Results 1 to 13 of 13
    Aug 2019
    Stoughton, WI
    Default Anyone know the thread size/length of OEM battery bolts?
    Anyone here have recollection on thread size/length of OEM battery bolts? I added a couple things and now I'll likely add one more ring/star washer to each bolt. I'll get longer ones now if I can find out their size. Thx
    2022 RT Sea To Sky
    I bought longer ones a long time ago ( so I could add extra terminals ) I think they are 10mm .. To check put a 10mm wrench on what you have .. good luck .... Mike
    Oct 2015
    Lynden, WA
    The bolts on the battery of my 2017-T are M6 threads.
    I use longer bolts and star washers to retain my extra wires at the terminals.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Sep 2016
    Chillicothe, Oh.
    Bolt head is 10mm. Threads are M6. Length is up to you and your needs.
    2015 RT , Black
    Oct 2021
    Wichita, KS
    A bolt which uses a 10mm wrench is not 10mm. A standard motorcycle battery uses M6 (6mm-1.0) x 12mm long bolts. The corresponding wrench is 10mm as Mike suggests.
    Edit: Navydad beat me to it.
    Peter Pan has struck again!
    Quote Originally Posted by FrogmanDave View Post
    Thanks ..... it sucks getting OLD ............ Mike
    Aug 2019
    Stoughton, WI
    This helps, thank you I'll pick up a couple that are 16mm long.
    2022 RT Sea To Sky
    Apr 2022
    GA
    Beats the only alternative.
    2017 SPYDER RT LIMITED
    Bossier LoUiSiAna
    May want to consider, post risers https://www.lamonstergarage.com/batt...ers-lamonster/
    Jun 2014
    Schenevus NY
    Not sure those post risers will help with adding additional leads to the battery. It looks like they're meant to provide a convenient secure post for jumper cables.
    Also you can't go too long with replacement battery bolts otherwise they'll bottom out before they're tight enough to hold additional leads securely.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    May 2018
    Chateauguay, Qc, Canada
    My fear is that if you get the length of the bolt wrong you can have either one of 2 scenarios happening.
    1. The bolt is too short and you get too little thread engagement into the nut and it loosens with
    time as the threads pull out.
    2. The bolt is too long and bottoms out and doesn't clamp the stack properly.
    You might want to consider putting a stud at the battery terminal by using a 20 mm or so long bolt, cutting off the head and screwing that into the existing nut. Get a 6mm x1 nut, washer and lock washer and use that to secure whatever number of leads you have to the battery. This setup will ensure engagement into the nut and never bottom out.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Florida Swamp
    The bolts are the same as the lawn tractor battery bolts, and you can buy packages with several sets from Amazon or any of the auto parts stores.
    2019 F3-S , Black & Silver
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Eckhard View Post
    This sir is an excellent idea! Thank you for it.
