Results 1 to 5 of 5
    Aug 2020
    Omaha, NE
    Default Ignition FOB relocation on Ryker?
    Has anyone ever looked into relocating the Ignition Fob unit?
    It obviously comes out pretty easily, as seen in the install videos for a keyless start unit.
    Quote Originally Posted by GrampaEJ View Post
    And why are you thinking of doing this ???? ... if that is what this thread is all about .... Mike ...OK I just discovered you don't own a Spyder,.... So here's some info ... the Ignition Switch also opens almost all Spyder Frunks ( the front trunk ) so if you don't provide another mechanical means of doing this, it won't open .... good luck .... Mike
    Aug 2020
    Omaha, NE
    That's why this is posted in the Ryker section.
    Durham,Maine
    Ryker Mike, not RT
    2012 RTL , Pearl
    Ryker Mike, not RT
    Well He doesn't own one of those either !!!!! ..... Mike
