Results 1 to 15 of 15
    Active Member Gunner 02's Avatar
    Apr 2014
    Potosi, MO
    Default Recommend an Air horn for 2020+ RT Ltd?
    Anyone have advise on an air horn for the 2020+ RT limited? The original is just too quiet.
    2012 RS White with corbin web seat, misty mountain seat skin, tour windshield, Hindle exhaust, handlebar risers, BRP saddlebags, foot boards, bump skid (critter splitter), fender LED lights, and lots of attitude.
    Oct 2020
    Vinton, IA
    You might start by checking w/ law enforcement; it may be illegal. Plus, I've been under mine & had most of the plastic off; not much room anywhere, 'cept maybe the frunk.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Active Member Schlic's Avatar
    Moscow Mills, MO
    Spyderpops
    THE "BAD BOY" HORN UPGRADE (RT MODELS 2020-UP)
    WOLO/SPYDERPOPS
    SKU: SPY403
    See you at Spyder Rendezvous in June...
    Original: 2013 RT-Limited Pearl White (Bought New 07/2013 Traded @ 34,000 Miles)
    Current: 2017 F3-Limited Pure Magnesium Metallic (Bought New 07/2018)
    Current: 2020 RT-Limited Petrol Metallic Blue
    Sep 2014
    USA
    Is the horn police going to put you over if its to loud?
    Bad boys are ok. but they dont last.
    Feb 2019
    Portland, Oregon
    Here's my pair of extra loud snail trumpet horns mounted over the battery. View is looking down.
    Sep 2020
    Middletown, NJ
    I used a Denali split air horn. I put the horn where the OEM horn was and put the compressor on the inner wall of the frunk. https://denalielectronics.com/collec.../tt-sb-10100-b
    2020 RT base , Chalk White
    Northern Kalifornia
    I have no clue how the 20 RT is constructed but I installed twin air horns on my 14 RT. I did the installation at the same time as I reinstalled my ECM. It's tight but it's possible. The horns were Harbor Freight twin horns and the OEM wiring hooked right up without modification. I had earlier replaced the OEM horn with a Rolo/Bad Boy which was really no improvement whatsoever. I simply modified the Rolo/bad boy mounts to fit the twin horns. It's tight but it's possible to get it where everything fits without touching or rubbing on something. By the way, don't be a dumb a$$ and test the twin air horns while you're bent over sitting next to them as I did. They exceed the pain threshold believe me.
    Harrington, Australia
    I had a Wolo on my ‘16 F3-L for 4 years with no issues, and I now have one on my ‘21 RT-L, Gunner. Bought from Spyderpops. It simply plugs in to the OEM horn wiring sockets, and increases the horn volume to a much more noticeable level than stock. It fits in the same spot as the stock horn, so you have to get under the RT and do a bit of fiddling to install. I was happy with my last one, and I’m happy with this one. It is so much easier than running new wiring through a relay and finding somewhere to mount a full air horn.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    I installed the Wolo Bad Boy horn as well. It's OK. Definitely better than stock but not as loud as the Denali Soundbomb (which is about the same size). I had the Denali Sound Bomb https://denalielectronics.com/collec.../tt-sb-10000-b on my R1200 GSA - it should be easy to install in the stock location on a 2020+ RTL.
    2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
    2021 RT Limited , Marsala Red/Black
    The lack of space under the tupperware is why I installed Wolo trumpet horns. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. The pics below are of the 2013 RT I had but I installed them the same on my 2014 RTS. The 2014 was easier as there is a lot more room for a compressor behind the left side grill. With this setup I left the OEM horns in place and connected.
    The OEM horns aren't as wimpy as many owners think. I did a test comparing the OEM to a Stebel Nautilus I have mounted on my ATV. Virtually the same loudness measured from across the street. I bought the Stebel to put on the Goldwing I had. I couldn't find any place to mount it and it wasn't any louder than the OEM horn.
    Don't expect too much by adding or changing horns. Doubling the decibel level will increase apparent loudness by only 10 to 20 percent.
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I bought horns from slingmods. They're way louder than the stock horns. They aren't air horns, but they sound like very loud car/truck horns. A noticeable difference in my opinion.
    2021 RT Base - Petrol Blue
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    I plan to pick up a couple GL1800 horns from ebay. They are pretty loud!
    1976 RD400c
    Active Member peterparker's Avatar
    Jun 2014
    The Woodlands, Texas and Pipe Creek, Texas
    Don't blow your horn(s) at the cops.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Why don’t they last I have gone through two wolo bad boy horns
    Feb 2022
    New Zealand
    Quote Originally Posted by pidjones View Post
    I have the hi low on my 09 Wing. Very nice tone and loud enough. The few times I have used them as a warning device they get do get a reaction.
    Are you going to mount them above the battery?
    Watching with interest.
    But also considering an AH-OOH-GA Klaxon type horn that I have fitted to a few vehicles and bikes I own.
    https://www.youtube.com/watch?v=Dqc6yRIHiW0
    Seems to get their attention as well.
