***** What Tires are on YOUR Spyder - Details Please *****
There's been a lot of talk about a sticky for tires. The purpose of this thread is to create a place for you to share your information.
I'll start:
Spyder: 2020 RTL
Type of Riding: Mostly touring. Not terribly aggressive.
Suspension: RonBar, Laser Alignment
Front Tires: Kumho Solus KH16 175/55/15, set to 17 PSI
Rear Tire: Cooper Mastercraft LSR Grand Touring 215/60/15, set to 26 PSI
Current Mileage: About 12,000 miles. They still look brand new.
Comments: Bought the tires for my previous Spyder and put about 6,000 miles on them. I liked them so much I had them transferred to my 2020 RTL before delivery.
The tires, alignment and RonBar were all installed by Netzley Tire in Accord New York. I'm very pleased with the tires and Remarkably Pleased with Netzley Tire.
Moderator Edit:
THREAD RULES
This thread is for providing the above information ONLY! Any other discussion will be removed. If you have any questions or comments, see one of the many other tire threads (search is your friend) or PM the Member who posted the info you wish to question/discuss.
Reason: Created Sticky & added caveat/Rules
IBA #47122
2020 RT Limited Asphalt Grey
Ozzie Ozzie Ozzie
Spyder: 2013 RT-L
Type of Riding: Spirited Twisty ryding; long/hot distance touring; occasional track/test work
Suspension: RonBar; Laser Alignment; ECU Upgrade with inlet & exhaust mods
Front Tires: Oz spec Kumho Solus 175/55/15, set to 15 PSI
Rear Tire: Oz spec Michelin (tba) 205/65/15, set to 17 PSI
Current Mileage: Fronts - 30,000 ish miles; Rear - 20,000 ish miles. They still look very good with even wear & no heel/toe
Comments: I do adjust my tire pressures on a daily basis to suit any changes in load, ambient temps, road surface or conditions; &/or what I'm doing, and I occasionally swap these tires out to test/evaluate others. This combination of tires particularly suits my need for Sport/Touring All Season/All Weather tires & the long/hot distances I frequently cover here in Oz.
2014 RTS Se6
Front tires Federal Formoza 165/R55 75V
Rear tire General Altimax RT43 215/60R 15
Spyder: 2019 RTL
Type of riding: Mixed. Country backroads, 50 to 500 miles at a time. Interstate 75++ cause if you see me on one I'm in a hurry.
Suspension: BajaRon swaybar and shock preload adjusters. Laser alignment.
Front tires: 175/55R-15 Vredestein Q5's 18 PSI 23,000 miles
Rear tire: 205/65R-15 Vredestein Q5 18 PSI 25,500 miles
Current mileage: Front 23,000 miles Rear 25,500 miles Still in good condition
Comments: Rear tire corrected speedometer to 1/2 MPH low at 70 MPH.
Found the hard way that 175/65R-15 are too big for the front.
Tires have been excellent in rain. Very smooth. Good dry traction.
On my 2011 RTS I have General Alitmax on all 3 wheels. I like them.
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
SPYDER: 2015 F-3S
SUSPENSION: Ronbar and laser alignment
FRONT: Hankook Ventus V4 ES. 175/55/R15
REAR: Hankook Kinergy PT H737 215/60/R15
I have almost 36,000 on the front tires with 18 lbs psi. Should be able to get 40,000 or more. The rear tire is brand new at 20lbs psi.
2020 F3 Ltd
Spyderpops Bumpskid
2019 Spyder F3-S
Type of riding: 100% solo - 80% spirited/20% touring
Suspension:
Front: Fox Podium 1.5 shocks with uprated Ohlin springs
Rear: Wilber 640 HPA
Laser aligned
Tires:
Front: Vredestein Q5's on PPA wheels 17.5#
Rear: Goodyear winter ultra grip 215/60R15 20#
10k miles on the front/like new. Gonna try the rear Goodyear after, literally, 200k+ miles of using them on my trooper cruiser. Loved them. We shall see on the Spyder...
