Results 1 to 13 of 13
    Dec 2020
    North Germany
    Default Added a Shiftlight to the digital cluster.
    I was not happy with the rev-counter on my 2020 F3-S with the monochrome cluster, the F3 runs 2 times into the limiter while overtaking some trucks
    so I mounted the shiftlight-pro from HealTech, it gets its signal from the CPS-wire, is connected via bluetooth with my mobile and I have several ways to calibrate the shiftlight.
    here the test-ride: https://youtu.be/1vNv7bpXuOM
    for me a "nice to have" - gadget
    modified 2020 F3-S for paraplegics including handbrake, wheelchairmount etc.
    2020 F3-S , pedalbox black
    Quote Originally Posted by ShockwaveSpyder View Post
    I learned how to ride Mtc's long before all the do-dad's mucked things up ...... " Shift Light " .... we don need no stinking shift lights ...... JMHO .... ride safe -ride happy ..... Mike
    Mar 2013
    Marion, Arkansas
    Only place the shift light might be a favorable tool is at the drag strip. Plus I don't see many Spyders at the drag strip.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Sep 2016
    Chillicothe, Oh.
    I like it. I had a sport bike with a shift light on it. Like many things over the years I said I have no use for that, but I missed it when the bike sold.
    2015 RT , Black
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Most of the riders on here don't know that the 1330 redline is 8100rpm and never go any where close to that.
    With the PV3 you can increase that to 8400rpm and the Monster tunes to 8600-9200
    You got it, use it.
    T.P.
    Quote Originally Posted by Ex-Rocket View Post
    Using / relying on a shift light at the Drag Strip ..... If someone is doing this ... they have no business at a drag strip. ...... JMHO .... Mike
    Mar 2013
    Marion, Arkansas
    and neither does a Spyder
    Dec 2020
    North Germany
    Quote Originally Posted by T.P. View Post
    You got it, use it.
    T.P.
    thats the point it seems we here in Germany are rYding faster, even on the Autobahn with no speedlimit. Just entering the Autobahn you have to accelerate like on a dragstrip, but more than 400meters and btw: my topspeed on the highway is 120mph, only, I have my wheelchair on the side
    Jan 2021
    Descanso, CA
    Thumbs up I like it
    I like the light although I'd mount it a bit higher in my line-of-sight. But these days my riding isn't close to the rev limit.
    The throttle-by-wire Spyder controls the rev limit event much better than my Moto Guzzis, etc which cut fuel or ignition. On my track Mustang, I added a shift light set to 200rpm below the rev limit because when the limiter cut fuel the car would pitch down a bit and then when the engine caught again pitch up a bit. Rather distracting in Turns 1 and 2 at 125mph on the Fontana Roval circuit. Sigh -- the good old days.
    May 2013
    Apex, N.C.
    My 2nd generation Vmax had a shift light. I loved the looks of the thing (brought me back to my old mustang days), but I never used it. But it sure did look cool.
    Mar 2021
    Maryland
    Here is a wonderful nice lass that almost beats a Hayabusa ...
    If you watch further into the video a Grom beats an HD.
    2020 F3 SE6
    2020 F3 , Black
    Northern Kalifornia
    I learned a long, long time ago to shift by feel. And the best place to shift is where you can bearly the shift. If you have to depend on a light to tell you when to shift,,,,,,,,,,,,,,well good luck.
    Dec 2020
    North Germany
    itīs just a nice-to-have for me. The monochrome cluster of my 2020F3-S has the counter very small on the right side at the bottom, so out of view. Together with the mounted PedalBox your are going very fast near to the limiter in the first 3 gears.
    similar to BertRemingtonīs Mustang I set the "highest" warning (red flashing) by 7500rpm, so 600rpm before the limiter
