10W40 Amsoil Synthetic Motorcycle oil
If in Doubt, Don't Do It! ![don't know](images/smilies/shrug.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by Little Blue
![popcorn](images/smilies/popcorn.gif) I will be waiting and watching for your report.
Always interested in new oil information. .... : )
I too am anxiously waiting this information.
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
We also run the Lamonster Garage oil, have had no issues with it.
Greetings from Idaho![thumbup](images/smilies/thumbup.gif)
2014 RT-S,
Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest, Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
![](signaturepics/sigpic16698_12.gif)
2014 RT , White (Mine) Cognac (wifes)
My Motul 7100 15W50 story has begun
Lamonster
He is the man to see about everything.
Motul 7100 5w40 run perfectly for me.(South europe clime)
I want to use Rotella T6 10/40, but that is getting really hard to find. I may have to use 15/40, or another brand of synthetic if I want to stay with 10/40.
I thought the T6 (full synthetic) only came in 5w40 and 15w40 weight ratings?
2022 RT Sea To Sky
Whoops, my error. 5/40 T6 is what I'm searching for.
Cannot find T6 5/40 here in WI. Shortage of that product everywhere I guess. Good thing I stocked up last spring!
Pennzoil Platinum
I use Pennzoil Platinum. I like that it is a full synthetic oil and that it has a high viscosity.
![Quote](images/misc/quote_icon.png) Originally Posted by Colleen91
I have used Pennzoil in the past ..... Does this one say anything about " Wet Clutch Safe " ?????? .... it makes a difference .... Mike
![Quote](images/misc/quote_icon.png) Originally Posted by WisconsinDavid
Cannot find T6 5/40 here in WI. Shortage of that product everywhere I guess. Good thing I stocked up last spring! ![Smile](images/smilies/smile.png)
Walmart took my order for 2.5 gal T6 5w-40 for 60 bucks including tax and free delivery. NAPA tried to talk me into Mobile 1 because they could not get T-6, however it did not appear to meet the JACO M/M2 spec.
![](signaturepics/sigpic41158_6.gif)
I recently purchased my first Spyder, a 2015 RT-S with a manual transmission (SM6). Being a big fan of full synthetic oil I'm wondering if there would be any problems with clutch slippage?
![Quote](images/misc/quote_icon.png) Originally Posted by gbatown
NOT as long as you use a brand that is WET clutch compatible ..... Shell Rotella full syn T-6 5 or 10/40 works great ...... and it is probably the least expensive .... google them and see if they have a RE-BATE in effect now ...;. Mike
Will be changing soon with Mob1 4T for about $9 qt.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
https://sharena21.springcm.com/Downl...ber=1&Zoom=100
I use Valvoline Full Synthetic 4-T stroke for my 2014 -RTS-SE 6 spyder. I have had any problems with this oil.
This oil is formulated for specific needs of high performance motorcycles including high temps, High RMPS, and Wet Clutch Systems ( The spyders have a wet clutch systems).
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
![Quote](images/misc/quote_icon.png) Originally Posted by Deanna777
Deanna
Same here, been using Valvoline 4T for about 6 years.
![](signaturepics/sigpic14531_5.gif) .
Monique,
2016 F3t pearl white
Ultimate driver back rest
12v power outlet for batt. tender
Doc Humphries' vibration damper
factory floorboards
added topcase
Rather than start a new oil thread, I figured I'd just comment here. It's time for my annual oil change on my 2015 SE6 F3. I have been using Shell Rotella T6, 5W 40, but as you know, you can't find it anywhere now. It is not available in either of the 2 Wal Marts in Tallahassee, FL. But guess what?! You can order it for $79.00. No thanks. It cost me about $34 last year. Get an oil change kit at the dealer you say? Too expensive. $135 last I looked. Lamonster? Even more for the oil. So what did I do? Got the filter from Lamonster for $15.95. Got Castrol 5W40 4T (yep, meets JASO MA2 specs) from Amazon for $52.94 for 6 qts.
John F.
Tallahassee, FL
2015 Spyder F3 SE6, black
BRP Driver/passenger Footboards
BRP Adjustable Passenger Backrest
Blue Ridge Windshield
MRA X-Creen Tour, clear, clamp-on
H4 LED Headlights
F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
Easy Brackets
Leatherworks, Inc. 120 Special Slight Angle Saddlebags
Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
2-up rear shock
Idler pulley kit
BajaRon also sells the oil change kit at a reasonable price. My last change I got his change kit, not including oil. He also sells on Amazon, but deal with him direct and save tax and the Amazon up charge for the third party handling.
![Quote](images/misc/quote_icon.png) Originally Posted by deer30084
Do you have a " Tractor Supply " store near you .... google them and see if they have it in stock ..... decent price also .... Mike
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
Do you have a " Tractor Supply " store near you .... google them and see if they have it in stock ..... decent price also .... Mike ![thumbup](images/smilies/thumbup.gif)
Thanks. We do in Monticello, FL and one on the west side of Tallahassee. ......and a few days later.....no Shell Rotella T-6 at area Tractor Supply stores.
John F.
Tallahassee, FL
H4 LED Headlights
Easy Brackets
2-up rear shock
Idler pulley kit
Alternatives to BRP and Rotella T6
I wanted to go Rotella (if I can find it) on my new to me 2020 RTL, BUT from what I read, Rotella T6 xxW40 weight oils don't carry the API SJ SL SM or SN rated as shown in the Owner's Manual. I know it's JASO MA2 rated so OK for , wet clutch, but I understand the "S" (for spark ignition) API ratings confirm suitability for gas engines and address certain additives which damage the catalytic converter (we have one, right?). As for the BRP oil, not only is it expensive, but it also breaks down well before 9,300 miles (more like 3,000-4,000) and it's a semi synthetic. Would appreciate feedback on this from more experienced owners. Thanks.
04-15-2022, 01:11 AM
#100
![Quote](images/misc/quote_icon.png) Originally Posted by herrerao
..... You are overthinking this .... A JASO MA2 is the GOLD standard for oil and FULL synthetic is the BEST ..... IMHO Deisel engines are harder on oil than gas..... and an engine / tranny oil is even tougher. ..... Mike
