Results 1 to 14 of 14
    Feb 2022
    AZ
    Default 2022 Rally - Frunk won't lock? [SOLVED]
    Anyone else have issues with their Frunks? Mine doesn't seem to lock at all. I turned everything off, took the key out put it in another room even and still nothing.
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    '22 frunks lock? My'21 600 doesn't, never read where other models did. I know you can buy an after market kit.
    Feb 2022
    AZ
    Yeah this is included.
    https://can-am-shop.brp.com/on-road/...ebox-lock.html
    Here's the description:
    Innovative Glovebox Lock. The latch is released when you wake up your vehicle (start button) and the valid key is detected. No need to start the engine or reverse throttle. The latch locks when the vehicle is turned off. If the DESS key is removed while the engine is running, the engine will continue to run and the latch will remain unlocked. So once the engine is off, the latch locks either when the key is removed or after a delay of about 30 seconds. Stock equipment on Ryker Sport and Ryker Rally models.
    Jul 2010
    Las Vegas, NV
    When did you take delivery?
    Joe Meyer
    Active Member DickB's Avatar
    Jun 2021
    Lake Placid, FL
    Talk to your dealer - I suspect there is no DESS due to chip shortages.
    "Some consumers say they have received products that were missing features because of the component shortage.
    Last spring, Milton Beaver, who works in the aviation industry in Alaska, spent $16,000 to preorder a 2022 Ski-Doo Expedition Xtreme, a snowmobile made by BRP Inc. DOOO -0.49% When the vehicle arrived recently, it lacked its electronic security system. The company told him they would install the system next year when parts become available.
    Milton Beaver said he was relieved to get his new, if incomplete, snowmobile from BRP in time for winter.
    “Right now any one of those plastic keys will start it,” Mr. Beaver said, adding that he isn’t too worried about his snowmobile getting stolen because he doesn’t leave it unattended in crowded places.
    BRP said it has been sending out snowmobiles without the security feature—while also providing physical locks—to ensure riders get their vehicles in time for the snow. Mr. Beaver said he was relieved to have gotten one at all, as others face delays that could extend well into the winter snowmobile season."
    Feb 2022
    AZ
    Quote Originally Posted by cptjam View Post
    This Tuesday.
    Feb 2022
    AZ
    Quote Originally Posted by DickB View Post
    Oh wow this is interesting. I'll for sure talk to the dealer. Thanks for the reply.
    Aug 2019
    Florida
    Actually they most likely didn't plug it in. If you pop your headlight fenders off, remove the glovebox you will find the unplugged harness. Simply find the other half and remove the block cover from it and plug it in. Then reassemble. It took me all of 20 minutes to fix it.
    2019 Rally , Black with red panels
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Does your paperwork indicate that the dealer installed this accessory?
    Feb 2022
    AZ
    Quote Originally Posted by Zusafek View Post
    Brilliant! That's exactly what it was. Fixed!
    It won't let me attach an image so hopefully this works?
    https://imgur.com/DX5kJ6K
    Aug 2019
    Florida
    Glad to be of help. Happened to me. Easy fix and pointed it out to my dealership.
    Feb 2022
    TX
    Quote Originally Posted by PrayingForSevens View Post
    I picked up a Sport Tues of last week. Noticed when the next day that the glove box didnt lock like advertised. Contacted the dealership and they did some digging and said there was a new TSB out that some bikes shipped from assembly plant without something being plugged in. Rode it back to dealership the next day and it was fixed in 5 mins. Dont give me an excuse to ride & finish break in miles on a nice day!
    Sep 2020
    Alabama
    I had the same issue on my 2022 Sport. I pulled the frunk out to install LED lights and notice the cable was not plugged in. There is an accessory plug there with a cap on it, removed the cap plugged the cable from the lock into the accessory plug now mine works.
    Clinton, MS
    Makes you wonder if Can-Am even included this item on the prep checklist.
