Results 1 to 25 of 30
    Nov 2021
    Raleigh, NC
    Default Comfort Seat Worth it?
    I have pre-ordered a 2022 Spyder RT Ltd. It was ordered by the dealer and I put a down payment on it. There are no accessories included with the original order. Since its been my experience that stock seats on any bike isn't worth much I'm considering ordering the comfort seat. For those that have ridden both is the comfort seat worth it? I'm on the heavier side and any extra firmness in the seat is usually worth it.
    My second question is does the OEM rider backrest fit both the stock heated seat and the heated comfort seat?
    Thanks for any comments.
    Feb 2019
    Portland, Oregon
    Remember this; One size does not fit all.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    My wife sat on a regular 2021 and a Sea to Sky. The comfort seat is the same as the one on the S2S except the stitching and logo. She said get the comfort seat.
    1976 RD400c
    Feb 2016
    Quote Originally Posted by pidjones View Post
    I beg to differ. A lot of people say that the comfort seat is the same as the S2S seat other than the stitching. I have a 2020 RTL and switched it to the Heated Comfort Seat as soon as I got it. I have since sat on numerous Sea to Sky bikes , and to me, the S2S seat is hard as a rock compared to my comfort seat. I DO believe it is dimensionally the same as a S2S, but I don't think the foam is the same. Previously I owned a 2015 RTL and had switched it to the Heated Comfort Seat also. You won't get me to go back to the stock seat.
    2020 RT Limited , Marsala Red
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Interesting.
    My stock 2021 RTL came with the heated seat and grips. I find it to be very comfortable. Even after hours of riding I have not had to use my Air Hawk pad which was a must on my 2008 Gold Wing trike stock seat.
    However, I rode passenger seat on the Sea to Sky on a good test ride put on by Can-Am and I thought that seat to be a little more cushy than my RTL.
    I think I would be happy with either seat.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    I have had two comfort seats. 09/RS, 2014 RT-S. IMO, an upgrade from the OEM. Able to do 150 miles without problems, compared to 50 or so with the OEM.
    Jan 2021
    Oklahoma City
    The Sea to Sky seat uses a layer of memory foam also, as I understand it it is the only seat offered from CanAm with memory foam. I find the seat the most comfortable OEM seat I’ve ever had. But as RICZ said, “one size does not fit all,” so relying on what I think or what others think is probably just a crap shoot when it comes to your own personal comfort. Good luck with your choice.
    INDIANA, USA
    Quote Originally Posted by Sagebrush View Post
    You are correct about the extra firmness stuff. The rider's weight has a major factor on seat comfortably.
    So a lot of the seat issues can be made doable, but may have an extra cost. Which by the way is the only way to get quality ryde time.
    There are still some good 'seat options' but you will need to do your homework.
    As far as the backrest goes, BRP in the past has always made two different types. So most likely the backrest for the OEM Seat will not fit the 'Comfort Seat'.
    Your Spyder Dealer should know for sure......
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    Seats are a hard thing to compare for you, every ones butts are different in a lot of ways and like different things. I have had both and like the comfort seat just a hair better than the stock!
    2012 RTL , Pearl
    PA
    I have the comfort seat and my dad got the comfort seat on his new spyder. I ended up cutting mine up, adding the gel pad from Dave, added the heat pads and put 2 layers of memory foam over everything. When installing the memory foam,after spraying the 3M, I actually sat on the seat for 30 minutes while it dried. It formed perfect to my needs. A guy I know that makes profession drag strip seats told me to do that and wiggle a bit. As it glues, air pockets can form and glue release forming the perfect fit. (Only for driver not passenger) He stapled on the cover, it’s a perfect fit. My wife sat on both, as a passenger, Oem and comfort and could really tell the difference. She liked the comfort. As for the difference between the pre 20 vs post 20, sitting on both comfort seats, the post 20 is a touch wider especially the passenger and much firmer. But that’s comparing the generations not apples to apples. Wife liked the comfort, I got the ultimate and heat by doing my own work much cheaper. Best of 2 worlds. I agree with the statement everyone is different. I’d get some seat time, add an air hawk first then jump. I can say this. Even though I have a perfectly fit seat now, on trips I never let my butt or wife’s butt get used to the seat position. Every fuel stop we switch thing up. I start with nothing just seat. Next stop add air hawks. Next stop remove air hawk bladder and insert a gel pad. Next stop start all over. Changing up is our success pattern when touring and riding 8-10 hours everyday for a period of days.
    Dec 2015
    Oakley Utah
    I don't know about recent models, but with my 2014, the main difference between stock and comfort seats is the added legroom of the comfort seat.