2022 RT Sea To Sky
. Vredesteins in front and General Ultimax on the back. Just ordered a new General Ultimax 43 also. Lots of mountains here and some long trips planned.
Lew L
Same as Lew L....Vredesteins on front and General Altimax 43 on rear. Just putting the Altimax on the rear this week. The fronts are at 16 psi and the rear I’ll start out at 19 psi and see how that is.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Spyder: 2020 RT
Type of Riding: Solo, brisk
Suspension: stock
Front Tires: Vredestein 165/60R15 20psi
Rear Tire: Yokohama Avid S 215/60R15 24psi
Current Mileage: About 4,000 miles rear, 13,000 front. Many miles to go.
I increased tire pressures (from 17psi front) when I felt the fronts rolling under on hard steering inputs.
Head in the game, eyes down the road... 2020RT
Spyder Tryke Pylot
Spyder: 2013 RT-L
Type of Riding: Touring; Local transportation
Suspension: Stock
Front Tires: Vee Rubber 175/55/15, set to 18 PSI Came on Yike (Y-Bike vs Trike)
Rear Tire: Kumho KU25, 91H, 225/50/R15, set to 22 PSI
Current Mileage: Fronts - look newish 1K miles; Rear - Brand new
Spyder: 2019 RTL
Type of Riding: 40% touring and 60% very spirited curvy roads. Ride apx. 7,500 miles per year. ECU flashed to Stage two by Monster. Riding style would be considered as very aggressive.
Suspension: BajaRon sway bar, lazer alignment by Lamonster Garage
Front Tires: Kenda Kanine KR20 165/55R15 55H - Pressure 18 lbs. Handles much better than 20lbs or more.
Rear Tires: Kenda Kanine 225/50R15 76H - Pressure 28 lbs.
Current Mileage: About 5000 miles. They still look brand new.
Comments: I replaced the OEM tires with the Kanine K20 and am pleasantly surprised by their performance to date, much better than OEM tires. I would consider replacing at next tire change with car tires especially if K20's are not available, probably leaning toward Vredestein Quatrac tires but unsure about size. It appears to me that the Quatrac rear tire is not available in factory size but close. My concern with car tires is that some of them seem to have better wet traction than others. Since I will ride in rain or any condition I would not want tires that didn't handle wet pavement well. I am interested in receiving input on suggested car tires and size. Dealer will install any tire I bring in to be installed.
Reason: Fixed tire size/spec
Bartender
2022 Spyder Sea to Sky
Spyder: 2020RTL
Type of Riding: 70% 2-Up touring, 30% most anything goes! Aprox 9000 miles last season,
Suspension: Still stock (sway bar near future)
Rear Spool: Kumho KU-22, 205/55R15 (non-directional) 20 psi.
Front: Spools: Kumho KH-16, 175/55R15 (non-directional) 17 psi.
Old rear Kenda wore out (wires sticking out) at 10,649 miles, Front Kenda developed cupping at about 14,000 miles.
Love the ride of my New car tires, Added the Centramatic wheel balancers on all 3 wheels, Nice Smooth Ride Now!
........Bill
Reason: Fixed tire size/spec ;-)
10W40 Amsoil Synthetic Motorcycle oil
If in Doubt, Don't Do It!
Spyder: 2012 RT-L
Type of Riding: spirited Twisty riding; long distance touring varied Spring, Summer(hot), Fall touring mostly single but occasionally two up with trailer. About 12,000 miles/year.
Suspension: Baja Ron Bar; Laser Alignment
Front Tires: Cooper tires
Rear Tire: Pirelli no longer made
Current Mileage: Fronts - ?; Rear - 20,000 ish miles. The fronts still look very good with even wear. The rear is wearing even across and has maybe 1500 miles left.
