Results 1 to 9 of 9
    May 2022
    TX
    Default F3 Dash Lights are dimming & hard to see - any suggestions?
    The backlight behind my dashboard appears to have three light bands that are dimming to the point that they are hard to see. The top and bottom bands are dimmer than the middle band.
    Any suggestions?
    Quote Originally Posted by JNJRiding View Post
    Any suggestions?
    I know my RT has a dimmer for it .... I suspect yours does to ...... Mike
    May 2022
    TX
    Thanks. I’ll check it.
    May 2022
    TX
    Thanks but I’m not sure I have that dimmer switch on the F3.
    Mar 2021
    Arizona high country
    I have an 18 F3 Limited. It is in the settings.
    May 2022
    TX
    Quote Originally Posted by rjinaz86323 View Post
    Thanks. I’ll check it out.
    Feb 2022
    north dakota
    my f3 is a 2021 limited and I can't find the switch either. it is really annoying when it changes while i'm riding.
    May 2022
    TX
    In settings, the daytime display is set at 100%. There are no other setting options.
    May 2022
    TX
    Yes with mine, the center band is brightest. The top and bottom bands are really dim.
