Results 1 to 23 of 23
    Mar 2020
    Prior Lake, MN.
    Default How can I make my 2015 f3s more visible from the back?
    Friends, I would like to add extra rear lighting to my F3s, I want to be more visible. It seems to me that the rear tail lighting is not very noticeable, what are you guys doing? Pictures would help. I would greatly appreciate your thoughts.
    Kind Regards Willie…….
    Last edited by Peter Aawen; 04-05-2022 at 02:37 PM. Reason: Removed Prefix - this is a 'How do I?' not a 'How to:' DIY explanation....
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    This looks interesting from SlingMods.com
    https://www.slingmods.com/canam-spyd...cled?vehicle=1
    Combine that with the LED side reflectors, which can also be seen from behind, and you'll be hard to miss on the road at night.
    https://www.slingmods.com/can-am-spy...-f3s?vehicle=1
    I haven't even received my 2022 RTL yet and have already purchased a bunch of lighting mods.
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by WillieB View Post
    Before I removed my OEM fender and installed the chopped fender, I put these lights on my OEM fender tubing. Lights were cheap, being less than $10 on ebay. I tapped them into the license plate lamp.
    2022 RT Sea To Sky
    Feb 2020
    Minnesota,USA
    Rear facing lights on your front fenders are definitely a bonus!.......Bill
    If in Doubt, Don't Do It!
    Apr 2020
    tucson az
    Not on your bike but your helmet. I think it's motorcycle Dave that has a helmet device that lights up when you apply your brakes. The advantage is now your brake lights are at about eye level for a person driving a cage.
    2011 rt , pearl white
    Mar 2015
    Fritch, Tx
    When I inquired about adding fender lights to my '14 RT-L a while back, someone recommended Oznium LEDs. I took that advice and ran with it. If I've done this right, here is the final post from that project where I added some LEDs to the back for better conspicuity.
    I also add lights to all of my bikes. Here should be where I did that to my most recent two-wheeled acquisition using some 1200 lumen LEDs where I fabricated red lenses for the tail-lights and some flashing LEDs for brake lights.
    Those who say " I can't" will always be right.
    Feb 2019
    Portland, Oregon
    HI-VIS reflective jacket and a white helmet help greatly with visibility.
    Dec 2012
    Murphy, NC
    I replaced the brake/taillight bulbs with brighter LED’s and added Spyderpops LED strips to the rear. Now when I apply the brake the Spyderpops LED’s flash 4 times and then go solid red.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2015
    Fritch, Tx
    This is also very good advice. Not long after seeing a friend of mine's hi-vis yellow/green helmet from at least 6 blocks away, I made the decision my next helmet would be that color. When it came time for my next helmet, I stuck with that decision about two years later. During the interim, I added the hi-vis color along with red reflective tape to my older Nolan. Bright helmets are very noticeable from long distances. Here are my old one with the reflective tape and my new one.
    Mar 2020
    Prior Lake, MN.
    Thanks for all the great ideas.
    Active Member rv6a's Avatar
    Mar 2021
    Indiana
    I wanted to be as visible as possible. I added a bunch of lights all around. The rear ones are tied to the brake light. I got them from slingmods. As a previous poster posted, they have sets for F3s too.
    Active Member mikthebik's Avatar
    May 2010
    Ramona, CA
    Default With luggage and Admore lighting
    If you're using luggage, here is my Shad side case and Givi V46 topcase setup on my F3S demonstrating with the emergency lights active. Brake lights for the Admore cases have a blinking option. All come on with the brakes active. Note the angled LED strips on the top case were not part of the Admore kit. I added strips from Superbright, added mainly to create a turn "arrow"..
    I don't have much faith in extra lighting down low on the swingarm area. I want the lights to be as directly in the driver's face behind me, as possible. Not that most cagers are't attentive enough to be scanning what's around them (riiight..)...
