:
    Throttle
    Under the left headlight cover are three black factory connectors: a 4-pin, 6-pin, and 12-pin (they may be in a different order, as I removed and replaced them from their mounts and I may not have replaced in the same order as original). The top connectors go to the handlebar controls, and the bottom halves to the wiring harness. The 6-pin connector is the throttle connection. The green with black stripe is the Throttle Sensor 1 and the green with yellow Throttle Sensor 2. Cut and connect these two at the wiring harness connector per the Rostra instructions. (if you get these wrong, the bike will enter Limp Home Mode as soon as you try engaging cruise.)
    The gray connector is my added cruise control buttons - more on that next.
    Cruise Control Switches
    I ran 4 wires to the cruise control switches using the factory wire loom for the left switch pod. As stated, the On/Off switch is a push - on, push - off switch; the others momentary. Make the 4 wire connections to the cruise module per the Rostra wiring diagram. As explained, I added a connector so that the switch pod can be readily removed if necessary. As this added connector has no mounting point, I wrapped it in foam to keep it secure.
    Brake
    The brake connection can be made here, at this wire bundle that runs along the bottom of the frame to the rear of the bike. The Brake wire is white. There are two white wires; use either.
    I solder then use Liquid Tape on these splice connections, then rewrap the bundle with black electrical tape. I ran this connection, along with the speed sensor wires, to the cruise module using wire loom (which I strongly recommend).
    The Brake + connection on the cruise module can be simply wired to switched 12V power (aux power). It is a required connection for the module to function.
    Speed pickup
    Rostra supplies a mounting bracket for the speed pickup coil, but I used a piece if 1/8" sheet aluminum with a slot cut in it and a cable clamp.
    Where do you find the switch harness? There is none in the package 250-1882 I bought, even no connector? Does it come with the 250-3593 you bought (and don't use)?
    Last edited by Peter Aawen; 03-14-2023 at 07:40 PM. Reason: Removed ' 's before ?'s ;-)
  24. #49
    Sep 2021
    Tri-Cities of Virginia
    Quote Originally Posted by PatrickS View Post
    There is no switch harness, you pull your own wires to the switches, and solder them to the switches themselves, unless you are referring to the cruise switches you pick when you buy the package? Then you will have that 'plug' at the module itself then just add your own wiring and pull it to wherever you want to mount your own switches.
    EDIT: Had to go back and find my order, I picked the 250-3742 with the kit (250-1882), and just used the plug at the module, cut the wiring short, and ran my own wiring up to the switches
  25. #50
    Oct 2022
    France
    Thank you very much for sharing this memento; I got a lot of inspiration from it; I copied the installation of the speed sensor and the switches, I just moved the RES/Accel switch next to the on/off switch; it’s a little more ergonomic ... for my hands (see photos) and a little easier to install I think.
Tags for this Thread