    2014 RTL Platinum
    Nov 2021
    Raleigh, NC
    I appreciate the replies. Why I'm a little confused is this, if I go to build my own Spyder RT Ltd on the Can Am website it only shows one riders backrest and doesn't flag it if you add the heated comfort seat but if you go to accessories in general it does show a different backrest for the heated comfort seat but it isn't clear which model or year of Spyder it is for. If the rider backrest is indeed different for the comfort seat then I would order it and the associated backrest. What I'm trying to avoid is buying a backrest for the stock seat and then find out I need the heated comfort seat and have to buy an additional backrest. There really isn't enough information available on the Can Am site.
    PA
    My backrest was different in 2017 for comfort vs Oem. I ordered mine after I got the bike. I’d do the same if I was you. The dealer should offer 10% off so you’re ahead anyway to wait. Then you know it’s right. Dad ordered the comfort seat and LED’s and then purchased everything after. The dealer took off some since he ordered the comfort. The site you get both seats which is a waste since they don’t deduct the original seat. I’d order after, it’s the same price, with discount its basically saying the post order is tax free if discount applied.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Like RICZ stated - One Size DOES NOT fit all.
    With the off season coming WAIT!
    Find a local group and ask to sit on their various saddles.
    But remember a few minutes on a saddle will only give you a ROUGH idea.
    There are numerous other Brands out there and you don't want to put out a Grand just to realize later OOOPS!
    A few will even give you a few weeks to try it out and if NOT satisfied return it (Custom Colors, patterns, etc. do not apply)
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    I have now ridden my heated comfort seat for an extended period of time and can say that it is the most comfortable seat I have had. Before this I had a Corbin that was very firm, rock hard. Was told that is better to have on a long ride. In comparison with this seat , does not compare. The comfort seat has extra firm cushioning in all the right places. Also the material keeps you locked inlace, no slip no slide. The extra expense over the stock seat was worth the money.
    So only one backrest is for the 2020 and up model year. So the photo on the left above is for 2019 and prior. In the pictures the one you order is without the BRP logo in the center of the back rest. SKU 219400957
    Hope this helps!
    TicketBait
    Nov 2021
    Raleigh, NC
    That helps a lot. Since I have degenerative discs throughout my lumbar spine I just cannot ride without a backrest. If the backrest works for both the stock and comfort seats then I can order just that and wait and see if I need the comfort seat.
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    I rode with the sto9ck seat for a short while and after sitting on a Sea 2 Sky, decided on getting the BRP heated comfort seat (Same as the S2S except for stitching). Both my wife and I like it a lot. I do use the BRP backrest and like that as well. My wife and I both ride ATGATT and my back armor hits the backrest and I had to get used to it. I am 6'2" 245. My wife is little.
    That said, I ride with a WildAss seat cover and find it raises me a bit and that is more comfortable for me. Coming from a BMW R1200 GSA, I find the Spyder more cramped. See my other options in my sig.
    Best of luck!
    2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
    2021 RT Limited , Marsala Red/Black
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I am probably going to get blasted, but I think the only difference between the stock seat and comfort is it gives you almost 2 inches of leg room. UtahPete stated that. I'm basically agreeing with his statement. I needed the extra stretch.
    My personal experience with the two that I have owned have been based on additional miles able to travel without the OEM "mush" factor kicking in. It may be the extra two inches or so set back, but the butt seems to be able to go another 100 miles more than the OEM stuff the Spyders come with.
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I swapped out my OEM seat for the comfort seat and noticed a huge difference. But I still had that issue of on long rides, in hot weather, with shorts on, my butt would still sweat, so I ended up buying a sheepskin and with both new seat and the sheepskin, it's a very comfortable ride without the headaches of butt sweat. lol
    But to answer your question, yes, the backrest is interchangeable.
    2021 RT Base - Petrol Blue
    Jul 2013
    Conn.
    Default Comfort upgrade
    I’m thinking of upgrading my 2017 RTL to heated Comfort Seat, I normally ride 2 up. How much room is left for the passenger?
    I want to keep her Happy…
    2017 RTL , Grey
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    It's OK for the passenger but I find it short for the driver.
    2021 Can Am Spyder Sea-to-Sky
    Member Slick51's Avatar
    Jun 2020
    North Carolina
    I have a comfort seat on my 2016 RTL and had to remove the backrest when the wife rides, she didn't have enough room and she is not a big girl, about 5'4" and 132. I would not have kept the bike without the extra room of the comfort seat, the stock was way too cramped. I don't mind not having the backrest when two up. Will use it when I'm solo.
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    My wife tried the s2s and thought the seat was great. So I'd like to put a call out to anyone that has upgraded there s2s to comfort that I would be interested in purchasing your old seat. Just pm me thanks.
    Clinton, MS
    Quote Originally Posted by kamper View Post
    I think changing the S2S seat out for a comfort seat would be a downgrade.
