The noise is exactly what you think it is and is harmless. I bet your car or pickup truck does the same you just can't hear it. The front wheels on these bikes are postioned in the perfect spot to hear every little noise. If a brake pad is dragging hard enough to cause an issue you would know it and the disc would be getting VERY hot from the friction.
