Results 1 to 19 of 19
    Active Member scorpion56's Avatar
    Jun 2020
    Boston
    Default Snapped the magnetic oil drain plug!
    2019 F3T, 1330 engine.
    And it was going so well........
    Had all the oil drained and safely off to the side. Not too much of a mess. Put on the new gaskets and o-rings. Installed the new oil filter and then went to re-install the 6 mm drain plug. Over-torqued it and snapped the head off. Ouch. And this was not my first DIY oil change.
    Attempting to drill out and replace the plug is not a DIY option for me. The only question I have for all of you, BEFORE I put any fresh oil back into the Spyder is this..... do I just get it towed to the dealer with no oil in it, or put in the oil and see if I have a major leak at the magnetic drain plug. And if things look good, drive it to the dealer. Thanks for your ideas.
    UPDATE: What little oil didn't drain out is, unsurprisingly, leaking by the headless bolt. So it's definitely a tow to CanAm. I don't have enough clearance under the bike to attempt a punch and bolt extractor operation.
    2019 Can Am F3 Limited
    Spyder Upgrades/mods:
    F4 Windscreen,
    Ultimate seat and Driver's backrest,
    Lamonster Fog lights,
    Lamonster Brake Rod kit,
    CanAm Short Reach Handlebar
    Other Current Bike: 2009 Honda Shadow 750 Aero
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    2019 F3 Limited , Oxford Blue Metallic
    Dec 2020
    Hartwell, Ga
    Sorry for your problem, who's oil plug did you use?
    Jun 2020
    Boston
    Thanks. The plug that came with the bike. I've been reading about Gold Plugs on this forum now that I snapped that OEM plug.
    F4 Windscreen,
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    Feb 2012
    Spring City,Utah
    My personal paranoia would have have it trailered to the dealer. But it only costs you the oil to check. So from there your paranoia will take over. Sorry about the mishap . Good luck with your repairs.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Florida Swamp
    Don't torque oil drain plugs. Never torque them in an aluminum case. Torque values are for clean, dry threads. Oil drain plugs are never clean and dry. Lubrication on the threads cause you to over-torque them. Just snug them up with a shorty ratchet. If they drip a little bit, it is much easier to put another quarter turn on them than to try to get a broken plug out. I don't know why they even publish the drain plug torque values.
    2019 F3-S , Black & Silver
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Make sure that you have the GOLD PLUG replacements in hand before you start (MP-01 & MP-18) Or the dealer would put an OEM plug back in.
    https://goldplug.com/shop/mp01/ https://goldplug.com/?s=MP-18
    As your sitting on your Spyder the MP-01 is on the right side and the MP-18 is on your left side
    T.P.
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Happened to me on my 998 2013 RT-S. I was able use a punch to tap remaining part loose enough to screw it out. Now use: Show Chrome (998 MOTOR) M14 X 1.5 / M12 X 1.5 MAGNETIC DRAIN PLUGS
    Ride safe!
    2022 Sea-T0-Sky
    Jun 2020
    Boston
    Quote Originally Posted by T.P. View Post
    T.P.
    That's great info. I'll get them ordered pronto and have the dealer install them in place of the cheap OEM plugs. Thanks!
    F4 Windscreen,
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    Feb 2019
    Portland, Oregon
    Busting in here, this reminded me that even my shop manual did not provide me the torque for the front shock bolts. Can anyone here tell me? 2017 F3L.
    I beg your pardon. Do a search on broken OEM clutch cover drain plug (see picture) and see what you get for the eight plus years the plug has been in use. The plug isn't cheap and the problem isn't on the plug end.
    Thank you , I didn't have the guts to say it .... Mike
    Aug 2019
    Stoughton, WI
    M10 hexagonal flanged elastic nuts [P3] 48 ± 6  N•m (35 ± 4 lbf•ft)
    2022 RT Sea To Sky
    Harrington, Australia
    Ric, on my ‘21 RT the shock bolts torque is listed as -
    48 +/- 6n*m
    35 +/- 4 lbf*ft
    (With “NEW” nuts)
    I’m not sure if the same holds true on your ‘17 F3 though…..but that info was on the first page of Front Suspension in my workshop manual, in the diagram.
    Sorry to hijack your thread Scorpion, but it should be a short hijack
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Jaybros, you're so right......the problem wasn't on the plug end! At least not in my case.
    Unfortunately, I had this happen to me when I did my 1st oil change. Couldn't believe I had actually screwed this up using a small torque wrench. All my years changing oils on my vehicles and never a problem, and here my 1st Oil change on my Spyder, and I break off the Transmission Head plug. UGH!
    Thankfully, I have a set of Easy Outs, and that took care of the problem. Just had to order a new plug.
    NEVER EVER again will I ever torque those 2 drain plugs.
    It only took one time to be taught a valuable lesson. I say, I got pretty lucky. Now after completing 3 oil changes, I am GOOD!
    Rick
    2014 RTS Pearl White
    2014 RTS , Pearl White
    Am glad you got your problem solved. A suggestion, if you're not going to use a torque wrench be certain to change the copper washer on the clutch cover plug and the aluminum one on the crankcase plug each time you do an oil change. That will ensure you get a leakproof seal every time.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    And on top of that, clean the treads, after the oil drained
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Oct 2021
    Wichita, KS
    I'm not sure I understand what the clutch drain plug has to do with the oil drain plug. Can you please explain?
    Peter Pan has struck again!
    Quote Originally Posted by FrogmanDave View Post
    The 1330 engine has TWO oil drain plugs .. One for the engine, and the other for the transmission .. He may be referring to the plug closest to the Clutch cover ..... JMHO .... Mike
    Yes, if you look at the parts diagrams the plug that many folks refer to as the transmission drain plug is actually in the clutch cover fiche. That fiche is also where one finds the hydraulic control module filter, aka transmission filter.
