Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 106
  1. #51
    Durham,Maine
    Take it away Peter! Every now and then you should take it away, never to be seen again, make believe it's one of those post that have stirred up the hornet's nest and upset the masses, take it away! There is really no useful information!
    2012 RTL , Pearl
  2. #52
    Sebring, FL
    Oh my, nearly 8 years old post, yes, a bit at dated I'd say.
  3. #53
    Northern Kalifornia
    This and other subjects like it will never end in our lifetime. Kill it if you can Peter.
  4. #54
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Amsoil 10W40 from Ron. Great stuff. I run it (15W40) in my 19 Duramax as well.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
  5. #55
    Aug 2016
    Nashville, GA
    Shell Rotella T 6 5W40
  6. #56
    Oil threads are like weeds. You can kill one, but another will simply pop up. It's Whack-a-Mole!
  7. #57
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    I use Amsoil VTwin 20/50 good for the Full 9200 mile interval
  8. #58
    INDIANA, USA
    Default History on Oil
    I welcome a little 'History on Oil.'
    The specs on oil have changed. The 'types' of oils we are using have changed. Also the cost of oil will always be going up. BRP Oil has changed along with the times.
    So I an using Mobile 1 full synthetic, because BRP doesn't offer it for Spyders. BRP’S Oil is a mixed blend.
    ENJOY YOUR LIFE WITH A SPYDER
  9. #59
    Member hillrad's Avatar
    Jun 2015
    Hillsboro, Ohio
    RE: Super Tech St Syn V-twin 20w-50 Motorcycle Oil
    Super Tech Full Synthetic SAE 20W-50 provides the following benefits:
    Resists thermal breakdown in high horsepower and high torque engines
    Protects against rust and pitting in gearbox and primary chain case especially during long periods of storage
    High shear stability reduces viscosity breakdown to maximize transmission protection
    Proper friction characteristics keep wet clutch operating at peak performance for smooth consistent shifts
    Meets the specifications of JASO MA2, API SL, and ISO-L-EMA2
    AND... $5.78/qt
    Fog lights
    Tour wind screen & deflectors
    Auxiliary power
    KewlMetal - radiator web
    SpyderPops - Air Dam, Heat Shield & Air Management
    Rivco - floorboards
    Easy Risers
    ISCI - passenger armrests
    Canisterectomy Stant 10819 gas cap
    DYI rear splash guards
    Frunk light
    Handlebar foam grips,cup holder & mirrors
    Wool seat cover
    Rear rack bag
    Car tires Solar 175/65r14 - 215/60r15
    MSD 8.5mm Super Conductor Wires (DIY)
    LED strips brake/running
    2008 GS , MSD 8.5mm Super Conductor Wires (DIY) - Autolite Iridium Extreme Sport Spark Plugs #XS4162 Stock BLACK/SILVER
  10. #60
    Quote Originally Posted by hillrad View Post
    AND... $5.78/qt
    Have you had it analyzed?
    Quote Originally Posted by Little Blue View Post
    BRP's 0/40 is a full synthetic. Though there are many 'Synthetic' oils using a variety of base stocks and additives. Producing a wide variance in manufacturing costs and performance. Just as gasoline varies widely in quality, additives, and octane. So too has the heading of 'Synthetic' become a very large umbrella.
  11. #61
    Aug 2019
    Stoughton, WI
    AND... $5.78/qt
    Or, the Super Tech Full Synthetic SAE 10W-40 4-Stroke Motorcycle Oil. MFRD by Warren Oil Co. Meets same specs:
    Super Tech St Synthetic 4t 10w40 Motorcycle Oil:
    Advanced anti-foam agents prevent foaming especially during high RPM engine speeds to prevent metal to metal contact and wear
    Protects against rust and pitting especially during long periods of storage
    Proper friction characteristics keep wet clutch operating at peak performance for crisp and precise shifts
    Specially designed for multiple motorcycle applications
    Meets the specifications API SL, JASO MA-2, ISO-L-EMA2
    Always follow the vehicle manufacturer's recommendations
    2022 RT Sea To Sky
  12. #62
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    2x on WM ST full synth. oils. Multiple vehicles taken over 200k miles on it.
    I used Valvoline MC 10-40w Jaso rated oil in my F3S on its storage oil change.
    I do not use overpriced BRP oil in my 1200cc 3 cyl. Rotax dry sump motor BRP sleds, I use the filters but not the oil. 10k miles on my '09 sled on M1 0-40w with no issues. They live at 4000 to 8000 rpm all the time when off idle. Sleds do not have a shared sump like spyders.
