Results 1 to 4 of 4
    Jan 2015
    southern WI
    Default Is there an accessible Hot power supply on '21 RT?
    I want to finally install my GPS base, and I'm looking for a "constant hot" (with key off) source to do so. Other than going down to the battery directly, is there a hot wire somewhere easily accessible? 2021 RT
    2016 RTS , Pearl White
    Active Member Elliott 76065's Avatar
    Mar 2018
    TX
    Lots of good info and videos out there. Here is the one you want.
    https://www.lamonstergarage.com/2020...-power-access/
    Ride safe
    Rick & Kathy
    ETX
    2021 RTL
    2017 F3T , silver black
    Jan 2015
    southern WI
    The connection of GPS base went off without a hitch, and as I was doing that, I decided to add a USB charger cord for my cell phone to the same power supply. HOWEVER, my phone says it's a slow charge. Is the slow charge because of the phone cord, or the power supply? I was hoping for a quick charge set up
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    I installed an accessory plug on my F3 to keep my phone charged. It was a slow charge, so I bought a higher charge rate charger that plugs into my accessory plug and now no issues. I have an Iphone 12.
    Rick
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
