Results 1 to 5 of 5
    Member SpyderSaint's Avatar
    Nov 2013
    White House, TN (Middle TN)
    Default Unidentified Missing Cargo Retainer on 2020 F3-T
    I have a 2020 F3-T. I was riding recently with someone on a 2018 F3-T and was astounded when they opened their side cargo box and they had a plastic retainer that ran along the bottom on the inside to keep the cargo from falling out onto the door when opened. Mine didn’t come with these at all and so I had no idea that it appears they should have. Since it doesn’t bolt in, my guess is they just left it off or the dealer swapped it out at some point. However, the dealer can’t identify the part number because it appears to be mis-labeled as a connector or screw instead of what it is (see pics). Can anyone please help me with whether mine should have had these parts and what the part number or name of it is so that I can locate it?
    2020 F3 T , Liquid Titanium
    Mar 2021
    Arizona high country
    Personally, I found them to be a PIA and put them in my spare parts box.
    Oct 2015
    Lynden, WA
    I have them in the bags of my 2017 T.
    Very handy and effective.
    I did glue them in-place and have had no issues.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2020
    California
    Quote Originally Posted by rjinaz86323 View Post
    Likewise.
    Thunder's just the noise. Lightning does the work.
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    They just slot in but seem to unslot themselves all the time. So to be honest, unless you stick them in place they are often more trouble than they are worth.
    I suspect a lot of riders like rjinaz86323 and wmjweber45 have just removed them, so it may be worth seeing if anyone is willing to give/sell you theirs? I would have sent you mine but I've already chucked them away.
Tags for this Thread
