Results 1 to 23 of 23
    Oct 2021
    Texas
    Default Ryker 900 stutter / hesistation in reverse
    Here is my dilemma.
    I changed the the rear tire and took it to discount tire to get mounted on rim.
    I took it off the bike and remounted it after I got the tire shop to put the new tire on.
    While it was off I changed the final drive fluid.
    Bike drove fine afterwards
    Today when I was driving I decided to give it WOT I hit 90mph and a loud beep came on, dash said vss and check engine light came on.
    I took the bike off and turned it back on, it drove fine the rest of the way home.
    Here is the issue.
    When I put it in reverse it stutters and shakes when I give it gas it gets better but this is all new.
    In fwd it drives fine.
    What do y’all think ???
    Check engine light is off and there was no vss on dash after I restarted it
    I have 6700miles 2020
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Start by checking the rear speed sensor and wiring for anything that could have been affected by wheel removal.
    Oct 2021
    Texas
    Oh that’s awesome
    Where is that located ?
    I appreciate the input
    Active Member DickB's Avatar
    Jun 2021
    Lake Placid, FL
    Same diameter tire as original?
    Oct 2021
    Texas
    Yes the same
    Oct 2021
    Texas
    I’m confused why it would happen
    Fwd is ok
    Is there any way to bring up the engine codes ?
    May 2020
    New Mexico
    The rear speed sensor cable assembly has a connector at one end and the sensor at the other.
    The sensor mounts similar to a crank or cam position sensor: One bolt hole, with a metal sleeve reinforcing the plastic.
    The sensor points at the reluctor (tone ring), which has slots for inputs to the sensor.
    When removing the rear caliper, to pull off the wheel with the disc, was anything done with the sensor?
    Gap is important. When Triumph had issues with crank position sensors on the New Triumph Bonnevilles (2009 first year of EFI), the specified gap was changed from 1 mm to 0.8 mm and problem solved.
    Oct 2021
    Texas
    Great to know !
    I had no clue when I was doing so, I just took the caliper off and laid it down.
    I will go back and take the wheel off and look through everything
    Also it’s good to know about the gap.
    I will re-seat the tire.
    Thank you for your help!
    May 2020
    New Mexico
    Doubt you need to remove anything. Just inspect the rear VSS.
    I would send you better photos, but the Ryker is no longer in the garage.
    This thread has some photos, but not sufficient for the sensor
    https://www.spyderlovers.com/forums/...tenance-photos
    Hopefully other Ryker riders will help with more appropriate photos.
    This link has most sensor part numbers
    https://www.spyderlovers.com/forums/...r-amp-location
    And when it is time for spark plugs, this may be helpful:
    https://www.spyderlovers.com/forums/...ng-spark-plugs
    Oct 2021
    Texas
    So I took the wheel off looks like everything is intact
    I even made sure the wheel was seated close in and there was no play.
    I also unplugged the battery for 20 minutes
    Same thing happens :/
    It very jerky fwd and worst in reverse only at slow speeds
    Oct 2021
    Texas
    There’s also a squeaking noise coming from the cvt belt area
    It just coincidental that the belt is faulty when I just did the tire change and final drive change
    Durham,Maine
    It's time for a new belt!!! Clean your clutches while your there! Soap and water will work, let it dry put it back together and ride it!!
    2012 RTL , Pearl
    Oct 2021
    Ontario
    New here, but would a 2020 with 6700 miles need a new belt or clutch adjustment ?
    Oct 2021
    Texas
    That’s what I was thinking
    So soon for a belt ?
    But I’m leaning towards that
    Going to dealership on Friday
    Durham,Maine
    Quote Originally Posted by Raven View Post
    From what he's saying that's where I would start, no matter how many miles he got! If he's not hearing any grinding going on. it could be his belt slipping. Just my thoughts
    2012 RTL , Pearl
    Oct 2021
    Texas
    Thank you everyone !
    Oct 2021
    Texas
    So I finally got a service appointment, looks like the rotor is bent so that’s what caused the vibration at low speeds and more than likely caused the vss check engine light.
    I took the tire to get swapped out there but discount tire probably didn’t care and bent my rotor while doing so, now I know for the future that I won’t be going there.
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    About the reverse problem - Mine was doing the same thing and the solution was to adjust the shift handle. It wasn't going all the way to the stop. Next time iet happens, try applying a bit of force to make sure the lever is all the way over.
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    Oct 2021
    Texas
    Ok
    Hopefully they have the issue fixed before I get it back
    But with parts and all there is a two week wait before the rotor comes in
    May 2020
    New Mexico
    Most M/C shops can handle a wheel with disc still mounted, but for an automotive tire shop, best to remove disc.
    Jan 2021
    Oklahoma City
    Has anyone tried Cycle Gear for dismounting/mounting Spyder tires. I’ve had them do several motorcycle tires with the rotor left in place so wondering if they might do our Spyder/Ryker tires?
    Oct 2021
    Texas
    I didn’t know that
    My rotor got bent at discount tire
    Oct 2021
    Texas
    We’re also waiting on the bolts for the rotor to come in
