Results 1 to 18 of 18
    Oct 2015
    Lynden, WA
    Default Need Helmet Help. Considering HJC & GMax - any issues with either?
    OK, Its time for a new helmet. Needs to be Modular with an internal sunshade, and capable of accepting a Sena 10 unit.
    I've narrowed my search to 2 modular helmets that I have been able to try wearing in the store (CycleGear).
    The HJC C91 and the GMax GM54S (XXL). Both are entry level helmets which is OK for me.
    The HJC is snug but will probably break-in with time.
    The GMax is tight at my forehead. Again maybe it will break-in.
    The GMax has a lot of fitment and repair parts available.
    Are there any known issues with either helmet in fit or function?
    Thank You for your insight.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Feb 2019
    Portland, Oregon
    Snug = good. Tight = bad.
    Hard spots = bad....very bad, especially if on the forehead.
    I have both brands and both fit me well, but they did from the start. True, the padding loosens, but over a great length of time. Any tightness will result in headaches.
    Feb 2022
    Washington
    I am using an LS2. It has all you mentioned. Very sound chin guard that rotates all the way to the back of the helmet. Internal shades are a plus and easy to put down or up. Currently using a Sena intercom/headset.
    Bossier LoUiSiAna
    Hopefully helpful (not restricted to any brand)https://youtu.be/Exjt5q9l1yU
    Apr 2022
    GA
    Just FYI, I measure 62cm, and needed a 4XL with the HJM i90. So at least for me, the size charts are WAY off.
    2017 SPYDER RT LIMITED
    Sep 2020
    Middletown, NJ
    Choose the one that FITS PROPERLY. If it has pressure points (hot spots) now, it is the wrong shape for your head. Wear it around the shop for as long as possible before deciding. It may take a little time to notice the hot spots.
    2020 RT base , Chalk White
    Sep 2016
    Chillicothe, Oh.
    A snug helmet will break in a bit. Tightness at the forehead MAY, but not likely and you will be miserable until/if it does go away. If the HJC fits better I would go that route plus HJC offers different thicknesses of padding to help tailor the helmet to your comfort needs.
    2015 RT , Black
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Haze, I have an HJC C91 XL that I wore about 6 times. I also have 2 shoei helmets. I thought I would like the modular, but I don't. Here is a couple pics of the HJC.
    BTW, I usually wear Large but got an XL cus it fit better.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Helmet pads, do slink a bit, but not much, snug is good, hotspots are bad, scorpion and shark have very different headshapes, I was in the market for a shark, just from reviews on the net, but when in the store, the shark did not fit good, bought a scorpion with the same specs, modular, sunshade, pinlock visor, suitable for comms, and am a very happy camper with them.
    Just sayin, a helmet should fit from the gitgo, else the helmet will hurt the riding experience... Try diffrent brands, and see what fit's your head the best. Sounds like an of the shelf answer, but I know from experience, with 4 helmets not fitting coorectly... that are now expensive bookstoppers....
    Some helmets are designed for oval heads, some for round heads, try and fit them all, the best helmet is the one you don't notice...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    When I purchased my Spyder 7 1/2 years ago I had a modular HJC in my budget. When I tried it on at the dealership it was an instant migraine. The best fit for me was a Shoei Neotec that fit like a glove. I wore it until last fall when it needed to be replaced. I went again to Shoei for a Neotec II that fit even better than and is quieter than the Neotec. While the Neotec II is manufactured for a complementary Sena device a lady at the dealership who specializes in installing comm systems in helmets moved my Sena 20S EVO to the new helmet at no charge and the placement and fit hit the bulls-eye. Yes, a Neotec II is substantially more than an HJC modular, but the cost of it meets the value I place in the contents of my coconut. If the helmet doesn't fit right off the bat, find one that does. Bring a very thin skull cap and plan to wear the helmet at the store for at least an hour. If they won't let you do that, find another store.
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    I have the GMAX 54s and have really enjoyed it. I just ordered a new headliner as after a number of washings the padding at the forehead is no longer firm. I also put an internal fog shield on the visor that helped with fogging. The helmet flows air well and the detent lets me ride with the shield cracked open a tad to flow more. The helmet is fairly quiet at highway speed. I can hear my intercome/radio well. The helmet is a bit heavier than some others. I plan to get a couple more years from it before looking at what is available then. I've looked and honestly, haven't found anything in this pricepoint that I think I would want that is better. I did have to order a couple of the vent covers from them that broke (bad construction) but GMAX service was great and sent them out free of charge as the helmet was still under their warranty at that point. They sent more for future use if needed since I had to do that 2x with customer service. I have replaced the battery in my SENA Smh-10 and it still works as good as new, so not ready to swap that out either. Guess old gear for an old guy (63)
    Oct 2015
    Lynden, WA
    Thanks to all for the input and advice.
    I'm still looking and considering other helmet options.
    David C.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I have an HJC i10 and an HJC i30 Slight. The i10 fits good in size 3XL but I have to put padding between the top liner and the shell so it sits better. The 2XL I had was a little tight in the forehead. The i30 is an XL but could have easily been a 2XL. The only modification I had to do was use a ballpeen on the forehead because like the i10, it was a little tight and gave me a headache after a while. Now it fits good.
    Good luck if you're buying off the Internet. HJC's sizing chart was way off for my shape head.
    2021 RT Base - Petrol Blue
    Apr 2022
    GA
    I ended up buying a Scorpion EXO-GT930. I much prefer an open face helmet. But when you get up in to the 3XL, 4XL size range, there are very few choices available. I like the way I can remove the chin bar, but in my opinion, they screwed the pooch when they made it in such a way that you can not use the outer shield without the chin bar. It's designed to use its own custom EXO-COM com system, which also leaves a lot to be desired in my opinion.
    I never imagined how much of a problem finding a decent helmet for my huge melon was going to be. Takes me back to my first year of Pop warner football. The biggest helmet they had, I could barely even get on my head. But, the one thing this Scorpion has going for it is that it fits my head like it was custom made for me. I guess in a way it was, because I had to remove just a bit of foam in the back of the crown straps.
    Good luck on your search!
    Active Member Woodswoman's Avatar
    Nov 2020
    Upstate NY
    This comment is nothing to do about fitment, and everything to do with safety.
    The first modular helmet I ever bought was a GMAX. It was my third GMAX -- first a 'halfie,' then a 3/4, then the modular. (I got increasingly safety conscious as I learned to ride bigger and faster motorcycles.)
    Once day, when the modular helmet was about 2 years old, I turned my head far to the side (looking at traffic at a stop sign), the chin bar collided a little with my shoulder. The modular front opened. I pulled over and stopped to secure it down again, and it wouldn't. I had done nothing at all to abuse the helmet, yet the modular securing mechanism quietly failed. I don't know how long I'd been riding in this helmet without knowing that such an important safety mechanism was kaput.
    I junked the thing when I got home, and that was my last GMAX helmet.
    2016 Spyder F3-S
    Sep 2018
    Beaver Dam WI
    Sorry you had that experience... i have the 54s modular and the latching mechanism has never failed. It it were to, I'd toss it in the trash too. So far, this model of their helmet has been super dependable.
    Feb 2019
    Portland, Oregon
    I had the latching mechanism fail on my Scorpion modular. I called the company and the immediately sent me a new front piece. I've had no problems with it since.
    Aug 2008
    MA & NH
    My HJC just started to have the rubber trim around the edge come apart. Only a couple of years old. Disappointed.
    Wife and I are both using G Max now for our sled helmets. Love them.