Comments: I have my tires mounted at my local tire shop here in rural Utah and they have never balked at me bringing my own tires. The first time I did buy a Mastercraft from them which I liked very much and it lasted 40,000 miles. I also bought my current Coopers there. I let them remove the fronts but I bring the rear wheel in for them to mount and then remount the wheel on the Spyder myself. I run 15 to 18 lbs front and 18 to 20 in the rear. Tires are as close to stock as possible given the brand being used.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
2014 RTS
Front- Federal EVO 165/55-15
Rear- General Altimax RT43 215/60-15
2021 S2S RT
Front- Federal Formoza AZ01 165/55-15
Spyder: 2017 RTL
Type of Riding: touring, mainly 2 up, some with Freedom trailer, back county roads, and some Interstate when needed
Front Tires: Federal Formoza AZ01 165/55R15 @ 17#
Rear Tire: General Altimax RT43 215/60R15 @ 18#
Current mileage: around 9000 miles on front & back - put on at same time
I love these tires, they have all I need for the way I ryde. Would put same tires back on when needed if available.
2017 RTL Asphalt Grey Metallic Chrome
See profile for added mods
Spyder: 2017 RTL
Type of Riding: Day to day running, touring (solo - two-up - two-up+622 trailer), some sport touring, the occassional hot run. Will ride in any weather except hail
Suspension: (Fr) Wilbers 630 Front (Rr) 640 with remote adjuster, adjust dampening depending on ride (freeway vs country road vs MotoX track disguised as country road).
Front Tires: Nankang XR611 165/65R15 20 psi dry, 18 psi wet
Rear Tire: Nankang XR611 225/50 R15 26 psi dry, 24 psi wet
Current Mileage: Fronts 40,000kms, rears about 20,000 per tyre (I don't let them wear all the way) Spyder has 68???kms on clock
Comments: Switched from OEM Kenda to Arachnid saw improvement ditched it, and tried the Nankangs. Decided to give aftermarket shocks a try + sway bar, but aftermarket shocks have addressed the issues sufficiently. Not one to be too concerned about mileage, prefer grip and handling. Alignment done by my very competent dealership mechanic. I was ready to abandon Spyders until this combo resulted in a very tidy ride and convinced me to stay with the product.
PSOP excellent idea
Reason: Formatting error
SpyderLovers Sponsor
I am using Michelin Tires all around I got them from our local Costco they mounted & balanced them
the rear was tricky I had to remove the brake and pulley from the wheel
Ozzie Ozzie Ozzie
Please see the reminder below from the opening post of this sticky - if you want to keep the sticky here &/or going, please post accordingly.
Moderator Edit:
THREAD RULES
Recently bought the 2015 F3-S. Has factory original Kendas in front, and selling m/c dealer installed a brand new Kumho Ecsta AST rear, size 225/50R15. Know nothing about it so far. Will try to remember to revisit this thread once we get some miles on it. Looks like 20-22psi should be about right on the rear. Spyder has right at 6K miles on it.
White 2015 F3-S SE6 - “ Gypsy” (hers)
Yellow 2017 F3-S Daytona 500 SM6 (his)
Originally Posted by 2dogs
2014 RTS Se6
This is the same as I run on my 2019 RT. I have about 20,000 miles on my rear now and just received an other General to replace it. I have used these tires on my 2015 RT and now my 2019.
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
Tomorrow ... putting them On... 225/50R15 Kumho ESCTA & 165/65R14 Sincera
I just ordered 165/60/15 Vredestein tires for my 2018 Spyder Lt.
Reason: Removed questions/additional discussion & following discussion posts as per thread rules!
Ride safe!
2018 Spyder RT Limited
Ozzie Ozzie Ozzie
I'll start:
Spyder: 2020 RTL
Moderator Edit:
THREAD RULES
2020 Can-Am Spyder RT
2018 Honda Goldwing DCT
