Results 1 to 8 of 8
    Active Member mrwog's Avatar
    Aug 2009
    Effingham NH.
    Default Is there a way to reset Vehicle hour meter or turn it off?
    2019 F3 S
    Is there a way to reset or turn of the hr meter or at least so it"s not showing o n the display?
    it reads different every time I start it or ride, one time it may say 120 or 67 etc.
    Some people are like Slinkies good for nothing but fun when tossed down the stairs
    Quote Originally Posted by mrwog View Post
    2019 F3 S
    I THINK you change / eliminate it using the preferences screen .... or maybe not .... good luck .... Mike
    Aug 2009
    Effingham NH.
    I have tried everything with no luck,,,,
    In the manual it mentions it and that's it.
    Aug 2009
    Effingham NH.
    I just looked again, may be the distance I have left in miles till I need gas.
    Mar 2021
    Arizona high country
    is this what you are referring to? If yes then this is the distance to empty.
    Aug 2009
    Effingham NH.
    Quote Originally Posted by rjinaz86323 View Post
    Yes .....I'm having an old man brain fart I just went out to the garage and saw the letters on the left that say DTE.
    Is there a way to not have that sowing?
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    You can shut off the range (distance to empty) display. Go to settings (the gear icon) - then move down to "customization" and choose between range (distance) or off. Toggle back to home and you're all set.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Aug 2009
    Effingham NH.
    Quote Originally Posted by Valkrocket View Post
    Thanks let's seevhow this goes.
