Results 1 to 25 of 29
    Katy, Texas
    Spyder Got her done - installed BajaRon bar plus foam grips & risers
    What the factory didn't give me Bajaron (via lamonster) did, a nice riding machine. Install time was about 3 hours from jacking it up to setting her back down on the ground. Riding in the twisty's is no longer a problem. Shame on can am for making such a crappy sway bar. Installed foam grips and bar riser already all good stuff Maynard. Things are looking good here. Now to find some more trouble to get into...
    Sep 2020
    Middletown, NJ
    Start shopping for tires now
    2020 RT base , Chalk White
    Mar 2021
    Maryland
    If there was any "First" mod to do I would say this is the one.
    It's well worth the price which isn't that much and gives you one hell of a noticeable difference on your ride.
    Luv mine. Getting me some Quatracs next once it warms up.
    2020 F3 SE6
    2020 F3 , Black
    Katy, Texas
    Since I bought the asphalt gray I get an option the other colors can't get... Darth Vader costume. I wonder if they have them in stock at Lamonster garage?
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Rider Steve View Post
    Yes, We are lucky with the Marsala Red, (3) options: Spiderman, Santa Claus, & Ronald McDonald.
    If in Doubt, Don't Do It!
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I have the BajaRon sway bar parts for both my 2021 RT and my wife's 2020 Ryker. I have to wait until spring because it's way too cold in my garage (plus no room) to install them now. Can't wait though.
    2021 RT Base - Petrol Blue
    Jun 2015
    Ritzville, Wa
    I've read where you need at least a 24" rise on the Spyder in order to slide the old bar out. Any confirmation on that?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Clinton, MS
    Quote Originally Posted by gkamer View Post
    I can confirm it.
    Harrington, Australia
    As EdMat says above, 24” is required, Greg. Some have been innovative and have positioned the Spyder above a manhole of some kind when it comes time to drop the bar and insert the new one. Or they have driven the Spyder up tall ramps attached to the back of their pickup, etc etc……. It is so frustrating getting it all undone and finding you have only raised the Spyder 22”. Don’t ask me how I know
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2015
    Ritzville, Wa
    Haha, OK I won't.
    Greg Kamer
    Mar 2021
    Maryland
    Pic of when I installed my Swaybar, I removed the tailgate so the ramps would have a firm grip on the linex in the bed.
    It was raining that day thus the position in the garage rather than outside.
    2020 F3 SE6
    2020 F3 , Black
    INDIANA, USA
    Default 24"+
    ......YES, 24"+ makes it an easy job. .... : )
    ENJOY YOUR LIFE WITH A SPYDER
    Quote Originally Posted by Little Blue View Post
    ……and 24”- makes it an impossible job, Little Blue
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2020
    Arizona
    Only needs to be in the air for a couple minutes.
    May 2021
    Upstate NY State
    I bought a lift, but it only goes up to 17" so I'll make a platform for it to get at least a 24" clearance.
    Sep 2019
    Central Texas
    I’ve used a Pit Bull lift since my Goldwing days. It has the stability and clearance to add the sway bars. I did that with my 2016 RTL and will use it on my F3L to install.
    Jul 2015
    Indiana
    I'm new to this whole sway bar thing... but.... (don't laugh at me).... If I change the sway bar will it void my warranty?
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by peatmoss View Post
    I don't think so, If it does you won't be the only one of thousands affected. OOPS! couldn't help it!
    Jul 2015
    Indiana
    Well, looks like I'll be picking me up one here soon.
    Clinton, MS
    Nope, dealers will install for you for a price $$$
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Whwen I replaced my swaybar, I used a forklift, the "spoons", under the a-arms, with a wooden block between them, worked like a charm, and is one of the best improvements to install...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Katy, Texas
    This is how I did it, safer than using M/C jack.
    Aug 2020
    Il
    My local Can Am dealer charges $375 for the installation alone.
    21 Spyder base F3
    Katy, Texas
    Quote Originally Posted by Pirate View Post
    I've heard dealers will install from 300.00 to 500.00 dollars.
    Aug 2019
    Stoughton, WI
    My dealer charged (1) hour labor.
    2022 RT Sea To Sky