    BRP specs 0 bottom number now as it keeps its oil inventory simple, one weight/size fits all across the product line. I will not run less than a 10-40w in a motorcycle in summer temps. That's my only oil ''quirk''. Same for power equipment.
    A quality full synth. oil, API and JASO certified, and proper oil / filter changes will never do you wrong. I myself am not a fan of overpriced ''boutique'' oils. Lots of folks are brand loyal, I get it, but the price of admission is not worth it to me.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
  13. #63
    Feb 2016
    We support our site sponsor, Lamonster Garage.
    2020 RT Limited , Marsala Red
  14. #64
    Feb 2020
    Minnesota,USA
    Ditto, x 3, They sell top notch products!....Bill
  15. #65
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    I learned a long time ago, that unless an emergency, one should not MIX oils.
    I recommend use what you are using, and if are unhappy with that, change the brand at next oil change.
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  16. #66
    Aug 2019
    Stoughton, WI
    Well ... As long as the bottle has the API label, mixing will not be an issue. API labeled bottles are required to be compatible. Ideal? Maybe not. Now I wouldn't be mixing a 0w20 oil with a 20w50 oil
    2022 RT Sea To Sky
  17. #67
    Springfield, MO
    Thank you for your support. We feel we have the best oil for your Spyder and that's what we run in ours.
    https://www.lamonstergarage.com/lamo...otorcycle-oil/
  18. #68
    Mar 2013
    Marion, Arkansas
    Been using Amsoil from BajaRon in all 3 Spyders that I have owned and never a engine related problem.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  19. #69
    Jan 2021
    Descanso, CA
    Lightbulb Quicklook on Motul 7100 15W50
    On my 85K mile 2014 RT-S SE6 I have about 3K miles on the synthetic Motul 7100 15W50. Had some days in the 80s (also a day where I drove on snowy roads) but nothing in the 100s yet plus I want to ride another 1K miles before I make a more complete report.
    The quicklook observation is oil pressures are generally 4psi higher (eg 54 rather than 50) than semi-synthetic BRP 5W40 and the synthetic LM/Spectro 5W40. Again the caveat is ambient temperature and engine RPM greatly affect oil pressure. Generally I won't see 54psi at less than 3,500rpm unless the engine is cold where I will see 58psi (the pressure relief setting). Currently idle is where I see the big difference, about 8psi.
    Shifting operation is smoother across a wider range of conditions. Because the 1st owner (I'm the 3rd) took long 2-up trips towing a trailer, there's the possibility the clutch wear is outside the TCM trim range. After I fix the air suspension and some other things I'm going to see if the firmware can be updated or adjusted with BUDS for improved shifting operation (maybe I'm running with 2014 firmware?).
    BTW I found essentially no difference between BRP and LM/Spectro in oil pressures and shifting operation around the 2-3K mile range (I've changed oil and both filters three times in 8K miles). YMMV.
    Please visit my https://www.spyderlovers.com/forums/...tul-7100-15W50 thread for the entire exciting story.
    Last edited by BertRemington; 02-04-2022 at 04:52 PM. Reason: added link to My experience thread
  20. #70
    Feb 2012
    Spring City,Utah
    I am interested in what led you to Motul.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  21. #71
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by jonnysevel View Post
    I need to buy some oil to take on a trip with me..don't want to run to dealer to buy overpriced BRP oil. What brand do you all use??
    Jonny
    And we’re off………..
    2019 F3L , Covid Blue
  22. #72
    Jan 2021
    Descanso, CA
    Cool Wait for it ... My experience with Motul
    Pegasus -- I asked Peter to put my post in a temporary location until I create a "My experience with Motul" thread. I had mistakenly created the post in the "Which way... filter" thread when I parenthetically mentioned my use of Motul, GFrog cited his use, I expanded on my use, UtahPete correctly pointed out I was of bounds for the thread, and Peter patched things up.
    In my forthcoming "My experience with Motul" I'll be describing my experience not advocating a position.
  23. #73
    INDIANA, USA
    Default Motul Engine Oil
    Quote Originally Posted by BertRemington View Post
    I will be waiting and watching for your report.
    Always interested in new oil information. .... : )
  24. #74
    Durham,Maine
    Wish I could put the weed killer on this thing, I would mix up a batch!! OMG
    2012 RTL , Pearl
  25. #75
    Jun 2019
    Deltona FL
    Yeah, apparently the nubies have a tough time finding the search button, lol......
