Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 106
  1. #76
    Feb 2020
    Minnesota,USA
    Wish I could put the weed killer on this thing, I would mix up a batch!! OMG
    A Good thing these engines are 4 Stroke, Can you imagine if the Spyder was a 2 Stroke and they had ta mix the gas & oil. (pre oil injected)
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
  2. #77
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Little Blue View Post
    I will be waiting and watching for your report.
    Always interested in new oil information. .... : )
    I too am anxiously waiting this information.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  3. #78
    Durham,Maine
    2012 RTL , Pearl
  4. #79
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    We also run the Lamonster Garage oil, have had no issues with it.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
  5. #80
    Jan 2021
    Descanso, CA
    Thumbs up My Motul 7100 15W50 story has begun
  6. #81
    Active Member Wildchild6969's Avatar
    Sep 2014
    Lexington, KY
    Default Lamonster
    He is the man to see about everything.
  7. #82
    Active Member GabrieleItalia's Avatar
    May 2021
    Italy
    Motul 7100 5w40 run perfectly for me.(South europe clime)
  8. #83
    Sebring, FL
    I want to use Rotella T6 10/40, but that is getting really hard to find. I may have to use 15/40, or another brand of synthetic if I want to stay with 10/40.
  9. #84
    Aug 2019
    Stoughton, WI
    I thought the T6 (full synthetic) only came in 5w40 and 15w40 weight ratings?
    2022 RT Sea To Sky
  10. #85
    Sebring, FL
    Whoops, my error. 5/40 T6 is what I'm searching for.
  11. #86
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Cannot find T6 5/40 here in WI. Shortage of that product everywhere I guess. Good thing I stocked up last spring!
  12. #87
    Feb 2022
    Texas
    Default Pennzoil Platinum
    I use Pennzoil Platinum. I like that it is a full synthetic oil and that it has a high viscosity.
  13. #88
    Quote Originally Posted by Colleen91 View Post
    I have used Pennzoil in the past ..... Does this one say anything about " Wet Clutch Safe " ?????? .... it makes a difference .... Mike
  14. #89
    Oct 2020
    Arizona
    Quote Originally Posted by WisconsinDavid View Post
    Walmart took my order for 2.5 gal T6 5w-40 for 60 bucks including tax and free delivery. NAPA tried to talk me into Mobile 1 because they could not get T-6, however it did not appear to meet the JACO M/M2 spec.
  15. #90
    Nov 2021
    CA
    I recently purchased my first Spyder, a 2015 RT-S with a manual transmission (SM6). Being a big fan of full synthetic oil I'm wondering if there would be any problems with clutch slippage?
  16. #91
    Quote Originally Posted by gbatown View Post
    NOT as long as you use a brand that is WET clutch compatible ..... Shell Rotella full syn T-6 5 or 10/40 works great ...... and it is probably the least expensive .... google them and see if they have a RE-BATE in effect now ...;. Mike
  17. #92
    Jun 2011
    Near Lexington, NC
    Will be changing soon with Mob1 4T for about $9 qt.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  18. #93
    Vermont
    https://sharena21.springcm.com/Downl...ber=1&Zoom=100
    I use Valvoline Full Synthetic 4-T stroke for my 2014 -RTS-SE 6 spyder. I have had any problems with this oil.
    This oil is formulated for specific needs of high performance motorcycles including high temps, High RMPS, and Wet Clutch Systems ( The spyders have a wet clutch systems).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  19. #94
    Active Member rays hell's Avatar
    Hiram Ga.
    Deanna
    Same here, been using Valvoline 4T for about 6 years.
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
  20. #95
    Active Member deer30084's Avatar
    Tallahassee, FL
    Rather than start a new oil thread, I figured I'd just comment here. It's time for my annual oil change on my 2015 SE6 F3. I have been using Shell Rotella T6, 5W 40, but as you know, you can't find it anywhere now. It is not available in either of the 2 Wal Marts in Tallahassee, FL. But guess what?! You can order it for $79.00. No thanks. It cost me about $34 last year. Get an oil change kit at the dealer you say? Too expensive. $135 last I looked. Lamonster? Even more for the oil. So what did I do? Got the filter from Lamonster for $15.95. Got Castrol 5W40 4T (yep, meets JASO MA2 specs) from Amazon for $52.94 for 6 qts.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
  21. #96
    Sebring, FL
    BajaRon also sells the oil change kit at a reasonable price. My last change I got his change kit, not including oil. He also sells on Amazon, but deal with him direct and save tax and the Amazon up charge for the third party handling.
  22. #97
    Quote Originally Posted by deer30084 View Post
    Do you have a " Tractor Supply " store near you .... google them and see if they have it in stock ..... decent price also .... Mike
  23. #98
    Tallahassee, FL
    Thanks. We do in Monticello, FL and one on the west side of Tallahassee. ......and a few days later.....no Shell Rotella T-6 at area Tractor Supply stores.
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
  24. #99
    Oct 2021
    Florida
    Default Alternatives to BRP and Rotella T6
    I wanted to go Rotella (if I can find it) on my new to me 2020 RTL, BUT from what I read, Rotella T6 xxW40 weight oils don't carry the API SJ SL SM or SN rated as shown in the Owner's Manual. I know it's JASO MA2 rated so OK for , wet clutch, but I understand the "S" (for spark ignition) API ratings confirm suitability for gas engines and address certain additives which damage the catalytic converter (we have one, right?). As for the BRP oil, not only is it expensive, but it also breaks down well before 9,300 miles (more like 3,000-4,000) and it's a semi synthetic. Would appreciate feedback on this from more experienced owners. Thanks.
  25. #100
    Quote Originally Posted by herrerao View Post
    ..... You are overthinking this .... A JASO MA2 is the GOLD standard for oil and FULL synthetic is the BEST ..... IMHO Deisel engines are harder on oil than gas..... and an engine / tranny oil is even tougher. ..... Mike
