Ryker mph/rpm/reverse
Hello everyone,
Can someone help me out.
My mph, rpm just froze and won’t function properly and I noticed the beeping when I put it in reverse also stopped.
I’m disconnecting the battery for a while to see if that helps.
Thank you,
Gerome D
Ryker mph/rpm/reverse just froze & won't work - any ideas?
Hello everyone,
Thank you,
Gerome D
Ozzie Ozzie Ozzie
Originally Posted by JaxBella
Hello everyone, Can someone help me out.
Thank you, Gerome D
You mean the gauges froze at one reading? The reverse works but doesn't give warning beep?
Can you provide more of an explanation?
2014 RTL Platinum
Hi there
Thank you for responding
I currently don’t have any response when pushing the soft buttons on the instrument cluster.
There is no mph, rpm, or temp reading
I can’t get out of eco mode since I have no response when pushing the soft buttons on the cluster panel
When I put the bike in reverse there is no more beeping sound, hazards than normally would come don’t anymore.
Signals don’t come off automatically when making a turn, I have to turn it off manually.
I appreciate everyone’s input.
What model and year is your Ryker?
2014 RTL Platinum
I guess that disconnecting the battery made no change?
Are you getting a blank screen nothing on it at all? Maybe it came unhooked in the rear, or it's shot all together! Still under warranty, use it!!
I think Ed is suggesting disconnecting and reconnecting the battery as a start to helping you troubleshoot the problem. Most of us are familiar with Spyders, but not Rykers. However some troubleshooting may be common to both.
This is the first I knew of a beeping alarm when a Ryker is in Reverse.
2014 RTL Platinum
The screen is on but not functioning
Nothing works it just at 0 and the temp gauge has 0 bars
The buttons on the side I can’t even use it doesn’t work
When I used to put it in reverse it a beeping “warning” sound to alert people around you
I disconnected the battery overnight and still the same issue
It sure does seem like there's a problem with the electronic module that controls those things. Take it to the dealer while it's still under warranty.
2014 RTL Platinum
Wondering if you were fiddling about with something around the dash module and knocked something loose? Maybe driving in the rain with a loose connector?
And ya, sounds like there may be a service visit in you future, eh.
Where is the dash module located ?
Yes I’m dreading the service visit everywhere is backed up!
Ozzie Ozzie Ozzie
Look for the bit where the speedo, tacho, gas gauge, etc normally appear, with the buttons on it. That's the dash module - it's the black box that makes up the dash & all its workings, display, buttons etc...There's a fairly large bunch of wires that plug into it - check to make sure that's tight, not wet, etc.
I checked out he harness and it looks ok
Might be a loose wire or something
Does it start? If not test the battery. Low voltage/bad battery can do some funky stuff with the electronics.