    If you don't have luggage, a hi-vis helmet and jacket, plus attaching a helmet Brake Free device (brakefreetech.com) would be the best solution, in my opinion, to wake up the driver behind. Too bad we can't wire in a rear facing airhorn..
    https://photos.google.com/photo/AF1Q...WRzl_bSeOCzI5Q
    Spyder daily driver - 2015 F3S magnesium - grocery getter
    BajaRon swaybar, Shad sidecases and Givi top case with Admore kits, adjustable brake rod, LaMonster LED headlights, Stebel Nautilus, Zumo 396, FOBO TPMS, F4 Customs windscreen and bump skid
    Front Tires - 175/55R-15 Yokohama AVID S34FA SL
    Rear - General Altima RT45
    Spyder touring buddy (White-Whale) - 2018 RTL pearlescent white - set up for touring and local dates with SWMBO.
    LaMonster LED headlights, Stebel Nautilus, Zumo 396, Spyder cuff, FOBO TPMS, driver adjustable backrest, rear view mirror LED turn signals, and Eastern Beaver PC-8R fuse box. Baja Ron Ultra Sway Bar on the way.
    Front Tires - Stock Kendas
    Other motorcycle transport - 2010 Honda NT700VA Deauville and assorted vintage Japanese bikes
    Mar 2015
    Fritch, Tx
    "Too bad we can't wire in a rear facing airhorn.." What's stopping you. I'm thinking there might be room for a Stebel or WoLo on the inner surface of the saddlebags. hmmmm, may have to look into doing just that.
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Interested in your photos, but an error message with your link.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Quote Originally Posted by RickWB View Post
    Interested in your photos, but an error message with your link..
    It looks like the goggle link is to a private album that requires you to log in to goggle & be accepted by the owner before you can see it....
    Mik, if you have the pics on your computer or phone, click on 'Reply to Thread' down on the left below the last post in the thread, & once it opens scroll down past the text entry field until you get to Manage Attachments, then load the pics either direct from your device or via the url which is a bit further down. It helps them orient correctly here if you've taken the pics in Landscape mode by dropping the top of your phone/tablet/camera to the Left, ie anti-clockwise, cos the Forum platform uses the Top Left corner of any pic as it's default anchor point & is not something easily changed.
    Good Luck. PM if you have issues.
    May 2010
    Ramona, CA
    Looks like I wasn't clear the link was to a video, not a photo. When I posted, I was afraid Google Photos wouldn't allow sharing with "anyone with the link".
    I tried to upload via Manage Attachments, but file was too big, even for a 2 second MP4 reduced to "Computer Size" via Movie Maker, plus saw no option for video files. The upload feature treated either mp4 or wmv as illegal. Then I moved the file to Google Drive, which I've used in the past to share with anyone with the link, so hopefully this link should work...
    https://drive.google.com/file/d/1xUm...ew?usp=sharing
    If there is a way to upload a vid like this, similar to a pic file upload, I'd appreciate any further advice.
    Sep 2015
    Chilliwack, BC. Canada
    Works good for me
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Jun 2015
    Hampton Roads, VA
    TricLed.com has nice LED strips that sit in the seams of saddle bags, but the biggest change was adding the American Flag (4"x6"). Can order the mounting bracket that goes under the licence plate. Big, bright and 'Murican!!!
    Linden, CA
    I have MANY MANY options in stock to light up your F3 I always sell for less. Give me a call I will show a video to you of mine
    209-887-3283
    Linden, CA
    Quote Originally Posted by cruisintx View Post
    "too bad we can't wire in a rear facing airhorn.." what's stopping you. I'm thinking there might be room for a stebel or wolo on the inner surface of the saddlebags. Hmmmm, may have to look into doing just that.
    i bet you can !!!
    Aug 2020
    Omaha, NE
    Quote Originally Posted by remus View Post
    I love this...
    Automotive definition of CHMSL: Center High Mounted Stop Light
    Motorcycle definition of CHMSL: Center Helmet Mounted Stop Light
    Mar 2020
    Prior Lake, MN.
    Motorcycledave, I am hearing impaired, can I see your lights on your website?
    Apr 2020
    tucson az
    not motorcycle dave but here is a video of the light
    https://www.youtube.com/watch?v=Gv2zjC8fzrI
