Results 1 to 7 of 7
    Apr 2013
    Browning, Illinois
    Default Where do 2021 RT L pass arm rests attach - the top case or the bike?
    If BRP armrests are installed on a 21 RT L do they attach to the top case or to the bike? If I want to remove the top case I would like for the arm rests to also be removed.
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by hellridgeryder View Post
    Sorry, but the OEM BRP arm rests attach to the Spyder and are not easy to remove........Bill
    "And the panel that takes the place of the top case will not fit with the arm rests on."
    If in Doubt, Don't Do It!
    Jan 2022
    North Dakota
    Attach to bike not top case
    2021 RTL , Asphalt Gray
    Apr 2013
    Browning, Illinois
    Thanks for your help. What brand attaches to the top case?
    Active Member motoguzziman's Avatar
    Jan 2021
    Oconomowoc, WI
    Show Chrome- Here is the write up
    Can-Am Spyder F3 Limited (SE6) / Spyder RT Limited (SE6) 2020, Deluxe Series Black Armrest System by Show ChromeŽ. This Deluxe Armrest System is the ultimate in styling and comfort. The billet forged aluminum brackets are CNC finished and mount to the trunk. The socketed attachment of the swing arm does not intereferewith the trunk opening and swings fully out of the way for passenger access.
    2020 RT , Chalk White
    Apr 2016
    Albany NY
    The OEM arm rests go on & come off in less than ten minutes. I only use them for long trips with my wife. I've done it no big deal!
    Mar 2015
    Brockport, NY
    Once taken off would the panel then easily be installed if you wanted to ride without top case?
    2014 RT-S Pearl White
